POV-Ray : Newsgroups : povray.binaries.images : Blob Potential Pattern Server Time
17 Jun 2024 07:59:50 EDT (-0400)
  Blob Potential Pattern (Message 21 to 28 of 28)
Subject: Re: Blob Potential Pattern
Date: 13 Sep 2016 13:00:39
Message: <57d830b7$1@news.povray.org>
Am 13.09.2016 um 18:39 schrieb William F Pokorny:
> When the plane's pigment is set to color rgbft <1,1,1,1,1> and the
> background is set to anything but black, an odd inverted shadow shows up
> on the transparent plane. Could be used for special effects I guess.
Yes, setting colours to any value with finish+transmit>1 may cause quite
unexpected effects. Most notably, the effective opaque component of any
pigment is (rgb)*(1-finish-transmit), so with finish+transmit>1 you get
an effective opaque component that is /negative/.
> Does make me wonder if "color 1" should be promoted as it apparently is
> in the posted code?
Presuming that 3.7 reacts in the same manner, I'd say it should trigger
a warning.
Date: 13 Sep 2016 13:01:53
Message: <57d83101$1@news.povray.org>
On 09/13/2016 12:49 PM, clipka wrote:
> Am 13.09.2016 um 17:51 schrieb William F Pokorny:
>>     pigment {
>>       potential { BLOB | ISOSURFACE }
>>       [ threshold BOOL ]
>>       [ PIGMENT_MODIFIERS... ]
>> Looking just at simple blob so far I see a few things.
>> 1) Wondering it the option [threshold BOOL] should be inside the
>> potential block syntactically?
> No; the braces around the BLOB or ISOSURFACE are just around the BLOB or
> ISOSURFACE. Strictly speaking, the syntax is
>     pigment {
>       potential { BLOB | ISOSURFACE [ OBJECT_MODIFIERS... ] }
>       [ threshold BOOL ]
> (for reasons only disclosed to Disciples of the Inner Sanctum), and the
> only reason the braces are there at all is to unambiguously mark the end
> of OBJECT_MODIFIERS, so that there is no ambiguity for statements that
> may be both valid OBJECT_MODIFIERS and PIGMENT_MODIFIERS.
> There is a long-standing tradition that pattern parameters are placed on
> the same hierarchical level as pigment/normal/texture/whatever
> modifiers, and `potential` honors this tradition. (Don't be fooled by
> the syntax of the `object` pattern, it is the odd one out and should
> never have been implemented this way in the first place.)
OK. Thanks.
Bill P.
Date: 13 Sep 2016 13:14:53
Message: <57d8340d$1@news.povray.org>
>> in the posted code?
> a warning.
I checked and it does behave in the same way in 3.7.
I almost always specify the full rgbft or srgbft qualifier and values to
not get tangled up.
I got lazy here - and I had it in my head that "color 1" promoted only
to a 3 value vector. It indeed promotes to 5.
To be sure - we are adding the warning on the promotion of color
specified as a single float value >0 getting promoted to a 5 value
vector? If so, suppose this likely work at a skill level I could go
after if you want?
Bill P.
Date: 13 Sep 2016 13:57:40
Message: <57d83e14$1@news.povray.org>
Am 13.09.2016 um 19:14 schrieb William F Pokorny:
> after if you want?
You might give it a try.
Must be in the parser... /somewhere/. Keep your eyes peeled for a piece
of code that has "COLOUR_TOKEN" in it, probably along with "RGB_TOKEN",
"RGBF_TOKEN", "RGBFT_TOKEN", and the whole lot.
Date: 14 Sep 2016 06:18:49
Message: <57d92409$1@news.povray.org>
>> after if you want?
Think I got it. Please see pull request #91.
Bill P.
Date: 14 Sep 2016 08:00:48
Message: <57d93bf0$1@news.povray.org>
On 09/12/2016 04:14 PM, clipka wrote:
> Am 11.09.2016 um 20:54 schrieb clipka:
>> Work in progress.
> Source code available now here:
> https://github.com/c-lipka/povray/tree/feature/potential_pattern
> Integration into POV-Ray proper to follow later.
Been playing a bit more. Potential {Blob} with densities and normals
works. An Isosurface as the pattern for a pigment_map.
The isosurface flavor is for me working pretty much as a path to the
isosurface function. Contained_by_box not having any effect that I can
see - meaning the container doesn't cut off the result from the function.
Perhaps how I've coded, but also seeing no effect from the new polarity
option of isosurface or the threshold on/off option of the potential
pattern. Not looked at the code as yet.
With media I tried a multi component blob as both the container and what
was defining the density - really fast with emitting media. Should make
for a good "glows" feature among other uses.
Bill P.
Date: 15 Sep 2016 07:00:46
Message: <57da7f5e$1@news.povray.org>
>>> Work in progress.
> Bill P.
Please see comment to pull request #88. I think I figured out why
threshold isn't working. More info there.
Bill P.
Date: 15 Sep 2016 07:24:04
Message: <57da84d4$1@news.povray.org>
Am 15.09.2016 um 13:00 schrieb William F Pokorny:
Nailed it. Thanks for the support.
