POV-Ray : Newsgroups : povray.binaries.images : QUESTION: Bump not showing? Server Time
1 Apr 2026 10:58:23 EDT (-0400)
  QUESTION: Bump not showing? (Message 67 to 76 of 91)
Subject: Re: QUESTION: Bump not showing?
Date: 28 Jul 2017 02:46:02
Message: <597addaa$1@news.povray.org>
On 27-7-2017 14:16, Stephen wrote:
> On 7/27/2017 12:19 PM, Thomas de Groot wrote:
>> On 27-7-2017 11:34, Stephen wrote:
>>> Has anyone collect Sven's code? I don't fancy going through the thread
>>> to piece it all together. And I've not been following it closely.
>> This is the latest, with my amendments. See also the attached images I
>> used.
> Thanks Thomas.
> The results were as expected. The shadows showing.
> But is this expected? It is the top of the balloon.
> [Drat! I can't put them inline.]
Well, the bump_map is polar-oriented, so I expect the creases to show up
on the sides too while the top is fairly smooth (according to the map).
> Using Sven's original code. I imported it into Bishop3D correcting the
> errors one by one. Using the image maps you supplied. The second image
> is directly from Sven's code.
> What concerns me is:
>    image_map { png "H:\My Documents\My Pictures\POV-Ray\Space - Launcher
> - Balloon - Type 001 - Moon Runnings - Balloon Texture.png" }
> Are those spaces and dashes part of the file name?
A question for Sven, but I think they are.
Date: 28 Jul 2017 05:16:05
Message: <597b00d5@news.povray.org>
>>> used.
>> Thanks Thomas.
Sorry, I meant the cap on the top that was missed in the difference.
Indeed it is. Although they look suspiciously, a bit like file paths to me.
Like everyone else, I see no reason for it not to work on Sven's machine.
Regards
Date: 28 Jul 2017 20:09:39
Message: <597bd243$1@news.povray.org>
On 27.07.2017 03:10, Stephen wrote:
> On 7/27/2017 7:30 AM, omniverse wrote:
>> Here we are approaching 60 messages in this thread, must be an answer
>> to the
>> mystery... thing is, no one else has had the same thing happen yet,
>> except for
>> finding trouble with low contrast, dark image/bump maps.
> Do you think that it is possible that there is a mix up with duplicate
> image files being referenced?
> Or finding the wrong file in a long Library_Path?
Not sure, but I would tend to say NO. I have only that one bump image.   :-
Diese E-Mail wurde von AVG auf Viren geprüft.
http://www.avg.com
Date: 28 Jul 2017 20:11:34
Message: <597bd2b6$1@news.povray.org>
On 27.07.2017 03:41, omniverse wrote:
> Await hearing which POV-Ray version, or if custom compiled. I could have
missed
> that info so maybe I will scan over this thread again in the meantime.
POV-Ray v3.7.0.msvc10.win64
http://www.avg.com
Date: 28 Jul 2017 20:12:42
Message: <597bd2fa@news.povray.org>
#version 3.7;
#include "kolors.inc"
#include "finish.inc"
#include "textures.inc"
#declare MyRadiosity = off;
//#declare MyBackground = "SL_Space_Scene_003"; // Wormhole /
SL_Space_Scene_003 /
global_settings
 #if(MyRadiosity)
  radiosity
   media on
   pretrace_start 0.08
   pretrace_end   0.001
   count 400
   error_bound 0.75
   recursion_limit 1
   normal on
 assumed_gamma 1.0
 subsurface        {}
 adc_bailout       0.0039
 ambient_light     rgb < 0.000, 0.000, 0.000 >
 assumed_gamma     1.000
 irid_wavelength   rgb < 0.250, 0.180, 0.140 >
 max_trace_level   5
 number_of_waves   10
 noise_generator   3
 charset           ascii
#declare LightDiameter =     10000.0;
#declare LightDistanceX =  -500000.0; // X = Left - Right
#declare LightDistanceY =  1000000.0; // Y = Up - Down
#declare LightDistanceZ =  -100000.0; // Z = Front - Back
#declare LightRotate =          36.0;
#declare MyLight =             0.125;
camera
 location < -000.0, 400.0, -500.0 >
 look_at < 0.0, -200.0, 0.0 >
 right 1.77*x
light_source
 < 2500.0, 2500.0, 500.0 > //< 2500.0, 2500.0, 5000.0 >
 rgb < 0.72265625, 0.8046875, 0.80859375 > *1.5 // bright!?
