Am 24.12.2016 um 16:21 schrieb jhu:
I've made no attempt to "un-out-wash" it, so that's not much of a surprise.
Better?
Download 'gamma_smoking_gun.png' (98 KB)
Preview of image 'gamma_smoking_gun.png'
> Better?
Significantly. Radiosity?
Am 24.12.2016 um 23:42 schrieb jhu:
>> Better?
That, and gave the light source a realistic inverse-square-law falloff
while moving it closer.
> #version 3.7;
> global_settings { assumed_gamma 2.2 }
> light_source { <-3000,3000,-3000> color rgb 1.2 }
Hello all! I finally have a new computer (well, a used one, with Windows 7
Ultimate, and a dual-core processor. No more Windows XP, sadly-- that one died.)
I've been away from the newsgroups for several months...
But I digress...
I decided to run your test scene with assumed_gamma 1.0 instead of 2.2, and
noticed something about your use of 'rgb' in the light_source. I changed it to
srgb (which I've started doing in all my v3.7xx scenes, to be 'color-consistent'
with all the other srgb colors I use), and noticed that the scene gets
*brighter.* It's an interesting (and unexpected) effect-- unexpected because,
when substituting srgb colors for rgb (under assumed_gamma 1.0), it usually
causes the lighting/colors to be be somewhat *darker* (as expected, due to the
gamma shift of the color components away from linear.) But in this case, the
result is the opposite-- it's brighter!
I assume this is because the light's intensity is greater than 1.0; but I don't
quite understand why. Is it a natural consequence of the srgb 'gamma curve',
affecting color components above 1.0? (Or maybe above a particular
'intermediate' value between 0.0 and 1.0?)
Am 27.12.2016 um 09:21 schrieb Kenneth:
You can think of "srgb C" as (roughly) equivalent to "rgb pow(C,2.2)",
i.e. very roughly squaring the colour value. As you may be aware, the
square of a (positive) value below 1 is an even smaller value, while the
square of a value above 1 is an even larger value.
The sRGB "transfer function" (that's the official technical term) is
indeed designed in such a way that it is neutral for values of 0 and 1,
while adjusting any values in between. Since it was designed for
situations where colours are clipped to this range, no special handling
is provided for larger values, and the effect is reversed there.
BTW, in the nominal region (between 0 and 1) the largest absolute effect
of gamma adjustment is roughly around an sRGB value of 0.5 (a linear
value of about 0.24), while the largest relative effect is near black.
BTW, there's a caveat when using "srgb" in light sources: To modify the
brightness without affecting the hue, you need to use
colour (srgb <R,G,B>)*Brightness
rather than
colour srgb <R,G,B>*Brightness
because the latter would be interpreted as
colour srgb (<R,G,B>*Brightness)
and in the sRGB world multiplying a colour vector by a constant does
/not/ correspond to an even scaling of the corresponding linear colour
components. (That would work for f(x)=pow(x,2.2), but sRGB gamma is more
complicated than that.)
Ah, of course; that makes perfect sense (now that you've explained it, ha!)
> rather than
Wow, that's a subtle difference that I wasn't aware of. Thanks! I'm curious--
would the same logic apply to colors in MEDIA? Or does the above formula apply
*only* to lights?
> rather than
The moral seems to be get all of your srgb declarations out of the way as early
as possible--including before you do any math on such colors.
Am 27.12.2016 um 21:28 schrieb Kenneth:
I'm just noticing that this syntax actually doesn't work; you'll need to use
#declare C = srgb <R,G,B>;
colour C * Brightness
>> rather than
> *only* to lights?
It applies anywhere you want to change the "magnitude" (be it
brightness, density or whatever) of a colour by a factor while retaining
the same hue and saturation.
What /is/ perfectly ok is dividing sRGB colour data for the purpose of
normalizing it to the range [0..1] when the "raw" data is normalized for
another range, e.g.:
srgb <0,192,255>/255
