On 7/25/2017 8:11 AM, Stephen wrote:
>> On 7/25/2017 7:06 AM, Sven Littkowski wrote:
>>> Thanks. Meanwhile, I actually applied many changes, with the effect that
>>> scene parsing ends with an error. I tried to incorporate all advises,
>>> but still miss something.
>> Do the changes one at a time and test if they work before going on to
>> the next. Otherwise it is like trying to find two matching ends in a
>> plate of spaghetti. :)
> Well, too late now. :-)
It should never be too late. Any sort of version control is better than
none.
I assume you pressed the wrong button
BTW Put more tobacco in them. ;)
Regards
On 7/25/2017 9:44 AM, omniverse wrote:
> I like that description, and spaghetti.
I've learned my lessons the hard way.
And it is Tuesday, traditionally pasta night.
> I didn't get any errors after making sure all lines of SDL are commented, mostly
> the several
/* That is why
I put my comments tile this. Even if it is only one line. */
Not that I do a lot of coding but I modify machine written SDL a lot.
Regards
Yoiks! Forgot to say what I was going to tell about before starting to write
that last reply.
I blame Stephen for making me lose my train of thought with that perfect
metaphor about finding errors. LOL
Sooo... bump_size 0.1, apparently that's too much. I tried 0.01 instead and
think it looks better. I realized the scale in the normal statement being
MyRadius*2 is probably the equivalent of bump_size 4 even if starting with 0.01.
Don't want to go into all that here but I recall many discussions long ago about
attempts to keep things such as normal and media from scaling up or down with
object sizes after placing the texture. Or just to be aware of the possible
ramifications when scaling.
That aside, please be sure to read my previous reply about the other things.
commented, mostly
> the several
/* That is why
I put my comments like this. Even if it is only one line. */
Regards
Hi, did you all see the latest code?
Diese E-Mail wurde von AVG auf Viren geprüft.
http://www.avg.com
ite
> that last reply.
nd
h 0.01.
o about
with
le
gs.
> Bob
Ho, can you publish here the entire scene code of your version of the
scene? That would help me better to see the differences and to understand.
I admit, another problem I have, is based on the English language. Yes,
i understand it well, I even live in an English-speaking country now.
But I am not natively English-speaking. Reading all that English here,
causes a concentration problem for me, and I am always missing a lot of
things, not capturing them somehow. That is why I want to ask you all
here, to be patient with me. :-)
http://www.avg.com
Jamaican English is an ittsy bitsy bit different from Standard English.
In case you hadn't noticed.
Regards
Hope this doesn't suffer in translation. ;)
There's some dark splotches on the lower left side, maybe reflection? I didn't
check, wanted to go ahead and post this.
#version 3.7;
#include "kolors.inc"
#include "finish.inc"
#include "textures.inc"
#declare MyRadiosity = on; // fast enough, but faster without
/*#declare MyBackground = "SL_Space_Scene_003"; // Wormhole /SL_Space_Scene_003
global_settings
#if(MyRadiosity)
radiosity
media on
pretrace_start 0.08
pretrace_end 0.02
count 100
error_bound 0.75
recursion_limit 1
normal on
subsurface {}
adc_bailout 0.0039
ambient_light rgb < 0.000, 0.000, 0.000 >
assumed_gamma 1.000
irid_wavelength rgb < 0.250, 0.180, 0.140 >
max_trace_level 5
number_of_waves 10
noise_generator 3
charset ascii
#declare LightDiameter = 10000.0;
#declare LightDistanceX = -500000.0; // X = Left - Right
#declare LightDistanceY = 1000000.0; // Y = Up - Down
#declare LightDistanceZ = -100000.0; // Z = Front - Back
#declare LightRotate = 36.0;
#declare MyLight = 0.125;
camera
location < -000.0, 400.0/2, -500.0 > /* < -000.0, 400.0, -500.0 > */
look_at < 0.0, -200.0, 0.0 >/2 /* < 0.0, -200.0, 0.0 > */
right 1.77*x
light_source
< 2500.0, 2500.0, 500.0 > //< 2500.0, 2500.0, 5000.0 >
rgb < 0.72265625, 0.8046875, 0.80859375 > *1.5 // bright!?
