Subject: Re: Differencing a cubic sphere sweep - artifact problem!
Date: 1 May 2017 12:35:43
Message: <590763df$1@news.povray.org>
Le 01/05/2017 à 18:19, Le_Forgeron a écrit :
> * sphere sweep: removed the preliminary workaround for FS#81 (not
> effective, was adding noise)
And also, REMOVE THAT FS#81 PATCH which do no good.
Date: 2 May 2017 13:00:41
Message: <5908bb39$1@news.povray.org>
Am 30.04.2017 um 17:42 schrieb Kenneth:
> "Kenneth" <kdw### [at] gmailcom> wrote:
>> I tried all sorts of tricks to try and eliminate the problem, but no luck...
> I ran the scene in the latest(?) 3.7.1 beta 5, as well as in my original 3.70
> install; same problems in both.
> IIRC, sphere_sweeps using a cubic spline have been problematic for a *long*
> time. If it were possible to do, I would suggest adding the 'natural_spline'
> type to the sphere_sweep code. I don't know the math differences between natural
> and cubic splines (or if one is mathematically 'simpler' than the other) but it
> might give us at least one way to make curvy sphere_sweeps that can be
> CSG-differenced from another object.
Mathematically, "natural splines" are only marginally different from
what POV-Ray calls "cubic splines": Both are 3rd order polynomial
splines, i.e. piecewise defined functions mapping a single scalar
parameter to a point in N-dimensional space, with each piece having the form
F(t) = A[3] * t^3 + A[2] * t^2 + A[1] * t + A[0]
with A[i] being N-dimensional constants (N=3 in the case of POV-Ray's
splines).
I would therefore not expect "natural splines" to have any advantage
over the so-called "cubic splines" (except possibly being more intuitive
to control, depending on user and use case). To the contrary, "natural
splines" have fewer degrees of freedom, allowing less control over the
direction and curvature at the start and end of the spline.
Technically speaking, all 3rd order polynomial splines are cubic
splines. This also includes POV-Ray's "bezier splines", which behind the
scenes differ from the other types only in that they provide even more
degrees of freedom, allowing for sudden changes in both direction and
curvature between the pieces of the spline.
Date: 2 May 2017 14:26:31
Message: <5908cf57$1@news.povray.org>
Am 01.05.2017 um 18:35 schrieb Le_Forgeron:
I was about to press "send" on a passionate defense of that patch just
now, when something crossed my mind.
Can you confirm my hunch that all use cases where the patch negatively
impacts quality are cases where we see the sphere sweep's inside?
Other than that, I'm at a loss how the patch could possibly have any
negative impact.
> splines... [snip]
Thinking back to the v3.62 days, I'm ashamed to admit that you probably
explained this long ago-- and probably in response to a similar post by me! Mea
culpa.
I've been looking at Wikipedia's entries on 'spline interpolation' and 'cubic
Hermite splines', in a (poor) attempt to understand them. But I'm trying! ;-)
My mention of using a 'natural spline' is simply based on its well-behaved use
in other parts of POV-Ray (without knowing its mathematical differences vs.
POV-ray's 'cubic splines'.) I had assumed that a 'natural spline' was somehow
better behaved mathematically than a cubic one... or maybe that it wasn't 3-rd
order...
Since both 'natural splines' and 'cubic splines' ARE both 3-rd order, I'm
willing to guess(!) that the problem is not in POV-ray's mathematical
implementation of the cubic spline, but rather in some kind of co-dependent
problem with the 'difference-ing' operation. Based on nothing but my nutty
intuition ;-)
Date: 3 May 2017 11:08:13
Message: <5909f25d$1@news.povray.org>
Am 02.05.2017 um 22:58 schrieb Kenneth:
>> splines... [snip]
> culpa.
I'm an explainer by nature. It's difficult to tire me out on
re-iterating stuff I've explained over and over again. Ask me again
tomorrow, and I'll explain once more.
> intuition ;-)
There _is_ (or so I think by now) a fundamental flaw of that infamous
"FS#81 Patch" that specifically screws up difference ops (and other
cases where the interior of the sphere sweep is exposed). However, the
issue the patch was originally intended to fix does hit 3rd order
splines even without a difference op. (In a nutshell, any 3rd order
sphere sweep will be screwed up anywhere the spline runs approximately
perpendicular to the viewing direction.)
