POV-Ray : Newsgroups : povray.binaries.images : Algorithmus Wanted Server Time
8 Jun 2026 09:04:24 EDT (-0400)
  Algorithmus Wanted (Message 11 to 17 of 17)
Subject: Re: Algorithmus Wanted
Date: 22 Feb 2018 14:00:01
Message: <web.5a8f1208b2b3090ca47873e10@news.povray.org>
"Norbert Kern" <nor### [at] t-onlinede> wrote:
> If you need your nice little "cells" touching each other, why not using
> equidistant splines?
> I made a quick example (source is in pbs-f).
Thanks for that. Making such multi-object equidistant spline shapes was never
easy for me; I did manage to do it once-- with much work-- for a long-ago scene.
But I lost it years ago :-(
Date: 22 Feb 2018 16:57:21
Message: <5a8f3cc1$1@news.povray.org>
Here is my new problem, and it has nothing to do with POV-Ray: the BLACK
SCREEN.
I am using an Intel i3 processor, and the Intel HD Graphics driver. That
combination is known to cause the Black Screen during graphical works.
In my case, i tried to do a simple animation with the modified scene,
but get always the Black Screen after rendering the 4th or 5th frame. I
don't think, that there is any solution to this, for my computer.
I have to ask anyone of you, if you could render 100 frames for me, if
you can forgive me that request.
Output_File_Type=n Quality=12 +KI0.0 +KF1.0 +KFI1 +KFF100
800x450
AA 0.3
// ABX  Place and orient objects along spline
http://news.povray.org/povray.general/message/%3Cttoenucoq6fcgkun57la24s9ia4ij5o573%404ax.com%3E/#%3Cttoenucoq6fcgkun57la24s9ia4ij5o573%404ax.com%3E
#version 3.7;
#declare RAD = 4;
global_settings
 #declare a_g = 1;
 assumed_gamma a_g
 max_trace_level 5
 subsurface {radiosity on samples 200,200}
 noise_generator 2
 #if(RAD > 0)
  radiosity
   pretrace_start 0.08
   pretrace_end   0.04/RAD
   count 60*RAD
   nearest_count min (20, RAD)
   error_bound 2/RAD
   low_error_factor 0.5
   recursion_limit 1
   gray_threshold 0
   minimum_reuse 0.015
   brightness 1
   adc_bailout 0.005
   normal on
   media off
   always_sample off
camera
 angle 31*image_width/image_height*0.75
 location  < 0, 0, -2 >
 look_at   < 0, 0.05, 0 >
#include "transforms.inc"
#include "shapes.inc"
#include "strings.inc"
#macro Time_To_Length_Converter (Spline, Min, Max, Accuracy)
#local Conversion = function
 spline
  #local Last   = Spline (Min);
  #local Length = 0;
  #local C      = Min;
  #while (C <= Max)
   #local C      = min (C, Max);
   #local Point  = Spline (C);
   #local Length = Length+vlength (Point-(Last*1.0003));
   #local Last   = Point;
   C , < 1, 0, 0 >*Length
   #local C      = C+Accuracy;
function (T)
  Conversion (T).x
#macro Spline_With_Linear_Movement (Spline, Min, Max, Accuracy)
 spline
  #local Last   = Spline(Min);
  #local Length = 0;
  #local C      = Min;
  #while (C <= Max)
   #local Length = Length+vlength (Point-Last);
   Length, Point+<0,0,0>
#declare fac  = 0.5;
#declare rs   = seed (2338);
#declare sca  = rand (rs);
#declare sca2 = 0.5;
#declare MySpline = spline
 cubic_spline
 -0.125,<sca*-1,0,0*sca2>+<rand (rs),0.5*rand (rs),rand (rs)>*fac,
 0,     <sca*0,0,1*sca2>+<rand (rs),0.5*rand (rs),rand (rs)>*fac,
 0.125, <sca*1,0,0*sca2>+<rand (rs),0.5*rand (rs),rand (rs)>*fac,
 0.25,  <sca*2,0,-1*sca2>+<rand (rs),0.5*rand (rs),rand (rs)>*fac,
 0.375, <sca*3,0,0*sca2>+<rand (rs),0.5*rand (rs),rand (rs)>*fac,
 0.5,   <sca*4,0,1*sca2>+<rand (rs),0.5*rand (rs),rand (rs)>*fac,
 0.625, <sca*5,0,0*sca2>+<rand (rs),0.5*rand (rs),rand (rs)>*fac
 0.75,  <sca*6,0,-1*sca2>+<rand (rs),0.5*rand (rs),rand (rs)>*fac,
 0.875, <sca*7,0,0*sca2>+<rand (rs),0.5*rand (rs),rand (rs)>*fac,
 1,     <sca*8,0,1*sca2>+<rand (rs),0.5*rand (rs),rand (rs)>*fac,
