![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thomas de Groot <tho### [at] degroot org> wrote:
> To test this I need the fFinal() fInpX() fInpY() fInpZ() functions too.
Okay, maybe Thomas has figured this out too. I was just trying to think it out
using other functions and got nowhere but I did suspect something I had happen
before:
I ran your files as animation and found nothing wrong...
except after about clock=0.52 and until about clock=0.72
What's going on is simply a case of max_gradient 50 being too low for that
particular segment of frames.
That isosurface requires up to max_gradient 60 from what I found during that
part of the animation.
Try this instead of max_gradient:
evaluate 15,4,0.7
That will give a minimum gradient value with a multiple of 4 (=60) and change
rate.
Better yet, read about that at:
http://wiki.povray.org/content/Reference:Isosurface
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> before:
> evaluate 15,4,0.7
> rate.
That seems to work. Thank you!
Mike
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> think it out
>> had happen
>> before:
>> that
>> during that
>> evaluate 15,4,0.7
>> change
>> rate.
> Mike
I was not yet that far, but I was thinking in the same direction.
Evaluate is a good tool to use in this context.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I haven't had a chance to look over the isosurface functions, but it looks like
the final shape is a parallelpiped.
If so, couldn't you just make a box and shear it in all 3 directions?
Simpler and lots faster, if that's the case.
I enjoy these color models you work on.
They are very pleasing to my eye.
Keep up the good work! :)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I am having the same problem in a different scene posted in p.t.s-f.
This time I used "evaluate" from the start. Render times are long but
artifacts still appear.
Mike
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
No, I don't want to do this.
Mike
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Mike
Disregard.
Mike
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Yow! I used max_gradient alone to see what POV-Ray was saying it wanted that to
be and its way beyond what the other isosurface evaluate parameters were.
Which BTW I finally ended up using MinFactor=0.7 to prevent any missing portions
of that one.
This current isosurface using max_gradient 10000 (sans evaluate) is rendering 5
minutes at only 160X120 resolution, incomplete of course.
Render message told me it needed max_gradient 7131910.500, so that really puts
the evaluate numbers up there and the render time is obviously going to increase
dramatically.
Sorry I don't have a solution, can only tell you that much. If there's a way to
reduce render times and still get a complete isosurface for this one I sure
don't know the answer. Unless something can be manipulated to do so and someone
else knows how to go about it anyway.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> of that one.
> dramatically.
> Bob
I think clipka told me to use this:
#declare cie_fClip1 = function(X,A) {select(X-A,A,X)}
#declare cie_fClip2 = function(X,A) {select(-(X-A),A,X)}
#declare cie_fD = function(C)
{abs(cie_fClip2(cie_fClip1(C,-0.1),1.1)-0.5)-0.5}
instead of this:
#declare cie_fD = function(C) {abs(C-0.5)-0.5}
as a workaround.
Mike
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 3/7/2017 12:21 PM, Mike Horvath wrote:
> I am trying to render the following isosurface.
> isosurface
> function {fFinal(fInpX(x,y,z),fInpY(x,y,z),fInpZ(x,y,z))}
> threshold 0
> accuracy 0.001
> contained_by
> box {0,1}
> max_gradient 50 // was 20000
> However, from certain angles there appear gaps or cuts in the surface,
> and you can see inside. The gaps disappear when viewed from other angles.
> Does anyone have any tips on how to fix this? I already tried scaling by
> 200 but it does not help.
> Mike
I wish I could replace these with meshes. Then I could make an animation
with many frames.
Mike
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