area_light x*100,z*100,5,5 circular orient
area_illumination
light_source
< -50.0, 50.0, 0.0 >
rgb < 0.3, 0.4, 0.8 > *1.1
#declare MyLight = light_source
< -1000.0, 1000.0, 1000.0 >
rgb < 0.72265625, 0.8046875, 0.80859375 > *0.25
// spotlight
// point_at < 0.0, 25.0, 100.0 >
// falloff 100.0
// radius 10.0
// fade_distance 50.0
// fade_power 4
union
object { MyLight rotate < 0.0, 000.0, 0.0 > }
object { MyLight rotate < 0.0, 036.0, 0.0 > }
object { MyLight rotate < 0.0, 072.0, 0.0 > }
object { MyLight rotate < 0.0, 108.0, 0.0 > }
object { MyLight rotate < 0.0, 144.0, 0.0 > }
object { MyLight rotate < 0.0, 180.0, 0.0 > }
object { MyLight rotate < 0.0, 216.0, 0.0 > }
object { MyLight rotate < 0.0, 252.0, 0.0 > }
object { MyLight rotate < 0.0, 288.0, 0.0 > }
object { MyLight rotate < 0.0, 324.0, 0.0 > }
translate < -1000.0, 0000.0, -1000.0 >
// simulate Earth below
plane {y,-9999 pigment {rgb <0.4,0.7,1>}}
#declare MyRadius = 200.0;
#declare PositiveBump = normal
bump_map
{ // use your file name
png "balloon2bump"
map_type 0 interpolate 2 }
translate -0.5
rotate < 90.0, 0.0, 0.0 >
scale MyRadius*2 // 200*2=400, multiply by bump_size
bump_size 0.02 // this equates to 8 after scale
#declare NegativeBump = normal // invert surface normal
bump_map
png "balloon2bump"
translate -0.5
scale -MyRadius*2 // 200*2=400, multiply by bump_size
bump_size 0.04 // this equates to 16 after scale
#declare MyOuterBalloonFinish = finish
reflection 0.1 // I'm guessing here
//crand 0.10 // grainy near shadows! Is it needed??
#declare MyInnerBalloonFinish = finish
brilliance 1.50
phong albedo 0.05
metallic 0.00
ambient 0.00
emission 0.00
reflection 0.50 // this much needed? or not?
#declare MyOuterBalloonTexture = texture
pigment
image_map
png "balloon2bump"
gamma 1
map_type 0
interpolate 2
once
transmit all 0.4 /* added to make partially transparent, change or remove? */
translate -0.5
scale MyRadius*2
normal
gradient y
normal_map
{ /* index number is based on balloon size, upper part height */
[ 0.2625 PositiveBump] // top
[ 0.2625 NegativeBump] // bottom
scale <1,1.5*MyRadius,1> // set to balloon height
finish { MyOuterBalloonFinish }
#declare MyInnerBalloonTexture = texture
pigment { color rgb < 0.7686275, 0.7607843, 0.7333333 >
transmit 0.4 /* added to make partially transparent, change or remove? */
normal
gradient y
normal_map
{ /* set index values to 0.175 if torus scale <1,0.5,1>, same above */
finish { MyInnerBalloonFinish }
#declare UpperBalloonShape = torus
/* Balloon Radius: 175 m /Launcher Radius: 10 m */
95.0, 105.0
scale < 1.0, 0.75, 1.0 >
/* if 0.5*y, use normal_map 0.175 not 0.2625 (0.175*1.5, 0.5*1.5=0.75) */
} /* I changed that to get tall fat appearance, not required
but must change everything back again if not used this way */
#declare LowerBalloonShape = difference
sphere { < 0.0, 0.0, 0.0 >, MyRadius }
cylinder { < 0.0, 0.0, 0.0 >, < 0.0, /*175.001*/MyRadius+0.001, 0.0 >,
MyRadius+0.001 }
scale < 1.0, 1.5, 1.0 >
#declare MyBalloonHullOutside = merge // union causes artefacts??
object { UpperBalloonShape }
object { LowerBalloonShape }
texture { MyOuterBalloonTexture }
#declare MyBalloonHull = difference
object { MyBalloonHullOutside }
object
scale 0.99999 // causing artefacts??
