![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: INVITATION: Join the Mississippi Paddle-Wheel Steamer!
Date: 28 Mar 2018 02:06:55
Message: <5abb30ff$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 28/03/2018 04:30, Sven Littkowski wrote:
> Thanks Alain and Stephen. :-)
> The item is what is to be checked for (like the name of a Declare union,
> I would assume).
> The first coordinate is from where the search ray is starting?
> The second coordinate is towards which direction (destination) the
> search ray is heading?
> Norm contains the coordinates of a hit?
I think that it a good idea to quote the bit of code that you are
talking about.
Norm is the vector of the normal if the trace ray hits the target. So we
test to see if the vector is not zero. That means we have a hit. If Norm
is zero then the ray missed.
I have an test scene from when I was learning to use trace() that is
self contained. Firing arrows at a mesh target. A study for Saint
Sebastian. I will post it after cleaning up the Bishop3D workarounds.
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 28 Mar 2018 09:07:35
Message: <5abb9397$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I once had Bishop 3D, too. In fact, I was been one of the beta testers,
and thus got the unlock code free of cost.
But then, my hard drive crashed, and I lost all programs and e-mails.
Now I cannot find the Brazilian developer anymore to ask him to re-issue
me my unlock code. I am not joking, I was really one of the beta testers.
Bishop 3D is a great software. Just it doesn't like functions. But all
the shapes - it can handle them very well!
Thanks for your TRACE help! :-D
Diese E-Mail wurde von AVG auf Viren geprüft.
http://www.avg.com
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 28 Mar 2018 09:51:37
Message: <5abb9de9$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I remember. You were building an underwater base.
Actually if you go back on the website. You will find a registration key
as Hugo made it freeware.
Drat! The site has gone but you can get it via the wayback machine.
https://web.archive.org/web/20160122202116/http://bishop3d.com/download.htm
StephenS developed quite a few techniques for workarounds by using the
Raw Code plugin. We even managed to get screen.inc to work in B3D
> http://www.avg.com
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 28 Mar 2018 14:02:09
Message: <5abbd8a1$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Wow, I did not knew about these "latest" developments! You can see,
since how long I lost touch. Sad and good news in one.
I registered the software now, after all these years, thanks to you. :-)
http://www.avg.com
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 28 Mar 2018 19:19:45
Message: <5abc2311$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Le 18-03-27 à 16:33, Stephen a écrit :
> On 27/03/2018 20:04, Alain wrote:
>> Le 18-03-27 à 05:28, Sven Littkowski a écrit :
>>> Thanks. I heard about that function, but have problems to handle it.
>>> But never mind, I have all coordinates of the entire scene in my mind. I
>>> find it difficult to learn to work with so-called WYSIWYG editors, I
>>> hand-code everything. :-)
>>> http://www.avg.com
>> You mostly need to remenber that trace(object, start, direction) use a
>> start location and a direction. If you change the last value, you'll
>> trace in different directions.
>> trace(Deck, <PosX, 1000, PosZ>, -y)
> Even I can use it. ;-)
> Use PosX, PosZ to describe a grid with a loop. And check that
> (vlength (Norm)!=0) and do some stuff
> Hmm! I had an extra variable:
> #declare Inter = trace (Trace_object_,< Pos_x, Pos_y, Pos_z >, z, Norm);
> #if (vlength (Norm)!=0)
> Then do some stuff.
> #end
> Alain probably knows and uses a more efficient way of coding it than I
> do/can.
If you can be reasonably sure that all your start points are over the
target object, then, you can omit the normal parameter.
But, yes, taking the normal into account is normally preferable.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 28 Mar 2018 19:30:49
Message: <5abc25a9$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> I would assume).
> http://www.avg.com
The correct way to use trace with an arbitrary, oddly shaped, target
object is :
#declare Normal =<0,0,0>;
#declare SurfacePoint= trace(<PosX, 1000, PosZ>, -y, Normal);
#if(vlength(Normal))
...do your stuff...
"SurfacePoint" will contain the location of the point directly under
<PosX,1000,PosZ>, or <0,0,0> it the trace miss the object. As a
legitimate point may be at that location, this is not a reliable way to
know if the trace hit or not.
"SurfacePoint" contain the location that interest you.
If the trace miss the target object, Normal have a zero length. If it
find the object, Normal contain the normal of the surface at that point
as an a unit length vector.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 28 Mar 2018 23:06:13
Message: <5abc5825@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>>> mind. I
>>>> http://www.avg.com
>>> a start location and a direction. If you change the last value,
>>> you'll trace in different directions.
>> Then do some stuff.
>> #end
>> do/can.
Thanks for the tip. :-D
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 29 Mar 2018 02:46:11
Message: <5abc8bb3$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
And I had bun and cheese in celebration. :-)
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 29 Mar 2018 18:21:22
Message: <5abd66e2$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Bun and Cheese"? I thought, that was a purely Jamaican thing - they
sell it here that way. So it is a wider English thing, I recognize.
Again learned something new and absolutely important... :-D
http://www.avg.com
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 29 Mar 2018 18:35:08
Message: <5abd6a1c$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thanks. I will copy the code and use it as reference for later usage.
Good help here in this group. :-)
http://www.avg.com
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
