POV-Ray : Newsgroups : povray.binaries.images : Egg Server Time
27 May 2026 09:07:39 EDT (-0400)
  Egg (Message 31 to 40 of 44)
<<< Previous 10 Messages Goto Latest 10 Messages Next 4 Messages >>>
Subject: Re: Egg
Date: 2 May 2017 04:03:20
Message: <59083d48$1@news.povray.org>
On 5/2/2017 8:48 AM, Thomas de Groot wrote:
> On 2-5-2017 9:25, Stephen wrote:
>> On 5/2/2017 7:48 AM, Thomas de Groot wrote:
>>> This all makes a lot of sense indeed.
>> Gosh! a first. :-)
> Really?
I meant a first for today.
>>> Generally, I do not build a scene
>>> with a particular scale in mind so I just assemble the elements and let
>>> the observer do the rest.
>> I'm the same. I tend to build my scenes small. For some reason I don't
>> like wasting Pov space. Which means I use a lot of decimals but decimals
>> are cheap.
> They are indeed. However, I try to avoid too small ones. They are more
> difficult to find when they drop to the floor. :-)
Alt+ LMB + drag scoops them up. :-)
(Bishop3D setting)
>>> Thus, a landscape can very well be built by
>>> either relatively small elements or by big ones, I do not care as I am
>>> only interested in the final effect.
>> I tend to use Poser figures as a reference. Michael is about six feet,
>> in my mind.
> Typically, I scale the figures to the environment they are to live in. :-)
I was talking my dreams. In truth I scale my scenes by the first object
I create.
>>> With SSLT it seems I have to be much more careful.... ;-)
>> I am sure if Clikpa were about. He would agree. ;-)
> Ah! The Clipka! He seems to have gone on holiday? Shame. He /knows/ he
> cannot go without our permission. ;-)
As long as he hasn't taken a marching band with him. It is okay. ;-)
Regards
Subject: Re: Egg
Date: 2 May 2017 07:02:04
Message: <5908672c$1@news.povray.org>
On 1-5-2017 14:06, Stephen wrote:
> On 5/1/2017 12:11 PM, Thomas de Groot wrote:
>> On 1-5-2017 12:08, Stephen wrote:
>>> On 5/1/2017 7:50 AM, Thomas de Groot wrote:
>>>> I am a bit wary about the mm_per_unit and prefer not to touch it too
>>>> much, especially if different objects have different scales.
>>> Yes Clipka has put the fear of god into us. :-)
>>> I suppose it depends what you intend by scaling the models.
>> Indeed, yes. Take my image as example, the dragon is scaled 0.01, the
>> egg 0.25, the cube is not scaled, and the floor 0.50. It seems best to
>> use a standard mm_per_unit and change translucency as needed.
> My understanding is that the mm_per_unit is the world/scene scale
> And to add to the confusion (on my part at least) meshes can have an
> internal scale and an external one. By internal scale I mean the scaling
> you can change in PoseRay before exporting and external is how you
> change it in PovRay.
> In Blender when using the physics engine the scale should be 1.0. So to
> scale a mesh. You need to edit it and scale it there. Otherwise you get
> unexpected results.
> So if the dragon is an ornament. I would scale it down in PoseRay. If it
> is a statue scale it up in PoseRay. Keep the mm_per_unit as the default.
> Having said that. I have not used SSLT since its RC3. :-(
> So what do I know?
I have been pondering this a bit. I think that you do achieve the same
(using meshes of course) if you first do basic transforms (in POV-Ray)
and /then/ use that copy of the original object with SSLT. In fact, I do
that exercise quite often:
#declare MyObject =
object {MyMesh_POV_
   transform {MyTransforms}
object {MyObject
   material {MyMaterial}
   rotate {MyRotate}
   translate {MyTranslate}
Subject: Re: Egg
Date: 2 May 2017 14:47:47
Message: <5908d453$1@news.povray.org>
Am 30.04.2017 um 13:05 schrieb Thomas de Groot:
> Question: In the wiki about SSLT it is said: "The effect doesn't scale
> with the object". Does this mean that SSLT works in the same way as a
> scattering media where the amount of scattering has to be compensated
> for the amount of media object's scale? It appears so to me at least
> although this is not mentioned in the wiki.
That depends on what you want to achieve.
If you want the object to look like a larger item made of the same
material, scale the object and use the same SSLT parameters.
If you want the object to look exactly the same, but take up a larger
portion on the screen, scale the object and adjust the SSLT parameters.
(Or zoom in on the object ;))
Subject: Re: Egg
Date: 2 May 2017 14:52:12
Message: <5908d55c@news.povray.org>
Am 01.05.2017 um 14:06 schrieb Stephen:
Indeed.
Also, I might take the opportunity to re-iterate that it is not an SSLT
setting /per se/. It only just so happens that SSLT is currently the
only feature that makes use of it.
Subject: Re: Egg
Date: 2 May 2017 15:04:19
Message: <5908d833$1@news.povray.org>
Am 02.05.2017 um 08:51 schrieb Thomas de Groot:
> On 2-5-2017 5:57, Alain wrote:
> [snip]
>> You should set it according to the overall scale of your scene.
>> The default of 10 mean 1 POV unit = 1 cm. Set it to 1000 if your scale
>> is 1 POV unit = 1 m, and 25.4 for 1 inch = 1 POV unit.
>> In my suggestion, it would make a scene scalled in cm work in mm. So,
>> you can change mm_per_unit from it's default of 10 to 1 to reflect the
>> change in overall scale.
> As I wrote in my answer to Stephen, I am shamefully negligent about
> overall scales and just throw together elements to be brewed in the same
> pot. I need to be a bit more careful if I want to include SSLT. :-)
Technically, you only need to be careful if you intend to re-use (or
have others re-use) your SSLT stuff in any other scene.
For instance, if you've concocted a convincing ivory material, that
ivory material will only look convincing in other scenes if both your
original scene and the new scene have proper mm_per_unit settings (or if
both have the mm_per_unit setting screwed up by the same factor).
Subject: Re: Egg
Date: 2 May 2017 15:05:55
Message: <5908d893$1@news.povray.org>
> Indeed.
Yet? :-)
Regards
Subject: Re: Egg
Date: 2 May 2017 15:44:06
Message: <5908e186@news.povray.org>
Am 02.05.2017 um 10:03 schrieb Stephen:
Nah, no marching band for me yet.
But eight bells for someone dear.
Subject: Re: Egg
Date: 2 May 2017 15:49:00
Message: <5908e2ac$1@news.povray.org>
Sorry to hear that. :-(
Regards
Subject: Re: Egg
Date: 3 May 2017 02:50:39
Message: <59097dbf$1@news.povray.org>
Well, I am very sorry to hear that, Christoph. You have my sincere support.
Subject: Re: Egg
Date: 3 May 2017 02:54:55
Message: <59097ebf$1@news.povray.org>
Hmmm... yes, that is well put. I guess I have to ponder this a bit and
add it to my own little reminders.
Thanks a lot!