texture { MyInnerBalloonTexture }
cylinder // Launcher Openings
< 0.0, -((MyRadius*1.5)+0.001), 0.0 >, < 0.0, (MyRadius+0.001), 0.0 >, 3.5
// plane {z,0} // only to see inside
#declare Launcher = difference
union
#declare MyLength = 10.0;
#declare MyHeight = 0.0;
#declare MyTop = 35.0;
cylinder {
< 0.0, -((MyRadius*1.5)+30.0), 0.0 >,
< 0.0, MyTop, 0.0 >, 3.5 }
box { < MyLength, -MyHeight, -0.1 >, < -MyLength, MyTop, 0.1 >
rotate <0.0, 000.0, 0.0 > }
rotate <0.0, 045.0, 0.0 > }
rotate <0.0, 090.0, 0.0 > }
rotate <0.0, 135.0, 0.0 > }
rotate <0.0, 180.0, 0.0 > }
rotate <0.0, 225.0, 0.0 > }
rotate <0.0, 270.0, 0.0 > }
rotate <0.0, 315.0, 0.0 > }
cylinder {
< 0.0, -((MyRadius*1.5)+30.001), 0.0 >,
< 0.0, MyTop+0.001, 0.0 >, 3.3 }
pigment { color rgb 1.0 }
#declare DoublePositionLight = union
union
cylinder { < 0.0, 0.0, 2.5 > < 10.0, 0.0, 2.5 > 0.20 }
cylinder { < 0.0, 0.0, -2.5 > < 10.0, 0.0, -2.5 > 0.20 }
pigment { color rgb < 0.05, 0.05, 0.05 > }
union
sphere { < 10.0, 0.0, 2.5 > 0.35 }
sphere { < 10.0, 0.0, -2.5 > 0.35 }
pigment { color rgbf < 1.0, 0.0, 0.0, 0.5 > }
finish { ambient rgb < 0.3, 0.1, 0.1 > }
union
light_source
< 10.0, 0.0, 2.5 >
rgb < 0.7, 0.0, 0.0 > *10.0
fade_distance 50.0
fade_power 4
light_source
< 10.0, 0.0, -2.5 >
rgb < 0.7, 0.0, 0.0 > *1.0
fade_distance 50.0
fade_power 4
#declare PositionLights = union
#declare MyDistance = MyRadius-0.1;
object { DoublePositionLight translate < MyDistance, 0.0, 0.0 >
rotate < 0.0, 045.0, 0.0 > }
rotate < 0.0, 090.0, 0.0 > }
rotate < 0.0, 135.0, 0.0 > }
rotate < 0.0, 225.0, 0.0 > }
rotate < 0.0, 270.0, 0.0 > }
rotate < 0.0, 315.0, 0.0 > }
union
object { MyBalloonHull }
object { Launcher }
// object { PositionLights } // slow, fast if commented out
background { rgb < 0.02392157, 0.03490196, 0.04627451 > }
But how different is German to English? :-)
http://www.avg.com
How long have you lived there?
And English is a Germanic language.
https://en.wikipedia.org/wiki/English_language
https://de.wikipedia.org/wiki/Englische_Sprache
Regards
On 25.07.2017 01:06, clipka wrote:
> Am 25.07.2017 um 01:41 schrieb Sven Littkowski:
>> Thanks a lot for your assistance, so far. But I admit, I am now irritate
d.
>> Did you see the bump image I posted inside the other group (GENERAL)
>> with the same topic? Someone there told me to reduce the image size,
>> make it 16bit, and increase the contrast between dark and bright areas
>> there. I did that all. Still - no success.
> I'm not sure what you are doing there. With the new bump map and using
> the scene from your original post, the attached image is what I get
> (after repairing broken comments and replacing the image_map with a
> plain white pigment).
> That looks like bumps to me. (Excessively strong ones, actually; try
> `bump_size 10` or lower.)
> You still have some residual issues:
> - Contrary to my recommendation, you apparently did not re-generate the
> image with higher contrast and bit depth, but rather just converted the
> old image and blurred it a bit. This still leaves you with artefacts
> from the original color banding.
> - You are using `gamma 1.8` in a bump map. This indicates to me that
> /something/ regarding gamma is not quite right: Either you didn't
> understand what you were doing, or your bump map uses a poor encoding
> scheme that gives you more precision in black areas than it does in
> white areas. (To tell which of the two is the case, I'd have to know
> more about how you created the bump map in the first place.)
> - Your radiosity block does not contain a `normal on` statement. As a
> consequence, if you turn on radiosity, you will not see any bumps in
> areas that are lit only indirectly.
It seems, with my graphic program I can work only with one layer, if it
comes to 16bit. Cannot create any additional layers when in 16bit, and I
would need, in order to crate a similar pattern.
I use Photoshop v7.0. That is the reason, why I could not create the
image you suggested (and I agree on). :-(
Will create a new bump image, but it will be again 8bit. But I create it
as a smaller version. Hoping for the best.
