POV-Ray : Newsgroups : povray.binaries.images : Proximity Pattern testing Server Time
27 May 2026 10:21:12 EDT (-0400)
  Proximity Pattern testing (Message 51 to 56 of 56)
Subject: Re: Proximity Pattern testing
Date: 30 Sep 2017 02:55:53
Message: <59cf3ff9@news.povray.org>
On 29-9-2017 19:56, omniverse wrote:
> Before reading what Mr wrote I was only going to mention the shininess of the
> green oxidation too.
> Was thinking along the lines of specular highlight and diffuse plus brilliance,
> not reflection.
I think that is the 'shininess' of the brass /behind/ or /below/ the
oxidation showing through somehow. The texture_map would allow that as
the textures go from one label to the next.
> Anyway... your sculpture or bust is somewhat creepy. I see it as an Egyptian
> mummy emerging from a golden cocoon.
LOL I had not thought of that! I certainly was not in a Gothic mind when
I modelled it ;-)
Date: 30 Sep 2017 03:17:03
Message: <59cf44ef@news.povray.org>
On 29-9-2017 13:55, Bald Eagle wrote:
>> ... of course, this texture demands a light probe ;-)
>> Thomas
> Yes, "demand" is an understatement.
> When I rendered my first iteration of the bell, I had nothing but a light source
> and a gray background.
> It looked like featureless gravel dust blown onto old soap scum.
> "Why does this look SOOO bad?"
> So then I pasted in the hdr light probe code (and botched it) so that _HALF_ of
> my bell was light from one side and the gray was on the other.
> Direct side-by-side contrast of "visually offensive yuk" and "OMG, _WOW_" on the
> same object with the same texture and finish in the same scene.
> No number of forum posts could have convinced me more about how metals are
> _completely_ dependent on their surroundings for what they look like, and in
> further test renders, how lighting and radiosity add yet another level of
> goodness.
Absolutely! I sometimes forget about a light probe and wonder what
happens, only to jerk awake again and call myself a fool :-)
> Your model is very cool - I like the way you textured and finished the upper
> part of the model and gave the lower base a contrasting material for it rise up
> out of.
I must confess here that I love to watch and study RL sculptures. This
is something that shows up sometimes. I wanted to use that feature one
way or another.
> This proximity pattern is the way to go - I'm going to have to learn how to
> apply that if I'm going to make any meaningful progress on scenes worth looking
> at   :)
It is so incredibly easy to apply that it would be a shame to leave it
aside. It needs some tweaking to get the textures as you want them but
that is part of the fun of course. A little trick that is very helpful
with this tweaking is using a false colours map first to see where the
subsequent textures will be placed. That may look like this:
#declare My_map =
#if (False)
texture_map {
	[ 0.30 + Offset pigment {Violet} ]
	[ 0.40 + Offset pigment {NavyBlue} ]
	[ 0.50 + Offset pigment {LightBlue} ]
	[ 0.60 + Offset pigment {Red} ]
	[ 0.65 + Offset pigment {Orange} ]
	[ 0.70 + Offset pigment {Yellow} ]
	[ 0.80 + Offset pigment {Green} ]
	[ 1.00 + Offset pigment {LimeGreen} ]
#else
texture_map {
	[ 0.30 + Offset T_WhiteWashDark6 ]
	[ 0.40 + Offset T_WhiteWashDark5 ]
	[ 0.50 + Offset T_WhiteWashDark4 ]
	[ 0.60 + Offset T_WhiteWashDark3 ]
	[ 0.65 + Offset T_WhiteWashDark2 ]
	[ 0.70 + Offset T_WhiteWashDark1 ]
	[ 0.80 + Offset T_WhiteWash ]
	[ 1.00 + Offset T_WhiteWash ]
> Thanks for sharing your experiments and the progressive improvement and
> development of your scenes, as always!
You are welcome. It is something I do as much for my own benefit as for
the benefit of people interested. I always keep a series of images (and
often scene files too) from the different development stages. It allows
me to assess the direction to go and/or branch of on alternatives.
Date: 2 Oct 2017 03:22:18
Message: <59d1e92a@news.povray.org>
On 29-9-2017 13:23, Thomas de Groot wrote:
> On 29-9-2017 10:45, Mr wrote:
>> Hi, it looks like a good basis, but reflections appear slightly too
>> strong/
>> crisp/ homogenous:
>> Here are three workarounds maybe some already used:
>> *roughness in uberpov reflection block
> Yes, something to try indeed.
>> *use conserve_energy / albedo + fresnel in reflection block with an
>> explicit ior
> I used the finish statement as given by Norbert Kern in his brass
> texture. Can be improved of course ;-)
>> *use the proximity pattern as a texture map for the "finish map" trick
>> (http://www.povray.org/documentation/view/3.6.2/82/) to modulate
>> reflections and
>> make less of them where metal is corroded/oxidized
> As far as I know, it does that already.
There were more things no working correctly.
- I put in a proper radiosity block, which was lacking;
- corrected the light probe illumination;
- used roughness on the reflections of the brass
I shall stop here for now.
Download 'ep_proximity_test.jpg' (93 KB)
Preview of image 'ep_proximity_test.jpg'
Date: 2 Oct 2017 03:36:09
Message: <59d1ec69$1@news.povray.org>
Not bad for a doodle. :-)
Regards
Date: 2 Oct 2017 07:04:27
Message: <59d21d3b$1@news.povray.org>
Indeed, isn't it? ;-)
Date: 2 Oct 2017 08:11:34
Message: <59d22cf6$1@news.povray.org>
agreed ... love it when that happens
