POV-Ray : Newsgroups : povray.binaries.images : I've seen the light! Server Time
13 Jun 2024 13:43:08 EDT (-0400)
  I've seen the light! (Message 13 to 22 of 32)
Subject: Re: I've seen the light!
Date: 1 Dec 2016 17:15:51
Message: <XnsA6D1ECA77E3D9seed7@news.povray.org>
in news:58403cc6@news.povray.org clipka wrote:
>     MiniPOV
Years of modeling with exquisite exlusive tools:
     (oo)
   _/ \/ \_______
_____\/\/______
_____{}{}___s7.
     -\/-   _\/_
_____\/\/___\/\/_____
_____{}{}___{}{}__s7.
Ingo
Date: 1 Dec 2016 18:01:03
Message: <5840abaf$1@news.povray.org>
Am 01.12.2016 um 20:26 schrieb clipka:
> Am 01.12.2016 um 18:16 schrieb scott:
>>> Turns out the core module is already better than I had feared. Still, it
>>> has highlighted various issues that still need sorting out -- mostly
>>> expected (such as failure to set various default values upon object
>>> construction), but a few I did not expect, like some compile-time config
>>> settings that don't come with defaults.
>> I guess you noticed already, but your checkered plane didn't seem to
>> work properly either ;-)
> Bah - checkered planes are for wussies. I'm much more worried about the
> gamma handling... ;)
Obviously I couldn't rest until the gamma handling was fixed.
Download 'minipov.png' (27 KB)
Preview of image 'minipov.png'
Date: 1 Dec 2016 18:40:15
Message: <5840b4df$1@news.povray.org>
On 12/01/2016 08:28 PM, Cousin Ricky wrote:
> Apple II: 280 x 192 (effective color resolution 140 x 192), 6 colors
> TRaSh 80: 80 x 24 (IIRC), black and white
> IBM PC-XT with CGA: 320 x 200, 4 colors unevenly distributed on the color wheel
    My first computer have only 8 red leds as display,
    really nice setup for some k2000 effects...
Date: 1 Dec 2016 18:51:15
Message: <5840b773$1@news.povray.org>
On 12/1/2016 9:24 PM, clipka wrote:
> Am 01.12.2016 um 22:09 schrieb Stephen:
>> On 12/1/2016 8:27 PM, clipka wrote:
>>> (Also, burning the software into a set of EPROMS might actually be the
>>> only reasonable way to get it into the computer; it doesn't have
>>> anything in terms of standardized external interfaces.)
>> How about using a lump hammer and two 12" shifting spanners?
>> That usually solves most problems. ;)
> That certainly /gets rid/ of most problems. Doesn't necessarily produce
> a /solution/ though ;)
Maybe not but who is going to around to complain? ;)
Regards
Date: 1 Dec 2016 19:06:28
Message: <5840bb04$1@news.povray.org>
On 12/1/2016 11:51 PM, Stephen wrote:
> Maybe not but who is going to *Be* around to complain? ;)
Regards
Date: 1 Dec 2016 20:02:30
Message: <5840c826@news.povray.org>
> =?UTF-8?Q?J=c3=b6rg_=22Yadgar=22_Bleimann?= <yaz### [at] gmxde> wrote:
>> This is how POV-Ray should look on the Commodore 64! Block graphic font
>> in 40 by 25 characters! No image bigger than 1000 bytes!
>> Retrocomputing rules! There should be a POV-Ray version for each of the
>> 1980s' 8-bit classic machines!
It have two graphic modes, low res and high res.
You describe the hires mode.
Low res is 40 x 48 in 16 colours.
Date: 1 Dec 2016 21:58:16
Message: <5840e348$1@news.povray.org>
Am 02.12.2016 um 02:03 schrieb Alain:
Sounds like an abused text mode to me (40x24 characters, using 2-block
graphic characters and per-character foreground/background colours).
Date: 1 Dec 2016 22:26:35
Message: <5840e9eb@news.povray.org>
That's effectively what it was, although I can't remember if that was
literally the case.  Either way, it was handled transparently by the
graphics commands.
The original Apple II used a 6 bit ASCII subset, so there was plenty of
room to play around with the extra bits.  The Apple IIe used the full 7
bit ASCII set, but I'm less familiar with that model.
Date: 1 Dec 2016 22:56:05
Message: <5840f0d5$1@news.povray.org>
Am 02.12.2016 um 04:29 schrieb Cousin Ricky:
> graphics commands.
Ah, that brings memories to life!
Such as flipping a hardware switch to change the character set from
German to ASCII when writing program code, and later flipping back to
German when running the program.
Date: 2 Dec 2016 03:01:35
Message: <58412a5f$1@news.povray.org>
Yes, much better indeed! How is aa coming along?