http://www.avg.com
Latest Scene Code, Latest Bump, Latest Result
(still no bumps)
#version 3.7;
#declare MyRadiosity = off;
//#declare MyBackground = "SL_Space_Scene_003"; // Wormhole /
SL_Space_Scene_003 /
global_settings
#if(MyRadiosity)
radiosity
media on
pretrace_start 0.08
pretrace_end 0.001
count 400
error_bound 0.75
recursion_limit 1
normal on
subsurface {}
adc_bailout 0.0039
assumed_gamma 1.000
max_trace_level 5
number_of_waves 10
noise_generator 3
charset ascii
camera
location < -000.0, 400.0, -500.0 >
right 1.77*x
light_source
area_illumination
light_source
// spotlight
// falloff 100.0
// radius 10.0
// fade_power 4
union
bump_map
png "H:\My Documents\My Pictures\POV-Ray\Space - Launcher - Balloon -
Type 001 - Moon Runnings - Balloon BumpMap.png"
translate -0.5
scale MyRadius*2
bump_size 0.02
bump_map { png "H:\My Documents\My Pictures\POV-Ray\Space - Launcher -
Balloon - Type 001 - Moon Runnings - Balloon BumpMap.png" map_type 0
interpolate 2 }
translate -0.5
scale -MyRadius*2
bump_size 0.04
// reflection 0.00
crand 0.10
brilliance 1.50
phong albedo 0.05
metallic 0.00
ambient 0.00
emission 0.00
reflection 0.50
pigment
image_map
Type 001 - Moon Runnings - Balloon Texture.png"
gamma 1
map_type 0
interpolate 2
once
translate -0.5
scale MyRadius*2
normal
gradient y
normal_map
[ 0.175 PositiveBump ]
[ 0.175 NegativeBump ]
scale < 1.0, 1.5*MyRadius, 1.0 >
pigment { color rgb < 0.7686275, 0.7607843, 0.7333333 > }
normal
gradient y
normal_map
#declare UpperBalloonShape = torus // Balloon Radius: 175 m /
95.0, 105.0
scale < 1.0, 0.5, 1.0 >
sphere { < 0.0, 0.0, 0.0 > MyRadius }
cylinder { < 0.0, 0.0, 0.0 > < 0.0, 175.001, 0.0 > MyRadius+0.001 }
#declare MyBalloonHullOutside = union
object { MyBalloonHullOutside hollow }
< 0.0, -((MyRadius*1.5)+0.001), 0.0 > < 0.0, (MyRadius+0.001), 0.0 > 3.5
union
cylinder { < 0.0, -((MyRadius*1.5)+30.0), 0.0 > < 0.0, MyTop, 0.0 >
3.5 }
box { < MyLength, -MyHeight, -0.1 > < -MyLength, MyTop, 0.1 > rotate <
0.0, 000.0, 0.0 > }
0.0, 045.0, 0.0 > }
0.0, 090.0, 0.0 > }
0.0, 135.0, 0.0 > }
0.0, 180.0, 0.0 > }
0.0, 225.0, 0.0 > }
0.0, 270.0, 0.0 > }
0.0, 315.0, 0.0 > }
cylinder { < 0.0, -((MyRadius*1.5)+30.001), 0.0 > < 0.0, MyTop+0.001,
0.0 > 3.3 }
union
union
union
light_source
< 10.0, 0.0, 2.5 >
fade_distance 50.0
fade_power 4
light_source
< 10.0, 0.0, -2.5 >
fade_distance 50.0
fade_power 4
object { DoublePositionLight translate < MyDistance, 0.0, 0.0 > rotate
union
object { Launcher }
http://www.avg.com
Download 'space - launcher - balloon - type 001 - moon runnings - balloon bumpmap.png' (201 KB)
Download 'space - launcher - balloon - type 001 - moon runnings.png' (171 KB)
Preview of image 'space - launcher - balloon - type 001 - moon runnings - balloon bumpmap.png'
Preview of image 'space - launcher - balloon - type 001 - moon runnings.png'
Clipka, I created a new, more contrasting bump image. I dream to get
something like your result. My Photoshop 7 does not allow to work with
multiple layers if the mode is 16bit, thus I had to create it again
(sadly) in 8bit.
