in news:58403cc6@news.povray.org clipka wrote:
> MiniPOV
Years of modeling with exquisite exlusive tools:
(oo)
_/ \/ \_______
_____\/\/______
_____{}{}___s7.
-\/- _\/_
_____\/\/___\/\/_____
_____{}{}___{}{}__s7.
Ingo
Am 01.12.2016 um 20:26 schrieb clipka:
> Am 01.12.2016 um 18:16 schrieb scott:
>>> Turns out the core module is already better than I had feared. Still, it
>>> has highlighted various issues that still need sorting out -- mostly
>>> expected (such as failure to set various default values upon object
>>> construction), but a few I did not expect, like some compile-time config
>>> settings that don't come with defaults.
>> I guess you noticed already, but your checkered plane didn't seem to
>> work properly either ;-)
> Bah - checkered planes are for wussies. I'm much more worried about the
> gamma handling... ;)
Obviously I couldn't rest until the gamma handling was fixed.
Download 'minipov.png' (27 KB)
Preview of image 'minipov.png'
On 12/01/2016 08:28 PM, Cousin Ricky wrote:
> Apple II: 280 x 192 (effective color resolution 140 x 192), 6 colors
> TRaSh 80: 80 x 24 (IIRC), black and white
> IBM PC-XT with CGA: 320 x 200, 4 colors unevenly distributed on the color wheel
My first computer have only 8 red leds as display,
really nice setup for some k2000 effects...
On 12/1/2016 9:24 PM, clipka wrote:
> Am 01.12.2016 um 22:09 schrieb Stephen:
>> On 12/1/2016 8:27 PM, clipka wrote:
>>> (Also, burning the software into a set of EPROMS might actually be the
>>> only reasonable way to get it into the computer; it doesn't have
>>> anything in terms of standardized external interfaces.)
>> How about using a lump hammer and two 12" shifting spanners?
>> That usually solves most problems. ;)
> That certainly /gets rid/ of most problems. Doesn't necessarily produce
> a /solution/ though ;)
Maybe not but who is going to around to complain? ;)
Regards
On 12/1/2016 11:51 PM, Stephen wrote:
> Maybe not but who is going to *Be* around to complain? ;)
Regards
> =?UTF-8?Q?J=c3=b6rg_=22Yadgar=22_Bleimann?= <yaz### [at] gmxde> wrote:
>> This is how POV-Ray should look on the Commodore 64! Block graphic font
>> in 40 by 25 characters! No image bigger than 1000 bytes!
>> Retrocomputing rules! There should be a POV-Ray version for each of the
>> 1980s' 8-bit classic machines!
It have two graphic modes, low res and high res.
You describe the hires mode.
Low res is 40 x 48 in 16 colours.
Am 02.12.2016 um 02:03 schrieb Alain:
Sounds like an abused text mode to me (40x24 characters, using 2-block
graphic characters and per-character foreground/background colours).
That's effectively what it was, although I can't remember if that was
literally the case. Either way, it was handled transparently by the
graphics commands.
The original Apple II used a 6 bit ASCII subset, so there was plenty of
room to play around with the extra bits. The Apple IIe used the full 7
bit ASCII set, but I'm less familiar with that model.
Am 02.12.2016 um 04:29 schrieb Cousin Ricky:
> graphics commands.
Ah, that brings memories to life!
Such as flipping a hardware switch to change the character set from
German to ASCII when writing program code, and later flipping back to
German when running the program.
Yes, much better indeed! How is aa coming along?