 area_light x*100,z*100,5,5 circular orient
 area_illumination
light_source
 < -50.0, 50.0, 0.0 >
 rgb < 0.3, 0.4, 0.8 > *1.1
#declare MyLight = light_source
 < -1000.0, 1000.0, 1000.0 >
 rgb < 0.72265625, 0.8046875, 0.80859375 > *0.25
// spotlight
// point_at < 0.0, 25.0, 100.0 >
// falloff 100.0
// radius 10.0
// fade_distance 50.0
// fade_power 4
union
 object { MyLight rotate < 0.0, 000.0, 0.0 > }
 object { MyLight rotate < 0.0, 036.0, 0.0 > }
 object { MyLight rotate < 0.0, 072.0, 0.0 > }
 object { MyLight rotate < 0.0, 108.0, 0.0 > }
 object { MyLight rotate < 0.0, 144.0, 0.0 > }
 object { MyLight rotate < 0.0, 180.0, 0.0 > }
 object { MyLight rotate < 0.0, 216.0, 0.0 > }
 object { MyLight rotate < 0.0, 252.0, 0.0 > }
 object { MyLight rotate < 0.0, 288.0, 0.0 > }
 object { MyLight rotate < 0.0, 324.0, 0.0 > }
 translate < -1000.0, 0000.0, -1000.0 >
#declare MyRadius = 200.0;
#declare PositiveBump = normal
 bump_map
  png "H:\My Documents\My Pictures\POV-Ray\Space - Launcher - Balloon -
Type 001 - Moon Runnings - Balloon BumpMap.png"
 translate -0.5
 rotate < 90.0, 0.0, 0.0 >
 scale MyRadius*2
 bump_size 0.02
#declare NegativeBump = normal
 bump_map { png "H:\My Documents\My Pictures\POV-Ray\Space - Launcher -
Balloon - Type 001 - Moon Runnings - Balloon BumpMap.png" map_type 0
interpolate 2 }
 translate -0.5
 scale -MyRadius*2
 bump_size 0.04
#declare MyOuterBalloonFinish = finish
 brilliance   1.50
 phong albedo 0.05
 metallic     0.00
 ambient      0.00
 emission     0.00
 reflection   0.50
 crand        0.10
#declare MyInnerBalloonFinish = finish
 brilliance   1.50
 phong albedo 0.05
 metallic     0.00
 ambient      0.00
 emission     0.00
 reflection   0.50
#declare MyOuterBalloonTexture = texture
 pigment
  image_map
   gamma 1
   map_type 0
   interpolate 2
   once
  translate -0.5
  scale MyRadius*2
 normal
  gradient y
  normal_map
   [ 0.175 PositiveBump ]
   [ 0.175 NegativeBump ]
  scale < 1.0, 1.5*MyRadius, 1.0 >
// finish { MyOuterBalloonFinish }
#declare MyInnerBalloonTexture = texture
 pigment { color rgb < 0.7686275,  0.7607843,  0.7333333 > }
 normal
  gradient y
  normal_map
  scale <1,1.5*MyRadius,1>
 finish { MyInnerBalloonFinish }
#declare UpperBalloonShape = torus     // Balloon Radius: 175 m /
Launcher Radius: 10 m
 95.0, 105.0
 scale < 1.0, 0.5, 1.0 >
#declare LowerBalloonShape = difference
 sphere { < 0.0, 0.0, 0.0 > MyRadius }
 cylinder { < 0.0, 0.0, 0.0 > < 0.0, 175.001, 0.0 > MyRadius+0.001 }
 scale < 1.0, 1.5, 1.0 >
#declare MyBalloonHullOutside = union
 object { UpperBalloonShape }
 object { LowerBalloonShape }
 texture { MyOuterBalloonTexture }
#declare MyBalloonHull = difference
 object { MyBalloonHullOutside hollow }
 cylinder  // Launcher Openings
  < 0.0, -((MyRadius*1.5)+0.001), 0.0 > < 0.0, (MyRadius+0.001), 0.0 > 3.5
  texture { MyInnerBalloonTexture }
#declare Launcher = difference
 union
  #declare MyLength = 10.0;
  #declare MyHeight = 0.0;
  #declare MyTop = 35.0;
  cylinder { < 0.0, -((MyRadius*1.5)+30.0), 0.0 > < 0.0, MyTop, 0.0 >
3.5 }
  box { < MyLength, -MyHeight, -0.1 > < -MyLength, MyTop, 0.1 > rotate <
0.0, 000.0, 0.0 > }
0.0, 045.0, 0.0 > }
0.0, 090.0, 0.0 > }
0.0, 135.0, 0.0 > }
0.0, 180.0, 0.0 > }
0.0, 225.0, 0.0 > }
0.0, 270.0, 0.0 > }
0.0, 315.0, 0.0 > }
 cylinder { < 0.0, -((MyRadius*1.5)+30.001), 0.0 > < 0.0, MyTop+0.001,
0.0 > 3.3 }
 pigment { color rgb 1.0 }
#declare DoublePositionLight = union
 union
  cylinder { < 0.0, 0.0,  2.5 > < 10.0, 0.0,  2.5 > 0.20 }
  cylinder { < 0.0, 0.0, -2.5 > < 10.0, 0.0, -2.5 > 0.20 }
  pigment { color rgb < 0.05, 0.05, 0.05 > }
 union
  sphere { < 10.0, 0.0, 2.5 > 0.35 }
  sphere { < 10.0, 0.0, -2.5 > 0.35 }
  pigment { color rgbf < 1.0, 0.0, 0.0, 0.5 > }
  finish { ambient rgb < 0.3, 0.1, 0.1 > }
 union
  light_source
   < 10.0, 0.0, 2.5 >
   rgb < 0.7, 0.0, 0.0 > *10.0
   fade_distance 50.0
   fade_power 4
  light_source
   < 10.0, 0.0, -2.5 >
   rgb < 0.7, 0.0, 0.0 > *1.0
   fade_distance 50.0
   fade_power 4
#declare PositionLights = union