Please have a look at my latest scene code, I also tried to incorporate
the changed scene code of Omniverse, too:
#version 3.7;
global_settings
#if(MyRadiosity)
radiosity
media on
pretrace_start 0.08
pretrace_end 0.001
count 400
error_bound 0.75
recursion_limit 1
normal on
subsurface {}
adc_bailout 0.0039
assumed_gamma 1.000
max_trace_level 5
number_of_waves 10
noise_generator 3
charset ascii
camera
right 1.77*x
light_source
area_illumination
light_source
// spotlight
// falloff 100.0
// radius 10.0
// fade_power 4
union
bump_map
translate -0.5
scale MyRadius*2
bump_size 0.02
interpolate 2 }
translate -0.5
scale -MyRadius*2
bump_size 0.04
// reflection 0.00
crand 0.10
brilliance 1.50
phong albedo 0.05
metallic 0.00
ambient 0.00
emission 0.00
reflection 0.50
pigment
image_map
gamma 1
map_type 0
interpolate 2
once
translate -0.5
scale MyRadius*2
normal
gradient y
normal_map
normal
gradient y
normal_map
95.0, 105.0
union
3.5 }
0.0, 000.0, 0.0 > }
0.0, 045.0, 0.0 > }
0.0, 090.0, 0.0 > }
0.0, 135.0, 0.0 > }
0.0, 180.0, 0.0 > }
0.0, 225.0, 0.0 > }
0.0, 270.0, 0.0 > }
0.0, 315.0, 0.0 > }
0.0 > 3.3 }
union
union
union
light_source
< 10.0, 0.0, 2.5 >
fade_distance 50.0
fade_power 4
light_source
< 10.0, 0.0, -2.5 >
fade_distance 50.0
fade_power 4
union
object { Launcher }
http://www.avg.com
Well, quite some time. Speaking English is the easiest for me. Listening
to English takes on a bit more concentration, but I can manage. But
reading in English takes on the most concentration, if I read too much,
i lose the contents and nothing reaches my understanding anymore, after
some time. That is how i would try to describe it.
English and German are not really similar, even if the modern English
has some of its roots in the Germanic language of the Saxons. Some parts
are Celtic, some parts are French, and some are even Latin (beside
French a 2nd Romanic language). But that is not so important. Important
is, how similar languages are. Not enough for me, to avoid this problem. :-
http://www.avg.com
All I can say is I can render your exact scene using your bump map file and see
how it should be.
However, there is trouble with the image_map. You say a "texture" name for that
one, yet didn't give another, so I used the same bump_map file for the texture
too.
I can see the shadowing on the surface, but the contrast is now so much I lose
sight of it in the darkest areas.
What I tried, again, is remove that image_map from pigment statement and
replaced with a simple:
color rgb 1 // plain white
Rendering posted.
And I was confused at first about the rounded shadow seen on the top left side
of balloon.
That was once again the 'parachute' piece, you don't actually see it until
moving camera farther away; I got rid of it before by replacing 175.001 with
MyRadius+0.001 in the SDL part:
cylinder {
< 0.0, 0.0, 0.0 >,
< 0.0, MyRadius+001, 0.0 >, MyRadius+0.001 } // instead of y*175.001
nd see
> how it should be.
r that
xture
> too.
lose
> Rendering posted.
side
> of balloon.
l
ith
> cylinder {
> < 0.0, 0.0, 0.0 >,
I made the balloon HOLLOW (instead of a difference). And removed the
TRANSMIT keyword. Looks better. But not getting any bumps. Made also the
top a bit flatter again 8as it was before).
Are you able to reproduce anything that looks like Clipka's balloon image?
Complete Scene Code:
#version 3.7;
global_settings
#if(MyRadiosity)
radiosity
media on
pretrace_start 0.08
pretrace_end 0.001
count 400
error_bound 0.75
recursion_limit 1
normal on
subsurface {}
adc_bailout 0.0039
assumed_gamma 1.000
max_trace_level 5
number_of_waves 10
noise_generator 3
charset ascii
camera
right 1.77*x
light_source
area_illumination
light_source
// spotlight
// falloff 100.0
// radius 10.0
// fade_power 4
union
bump_map
translate -0.5
scale MyRadius*2
bump_size 0.02
interpolate 2 }
translate -0.5
scale -MyRadius*2
bump_size 0.04
// reflection 0.00
crand 0.10
brilliance 1.50
phong albedo 0.05
metallic 0.00
ambient 0.00
emission 0.00
reflection 0.50
pigment
image_map
gamma 1
map_type 0
interpolate 2
once
translate -0.5
scale MyRadius*2
normal
gradient y
normal_map
normal
gradient y
normal_map
95.0, 105.0
union
3.5 }
0.0, 000.0, 0.0 > }
0.0, 045.0, 0.0 > }
0.0, 090.0, 0.0 > }
0.0, 135.0, 0.0 > }
0.0, 180.0, 0.0 > }
0.0, 225.0, 0.0 > }
0.0, 270.0, 0.0 > }
0.0, 315.0, 0.0 > }
0.0 > 3.3 }
union
union
union
light_source
< 10.0, 0.0, 2.5 >
fade_distance 50.0
fade_power 4
light_source
< 10.0, 0.0, -2.5 >
fade_distance 50.0
fade_power 4
union
object { Launcher }
http://www.avg.com
> (still no bumps)
I didn't change anything to your code and used the bump map provided,
and this is what I get: bumps *are* visible!