 1.125, <sca*9,0,0*sca2>+<rand (rs),0.5*rand (rs),rand (rs)>*fac
#declare MySplineLinear   = Spline_With_Linear_Movement (MySpline, 0, 1,
0.001);
#declare f_MySplineLength = Time_To_Length_Converter (MySpline, 0, 1,
0.001);
#declare MySplineLength   = f_MySplineLength (1);
#declare MyObject = union
 union
  torus
   0.425, 0.075
   rotate < 0.0, 0.0, 90.0 >
   scale < 4.5, 1.125, 1.125 >
  torus
   0.425, 0.075
   translate < -0.25, 0.0, 0.0 >
  torus
   0.425, 0.075
   translate < 0.25, 0.0, 0.0 >
  texture
   pigment
    onion
    color_map
     [ 0 color rgb 1 ]
     [ 1 color rgb < 0.075, 0.0751, 0.075 > ]
    rotate < 0, 0, 90 >
    scale 0.6
   normal
    granite 0.15
    scale 1
   finish { phong 0.1 }
 union
  cylinder { < -0.323, 0, 0 >, < -0.322, 0, 0 >, 0.425 }
  cylinder { <  0.323, 0, 0 >, <  0.322, 0, 0 >, 0.425 }
  texture
   pigment
    onion
    color_map
     [ 0      rgbt < 0.7764706, 0.8941176, 0.545098, 0.85 > ]
     [ 0.65   rgbt < 0.7764706, 0.8941176, 0.545098, 0.85 > ]
     [ 1      rgbt < 0.075,     0.0755,    0.075,    0.35 > ]
    rotate <0,0,90>
    scale 0.52
   normal
    granite 0.15
    scale 1
 sphere
  < 0, 0, 0 >, 0.315
  scale < 1, 1, 1 >
  texture
   pigment
    onion
    color_map
     [ 0      rgb < 0.5019608, 0.772549, 0.227451 >*0.9 ]
     [ 1      rgb < 0.5019608, 0.772549, 0.227451 >*1.1 ]
    rotate <0,0,90>
    scale 0.52
   normal
    granite 0.75
    scale 0.5
   finish { phong 0.1 ambient 0.5 }
 scale 0.27
 rotate z*90
#declare Step = MySplineLength*0.05;
#declare All = union
 #declare Count = 0;
 #while (Count <= MySplineLength-Step)
  object
   MyObject
   pigment { color rgb < 1, 0.3, 0.7 > }
   finish
    specular albedo 1
    metallic
    roughness 0.025
    diffuse 0.4
    brilliance 2
    reflection {0, 1 metallic}
    conserve_energy
    irid { 0.35 thickness 0.1 turbulence 0.5 }
    ambient 0
   Spline_Trans (MySplineLinear, Count, y, 0.1, 0.1)
  #declare Count = Count+Step;
 rotate x*90
 rotate < 0.0, (clock*360), 0.0 >
object
 Center_Object (All, 1)
 translate z*5
sphere
 0, 1000
 pigment
  image_map
   hdr "kitchen_probe2.hdr"
   gamma 2.2
   map_type 1
   interpolate 2
 finish {emission rgb 0.05}
 no_image
background
 color rgb < 0.1882353,  0.2705882,  0.3294118 >*0.1
Diese E-Mail wurde von AVG auf Viren geprüft.
http://www.avg.com
Date: 22 Feb 2018 18:05:00
Message: <web.5a8f4be2b2b3090c4b6ef3930@news.povray.org>
> SCREEN.
No problem,
I do it for you. But where can I upload the results?
Norbert
Date: 22 Feb 2018 18:30:00
Message: <web.5a8f5163b2b3090c4b6ef3930@news.povray.org>
> No problem,
> Norbert
Nevrmind,
I uploaded the pics to pbs-f.
Norbert
Date: 22 Feb 2018 21:39:33
Message: <5a8f7ee5$1@news.povray.org>
>> No problem,
>> Norbert
> Nevrmind,
> Norbert
Hmmm, best to send it by e-mail. Saved inside a ZIP or RAR file.
i [ AAATTT ] SvenLittkowski [ DDDOOOTTT ] name
http://www.avg.com
Date: 22 Feb 2018 21:42:52
Message: <5a8f7fac$1@news.povray.org>
Got the 2 files, big thanks!
http://www.avg.com
Date: 23 Feb 2018 00:28:35
Message: <5a8fa683$1@news.povray.org>
Okay, I was reading through the source code of this scene. This
"Spline_Trans" is new to me.
Is there any way to change the spline shape itself by random factors? At
the moment, it is like an "M", but I don't mind variations between "U"
and "M".
Each of these chains resembles a colony of Orbisiana, but based on the
water current, each chain had different angles.
I tried with changing the SEED, but all that does is to shorten or
stretch that given "M" shape. And when stretched, there are even wide
distances between each body.
One update: I made this change to the scene:
Before it was:
http://www.avg.com