 #declare MyDistance = MyRadius-0.1;
 object { DoublePositionLight translate < MyDistance, 0.0, 0.0 > rotate
< 0.0, 045.0, 0.0 > }
< 0.0, 090.0, 0.0 > }
< 0.0, 135.0, 0.0 > }
< 0.0, 225.0, 0.0 > }
< 0.0, 270.0, 0.0 > }
< 0.0, 315.0, 0.0 > }
union
 object { MyBalloonHull }
 object { Launcher }
 object { PositionLights }
background { rgb < 0.02392157,  0.03490196,  0.04627451 > }
http://www.avg.com
Download 'space - launcher - balloon - type 001 - moon runnings.png' (103 KB) Download 'space - launcher - balloon - type 001 - moon runnings - balloon bumpmap.png' (201 KB)
Preview of image 'space - launcher - balloon - type 001 - moon runnings.png'
Preview of image 'space - launcher - balloon - type 001 - moon runnings - balloon bumpmap.png'
Date: 28 Jul 2017 20:18:26
Message: <597bd452@news.povray.org>
>> used.
> Thanks Thomas.
Yes, they are part of the file names. But they cause no error message,
as POV-Ray gives them straight to the Windows system, and Windows is
handling the file management.
Please use my balloon texture for the outside, and let us know, if you
still get bumps.
http://www.avg.com
Download 'space - launcher - balloon - type 001 - moon runnings - balloon texture.png' (882 KB)
Preview of image 'space - launcher - balloon - type 001 - moon runnings - balloon texture.png'
Date: 28 Jul 2017 20:19:15
Message: <597bd483$1@news.povray.org>
>>> used.
>> Thanks Thomas.
Yes, they are. No cause of any error, as Windows handles the file
management.
http://www.avg.com
Date: 28 Jul 2017 20:33:10
Message: <597bd7c6$1@news.povray.org>
On 27.07.2017 05:14, clipka wrote:
> Am 27.07.2017 um 05:24 schrieb Sven Littkowski:
>>> At the moment, all seems to point at the pigment definition as the
>>> culprit, as that's the only relevant thing we've always changed. You
>>> should at least /try/ it with a plain pigment, to either confirm or
>>> refute this theory.
>>> If you can confirm it, we know that's what we have to examine further;
>>> in that case you'll probably want to post the image map at last, so tha
t
>>> we can see what might be so special about it.
>>> Otherwise we can be sure that it's a red herring, and that we have to
>>> dig someplace else.
>> Nope. Here's a one-color pigment. :-(
> Okay, now this leaves surprisingly few possible explanations. I can only
> come up with the following:
> - You might be using a rare and buggy version of POV-Ray.
> To check this, I recommend you post the exact POV-Ray version number
> (and let us know which operating system you're using).
> - You might be using a different scene file and/or bump map image file
> than those you posted.
> - There might be a relevant line break introduced in your post of the
> scene file that we've been overlooking.
> To check these two, I recommend you temporarily rename your scene and
> auxiliary files (image file and bump map), then try to re-create the
> scene from your own postings and render it. You'll get parse errors,
> make sure to fix only those actually reported.
> - You might be using low-quality settings (`+q7` or lower).
> To check this, I recommend you post the message output of the render,
> and/or run the render with `+giFOO.INI` and post the generated FOO.INI he
re.
Clipka, you shot the bird!
Okay, everyone: I herewith declare myself as a big fool!
I use POV-Ray for soooo many years, since around 1990 or so, and can you
believe it I just oversaw all the time of posting here, that I used:
QUALITY = 6
And did not even think about checking for the Q setting!!!!!
SHAME ON ME! I wasted so much of your all valuable time! But at least,
one more time the POV-Ray community has proven its great pioneer-alike
spirit! I owe you all my big thanks!
http://www.avg.com
Date: 28 Jul 2017 20:34:31
Message: <597bd817@news.povray.org>
>>> refute this theory.
t
>>> dig someplace else.
re.
http://www.avg.com
Download 'space - launcher - balloon - type 001 - moon runnings.png' (210 KB)
Date: 28 Jul 2017 20:37:22
Message: <597bd8c2@news.povray.org>
QUALITY = 6
http://www.avg.com