Download 'sl_balloon.png' (87 KB)
Preview of image 'sl_balloon.png'
>> (still no bumps)
Not entirely true ;-)
I added:
global_settings {
assumed_gamma 1.0
which was demanded by your kolors.inc (and for obvious reasons when
using version 3.7) and I provided a uniform red colour texture for the
balloon (as an image_map).
> > (still no bumps)
> Thomas
This whole thing really reminds me of:
http://1.bp.blogspot.com/-IFTXBJQc0UU/VIHkNM5jKkI/AAAAAAAA2F8/yyWnsQBHmO4/s1600/gah1.jpg
Since it's from the 80's, maybe Yadgar will join this thread ;) :D
>>> (still no bumps)
>> Thomas
Close Encounters of the Third(?) Kind? :-)
>>>> (still no bumps)
>>> Thomas
That's what I was thinking.
I thought that they would be earlier than the 80's.
Regards
Close. "The Greatest American Hero"
(With Robert Culp from I Spy (!) :O )
Yes, but only slightly. 1977
Whoosh! That went completely over my head. Not only have I never heard
of the movie. The image looked like a neon tube mounted in an old
fashioned lampshade.
Regards
Am 26.07.2017 um 16:44 schrieb Stephen:
Given the state-of-the-art special effects back then, maybe it /was/ a
neon tube mounted in an old fashioned lampshade after all ;)
>>> (still no bumps)
> I added:
> global_settings {
> assumed_gamma 1.0
I am not understanding this. I added the assumed gamma (but kept the
texture as it is), and still nothing of the bump shows! I really want to
use an images as texture. Please try my scene with the assumed gama, and
post the resulting image.
I am attaching the scene code, the bump image, and the resulting scene
image.
#version 3.7;
global_settings
#if(MyRadiosity)
radiosity
media on
pretrace_start 0.08
pretrace_end 0.001
count 400
error_bound 0.75
recursion_limit 1
normal on
assumed_gamma 1.0
subsurface {}
adc_bailout 0.0039
assumed_gamma 1.000
max_trace_level 5
number_of_waves 10
noise_generator 3
charset ascii
camera
right 1.77*x
light_source
area_illumination
light_source
// spotlight
// falloff 100.0
// radius 10.0
// fade_power 4
union
bump_map
translate -0.5
scale MyRadius*2
bump_size 0.02
interpolate 2 }
translate -0.5
scale -MyRadius*2
bump_size 0.04
// reflection 0.00
crand 0.10
brilliance 1.50
phong albedo 0.05
metallic 0.00
ambient 0.00
emission 0.00
reflection 0.50
pigment
image_map
gamma 1
map_type 0
interpolate 2
once
translate -0.5
scale MyRadius*2
normal
gradient y
normal_map
normal
gradient y
normal_map
95.0, 105.0
union
3.5 }
0.0, 000.0, 0.0 > }
0.0, 045.0, 0.0 > }
0.0, 090.0, 0.0 > }
0.0, 135.0, 0.0 > }
0.0, 180.0, 0.0 > }
0.0, 225.0, 0.0 > }
0.0, 270.0, 0.0 > }
0.0, 315.0, 0.0 > }
0.0 > 3.3 }
union
union
union
light_source
< 10.0, 0.0, 2.5 >
fade_distance 50.0
fade_power 4
light_source
< 10.0, 0.0, -2.5 >
fade_distance 50.0
fade_power 4
union
object { Launcher }
http://www.avg.com
Download 'space - launcher - balloon - type 001 - moon runnings.png' (172 KB)
Coming back into the cinemas. Alas they did not add the latest effects
and spaceship designs to that great movie. I've seen the original movie.
Great movie.
Still not getting any bumps, feeling very frustrated now. I want to keep
my texture image file, not replacing it with a single color.
Attached are scene code, bump image, and resulting bump-less scene
image. Are you people getting bumps the way it is?
