![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
in news:58403cc6@news.povray.org clipka wrote:
> MiniPOV
Years of modeling with exquisite exlusive tools:
(oo)
_/ \/ \_______
_____\/\/______
_____{}{}___s7.
-\/- _\/_
_____\/\/___\/\/_____
_____{}{}___{}{}__s7.
Ingo
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 01.12.2016 um 20:26 schrieb clipka:
> Am 01.12.2016 um 18:16 schrieb scott:
>>> Turns out the core module is already better than I had feared. Still, it
>>> has highlighted various issues that still need sorting out -- mostly
>>> expected (such as failure to set various default values upon object
>>> construction), but a few I did not expect, like some compile-time config
>>> settings that don't come with defaults.
>> I guess you noticed already, but your checkered plane didn't seem to
>> work properly either ;-)
> Bah - checkered planes are for wussies. I'm much more worried about the
> gamma handling... ;)
Obviously I couldn't rest until the gamma handling was fixed.
Download 'minipov.png' (27 KB)
Preview of image 'minipov.png'
![minipov.png](/povray.binaries.images/attachment/%3C5840abaf%241%40news.povray.org%3E/minipov.png?ttop=415988&toff=50&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 12/01/2016 08:28 PM, Cousin Ricky wrote:
> Apple II: 280 x 192 (effective color resolution 140 x 192), 6 colors
> TRaSh 80: 80 x 24 (IIRC), black and white
> IBM PC-XT with CGA: 320 x 200, 4 colors unevenly distributed on the color wheel
My first computer have only 8 red leds as display,
really nice setup for some k2000 effects...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 12/1/2016 9:24 PM, clipka wrote:
> Am 01.12.2016 um 22:09 schrieb Stephen:
>> On 12/1/2016 8:27 PM, clipka wrote:
>>> (Also, burning the software into a set of EPROMS might actually be the
>>> only reasonable way to get it into the computer; it doesn't have
>>> anything in terms of standardized external interfaces.)
>> How about using a lump hammer and two 12" shifting spanners?
>> That usually solves most problems. ;)
> That certainly /gets rid/ of most problems. Doesn't necessarily produce
> a /solution/ though ;)
Maybe not but who is going to around to complain? ;)
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 12/1/2016 11:51 PM, Stephen wrote:
> Maybe not but who is going to *Be* around to complain? ;)
Regards
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> =?UTF-8?Q?J=c3=b6rg_=22Yadgar=22_Bleimann?= <yaz### [at] gmx de> wrote:
>> This is how POV-Ray should look on the Commodore 64! Block graphic font
>> in 40 by 25 characters! No image bigger than 1000 bytes!
>> Retrocomputing rules! There should be a POV-Ray version for each of the
>> 1980s' 8-bit classic machines!
It have two graphic modes, low res and high res.
You describe the hires mode.
Low res is 40 x 48 in 16 colours.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 02.12.2016 um 02:03 schrieb Alain:
Sounds like an abused text mode to me (40x24 characters, using 2-block
graphic characters and per-character foreground/background colours).
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
That's effectively what it was, although I can't remember if that was
literally the case. Either way, it was handled transparently by the
graphics commands.
The original Apple II used a 6 bit ASCII subset, so there was plenty of
room to play around with the extra bits. The Apple IIe used the full 7
bit ASCII set, but I'm less familiar with that model.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 02.12.2016 um 04:29 schrieb Cousin Ricky:
> graphics commands.
Ah, that brings memories to life!
Such as flipping a hardware switch to change the character set from
German to ASCII when writing program code, and later flipping back to
German when running the program.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Yes, much better indeed! How is aa coming along?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
