Am 01.12.2016 um 22:09 schrieb Stephen:
> On 12/1/2016 8:27 PM, clipka wrote:
>> (Also, burning the software into a set of EPROMS might actually be the
>> only reasonable way to get it into the computer; it doesn't have
>> anything in terms of standardized external interfaces.)
> How about using a lump hammer and two 12" shifting spanners?
> That usually solves most problems. ;)
That certainly /gets rid/ of most problems. Doesn't necessarily produce
a /solution/ though ;)
clipka <ano### [at] anonymousorg> wrote:
> Am 01.12.2016 um 20:28 schrieb Cousin Ricky:
> > IBM PC-XT with CGA: 320 x 200, 4 colors unevenly distributed on the color wheel
> PC-XT doesn't cout; it's a 16 bit system, and therefore far too advanced
> to run interesting software.
Oh, yeah. Cramming those 16 bits through an 8 bit bus must have confused me.
Their color selection sucked anyway; it had me pining for the Apple II.
in news:58403cc6@news.povray.org clipka wrote:
> MiniPOV
Years of modeling with exquisite exlusive tools:
(oo)
_/ \/ \_______
_____\/\/______
_____{}{}___s7.
-\/- _\/_
_____\/\/___\/\/_____
_____{}{}___{}{}__s7.
Ingo
Am 01.12.2016 um 20:26 schrieb clipka:
> Am 01.12.2016 um 18:16 schrieb scott:
>>> Turns out the core module is already better than I had feared. Still, it
>>> has highlighted various issues that still need sorting out -- mostly
>>> expected (such as failure to set various default values upon object
>>> construction), but a few I did not expect, like some compile-time config
>>> settings that don't come with defaults.
>> I guess you noticed already, but your checkered plane didn't seem to
>> work properly either ;-)
> Bah - checkered planes are for wussies. I'm much more worried about the
> gamma handling... ;)
Obviously I couldn't rest until the gamma handling was fixed.
Download 'minipov.png' (27 KB)
Preview of image 'minipov.png'
On 12/01/2016 08:28 PM, Cousin Ricky wrote:
> Apple II: 280 x 192 (effective color resolution 140 x 192), 6 colors
> TRaSh 80: 80 x 24 (IIRC), black and white
My first computer have only 8 red leds as display,
really nice setup for some k2000 effects...
Maybe not but who is going to around to complain? ;)
Regards
On 12/1/2016 11:51 PM, Stephen wrote:
> Maybe not but who is going to *Be* around to complain? ;)
Regards
> =?UTF-8?Q?J=c3=b6rg_=22Yadgar=22_Bleimann?= <yaz### [at] gmxde> wrote:
>> This is how POV-Ray should look on the Commodore 64! Block graphic font
>> in 40 by 25 characters! No image bigger than 1000 bytes!
>> Retrocomputing rules! There should be a POV-Ray version for each of the
>> 1980s' 8-bit classic machines!
It have two graphic modes, low res and high res.
You describe the hires mode.
Low res is 40 x 48 in 16 colours.
Am 02.12.2016 um 02:03 schrieb Alain:
Sounds like an abused text mode to me (40x24 characters, using 2-block
graphic characters and per-character foreground/background colours).
That's effectively what it was, although I can't remember if that was
literally the case. Either way, it was handled transparently by the
graphics commands.
The original Apple II used a 6 bit ASCII subset, so there was plenty of
room to play around with the extra bits. The Apple IIe used the full 7
bit ASCII set, but I'm less familiar with that model.