#version 3.7;
global_settings
#if(MyRadiosity)
radiosity
media on
pretrace_start 0.08
pretrace_end 0.001
count 400
error_bound 0.75
recursion_limit 1
normal on
assumed_gamma 1.0
subsurface {}
adc_bailout 0.0039
assumed_gamma 1.000
max_trace_level 5
number_of_waves 10
noise_generator 3
charset ascii
camera
right 1.77*x
light_source
area_illumination
light_source
// spotlight
// falloff 100.0
// radius 10.0
// fade_power 4
union
bump_map
translate -0.5
scale MyRadius*2
bump_size 0.02
interpolate 2 }
translate -0.5
scale -MyRadius*2
bump_size 0.04
// reflection 0.00
crand 0.10
brilliance 1.50
phong albedo 0.05
metallic 0.00
ambient 0.00
emission 0.00
reflection 0.50
pigment
image_map
gamma 1
map_type 0
interpolate 2
once
translate -0.5
scale MyRadius*2
normal
gradient y
normal_map
normal
gradient y
normal_map
95.0, 105.0
union
3.5 }
0.0, 000.0, 0.0 > }
0.0, 045.0, 0.0 > }
0.0, 090.0, 0.0 > }
0.0, 135.0, 0.0 > }
0.0, 180.0, 0.0 > }
0.0, 225.0, 0.0 > }
0.0, 270.0, 0.0 > }
0.0, 315.0, 0.0 > }
0.0 > 3.3 }
union
union
union
light_source
< 10.0, 0.0, 2.5 >
fade_distance 50.0
fade_power 4
light_source
< 10.0, 0.0, -2.5 >
fade_distance 50.0
fade_power 4
union
object { Launcher }
http://www.avg.com
https://en.wikipedia.org/wiki/The_Greatest_American_Hero
Pretty sure it was lights on the bottom of a hot air balloon, which is why this
reminds me so much of it.
https://www.youtube.com/watch?v=e9Q3orQhEcA
Maybe Sven needs to add some light sources to the scene... :D
Am 26.07.2017 um 17:46 schrieb Sven Littkowski:
> Great movie.
At the moment, all seems to point at the pigment definition as the
culprit, as that's the only relevant thing we've always changed. You
should at least /try/ it with a plain pigment, to either confirm or
refute this theory.
If you can confirm it, we know that's what we have to examine further;
in that case you'll probably want to post the image map at last, so that
we can see what might be so special about it.
Otherwise we can be sure that it's a red herring, and that we have to
dig someplace else.
Am 26.07.2017 um 18:37 schrieb Bald Eagle:
You know you'll be going straight to The Hague for posting this, right?
I believe what's going on is your image map is too dark and there's no specular
highlight or phone home and load in your outer finish statement.
I'm not home to test that theory out.
> highlight or phong* in your outer finish statement.
* edited. note to self: don't talk to text these povray messages by smart phone!
pecular
phone!
You mean, I should use a different angle for the light source?
http://www.avg.com
>> Great movie.
> refute this theory.
> dig someplace else.
Nope. Here's a one-color pigment. :-(
texture source code:
pigment
color rgb < 0.2, 0.9, 0.0 >
/* image_map
gamma 1
map_type 0
interpolate 2
once
translate -0.5
scale MyRadius*2 */
normal
gradient y
normal_map
// finish { MyOuterBalloonFinish }
http://www.avg.com
Download 'space - launcher - balloon - type 001 - moon runnings.png' (70 KB)
y this
But I have a light source there. You mean, I should add more light sources?
http://www.avg.com
> y this
":D" big grin face, so I'm sure Bald Eagle was jesting, at least mostly I'm
guessing.
Having seen your green balloon using that same bump_map... something is
obviously wrong. I think we have all had trouble understanding why it only
happens for you.
Is that version of POV-Ray official or custom?
Probably what we all need to know is at this point is if a test of a simple
normal statement on a simple object is okay or not.
Not knowing what else you've done to check what's going on, maybe forget about
the balloon for now and render this and you should see a bumpy ball (camera NOT
needed! default camera used):
#version 3.7;
global_settings {
assumed_gamma 1
light_source {
<-20, 40, -20>
color rgb <1,1,1>
sphere {0,1
pigment{ color rgb <1,1,1> }
normal { bumps bump_size 1 }
finish { specular 0.1 }
scale 0.2
translate <0,0,3>
> >> specular highlight or phong highlight in your outer finish statement.
No, sorry, just that there's nothing at all in your outer finish statement to
affect lighting and shadowing.
// reflection 0.00
crand 0.10
brilliance 1.50
phong albedo 0.05
metallic 0.00
ambient 0.00
emission 0.00
reflection 0.50
As you can see there, the inner finish does have highlighting via phong but it's
very little and can't be seen from outside (without transparency for outside).
> // reflection 0.00
> crand 0.10
Sorry again. I wasn't smart there. Of course, default 'diffuse' finish should
still show shadowing when a normal statement is used, regardless of a finish
statement even existing or not.
Only way it wouldn't, that I can think of, is if scale is messing with the
normal. Or bump_size itself is affected in a bad way somehow.
Beyond that, I'm back to wondering about the program. I checked versions 3.7.0
and 3.7.1.rc1 and image_map doesn't remove a surface normal in my testing for
that. All okay here, anyhow.
Here we are approaching 60 messages in this thread, must be an answer to the
mystery... thing is, no one else has had the same thing happen yet, except for
finding trouble with low contrast, dark image/bump maps.
