POV-Ray : Newsgroups : povray.binaries.images : INVITATION: Join the Mississippi Paddle-Wheel Steamer! Server Time
5 Jul 2025 23:23:00 EDT (-0400)
  INVITATION: Join the Mississippi Paddle-Wheel Steamer! (Message 14 to 23 of 73)
Subject: Re: INVITATION: Join the Mississippi Paddle-Wheel Steamer!
Date: 25 Mar 2018 03:03:47
Message: <5ab749d3@news.povray.org>
On 24-3-2018 21:18, Sven Littkowski wrote:
> UPDATE
> Having made a small test-run for the transport items that will be, later
> on, inside and around the yellow storage area. Cotton bales and hay
> bales for now, but more to come.
For later correction: the bales intersect the ship.
Date: 25 Mar 2018 08:55:00
Message: <web.5ab79c0d2c27e3405cafe28e0@news.povray.org>
Sven Littkowski <I### [at] SvenLittkowskiname> wrote:
> UPDATE
> Diese E-Mail wurde von AVG auf Viren geprüft.
> http://www.avg.com
That's looking pretty cool so far    :)
For some reason, the way / method it got posted, it doesn't show up as an
in-line image, and it doesn't get listed in the image digest either   :(
Just curious - is it mathematically linked / parameterized so that you can
animate it?
Date: 26 Mar 2018 19:12:25
Message: <5ab97e59@news.povray.org>
Yes, I know. The deck at that location goes upwards. But the foreship
locations where the bales are stored (later on), are fully horizontal.
There won't be any cutting. :-)
http://www.avg.com
Date: 26 Mar 2018 19:13:39
Message: <5ab97ea3$1@news.povray.org>
Yes, with a little extra work, the wheels and the entire ship can be
animated. But that's not on my list for now. That comes later, much
later. :-)
http://www.avg.com
Date: 27 Mar 2018 02:51:02
Message: <5ab9e9d6$1@news.povray.org>
If you use the trace() function for positioning the bales on the deck,
you will avoid such problems.
http://wiki.povray.org/content/Reference:Vector_Expressions#Functions
Date: 27 Mar 2018 05:28:39
Message: <5aba0ec7@news.povray.org>
Thanks. I heard about that function, but have problems to handle it.
But never mind, I have all coordinates of the entire scene in my mind. I
find it difficult to learn to work with so-called WYSIWYG editors, I
hand-code everything. :-)
http://www.avg.com
Date: 27 Mar 2018 06:44:49
Message: <5aba20a1@news.povray.org>
UPDATE
The progress continues, and the main deck becomes more and more complete...
http://www.avg.com
Download 'sl - mississippi paddle-wheel steamer - prow atop side.jpg' (2358 KB)
Preview of image 'sl - mississippi paddle-wheel steamer - prow atop side.jpg'
Date: 27 Mar 2018 15:03:43
Message: <5aba958f$1@news.povray.org>
> http://www.avg.com
You mostly need to remenber that trace(object, start, direction) use a
start location and a direction. If you change the last value, you'll
trace in different directions.
trace(Deck, <PosX, 1000, PosZ>, -y)
Date: 27 Mar 2018 16:33:11
Message: <5abaaa87$1@news.povray.org>
>> http://www.avg.com
Even I can use it. ;-)
Use PosX, PosZ to describe a grid with a loop. And check that
   (vlength (Norm)!=0) and do some stuff
Hmm! I had an extra variable:
#declare Inter = trace (Trace_object_,< Pos_x, Pos_y, Pos_z >, z, Norm);
#if (vlength (Norm)!=0)
Then do some stuff.
Alain probably knows and uses a more efficient way of coding it than I
do/can.
Regards
Date: 27 Mar 2018 23:30:34
Message: <5abb0c5a$1@news.povray.org>
Thanks Alain and Stephen.   :-)
The item is what is to be checked for (like the name of a Declare union,
I would assume).
The first coordinate is from where the search ray is starting?
The second coordinate is towards which direction (destination) the
search ray is heading?
Norm contains the coordinates of a hit?
http://www.avg.com