And now the green balloon render lacking bumpiness only makes the mystery more
so one.
Never give up hope, but this is a tricky thing for whatever reason.
>>>> (still no bumps)
>> I added:
>> global_settings {
>> assumed_gamma 1.0
> image.
Well, I don't know what goes wrong with your render, but my render of
your code is ok.
Please note that assumed_gamma should be declared /before/ the
kolors.inc include or you while get an error message. Also note that you
have declared assumed_gamma twice inside the global_settings. However,
that is not the problem.
Download 'sl_balloon2.png' (88 KB)
Preview of image 'sl_balloon2.png'
Do you think that it is possible that there is a mix up with duplicate
image files being referenced?
Or finding the wrong file in a long Library_Path?
Regards
Not very likely I suppose.
Just checked using image and bump files located in a parent-sub-sub folder on a
another partition and was okay with forward slashes and backslashes, even though
the latter causes P-R to spit out error messages.
Oh, and this must be message number 60. ;)
Await hearing which POV-Ray version, or if custom compiled. I could have missed
that info so maybe I will scan over this thread again in the meantime.
Am 27.07.2017 um 05:24 schrieb Sven Littkowski:
>> refute this theory.
>> dig someplace else.
Okay, now this leaves surprisingly few possible explanations. I can only
come up with the following:
- You might be using a rare and buggy version of POV-Ray.
To check this, I recommend you post the exact POV-Ray version number
(and let us know which operating system you're using).
- You might be using a different scene file and/or bump map image file
than those you posted.
- There might be a relevant line break introduced in your post of the
scene file that we've been overlooking.
To check these two, I recommend you temporarily rename your scene and
auxiliary files (image file and bump map), then try to re-create the
scene from your own postings and render it. You'll get parse errors,
make sure to fix only those actually reported.
- You might be using low-quality settings (`+q7` or lower).
To check this, I recommend you post the message output of the render,
and/or run the render with `+giFOO.INI` and post the generated FOO.INI here.
It has happened to me on occasion.
A long way off the record.
642 at the last count, in OT.
http://news.povray.org/povray.off-topic/thread/%3C5797bc1b%40news.povray.org%3E/?ttop=416746&toff=50
Has anyone collect Sven's code? I don't fancy going through the thread
to piece it all together. And I've not been following it closely.
Regards
This is the latest, with my amendments. See also the attached images I used.
Download 'balloon bumpmap.png' (201 KB)
Download 'balloon texture.png' (3 KB)
Download 'sl_balloon2.pov.txt' (8 KB)
Preview of image 'balloon bumpmap.png'
Preview of image 'balloon texture.png'
> guessing.
The light sources I was suggesting were the lights at the bottom of the balloon
- in the video. Because spaceships only ever visit Earthlings at night in
isolated, unpopulated areas.
And it makes for dramatic lighting.
I think that for clarity and accuracy, it might be advisable to package all of
the files into a ZIP and post it in a binary thread so that everybody has all of
the same pieces to analyze. Unzip to a subdirectory, and then there shouldn't
be any question of what files are being used to generate the render.
> used.
Thanks Thomas.
The results were as expected. The shadows showing.
But is this expected? It is the top of the balloon.
[Drat! I can't put them inline.]
Using Sven's original code. I imported it into Bishop3D correcting the
errors one by one. Using the image maps you supplied. The second image
is directly from Sven's code.
What concerns me is:
image_map { png "H:\My Documents\My Pictures\POV-Ray\Space - Launcher
- Balloon - Type 001 - Moon Runnings - Balloon Texture.png" }
Are those spaces and dashes part of the file name?
Regards
Download 'import02_0000.png' (184 KB)
Download 'import03_00000.png' (137 KB)
Preview of image 'import02_0000.png'
Preview of image 'import03_00000.png'
How very true. :)
Did I ever tell you about the time I stopped off in Roswell for lunch? I
regretted it, I can tell you.
Regards
>> used.
> Thanks Thomas.
Well, the bump_map is polar-oriented, so I expect the creases to show up
on the sides too while the top is fairly smooth (according to the map).
A question for Sven, but I think they are.
>>> used.
>> Thanks Thomas.
Sorry, I meant the cap on the top that was missed in the difference.
Indeed it is. Although they look suspiciously, a bit like file paths to me.
Like everyone else, I see no reason for it not to work on Sven's machine.
Regards
>> to the
>> except for
Not sure, but I would tend to say NO. I have only that one bump image. :-
http://www.avg.com
missed
POV-Ray v3.7.0.msvc10.win64
http://www.avg.com
