Because catenary bridges are way cooler than power lines. :)
Download 'catenarybridge.png' (1054 KB)
Preview of image 'catenarybridge.png'
Slight progress before packing it in for the night.
Adjusted scale of struts, added cross-braces, red iron oxide paint texture,
added quick heightfield mountains, water, sky sphere.
Download 'catenarybridge.png' (1578 KB)
Cool. I've always enjoyed views of such bridges. The New Rivers Gorge
bridge as an example.
Bill P.
> Bill P.
I actually managed to grab the geo data from USGS, convert it into a png, and
then a heightfield, and once I got it all scaled and un-lost myself in the
aerial view, I managed to get things reasonably aligned.
Still needs some scaling and repositioning, and then it's mostly a matter of
working on the textures, seeing what I can do with plants again :O and all of
that skilled stuff that takes forever. :D
Download 'catenarybridge.png' (812 KB)
>> Bill P.
> Thanks :)
Good work!
Maybe the USGS data are a bit too /global/ for this scale? A bit of
extra roughness added to the png should do the trick.
Thomas de Groot <tho### [at] degroot org> wrote:
> Good work!
Thanks - though it was just a quick mock-up.
Why yes, as I found out.
The only data set I can find of that area is a 1 sec arc that covers something
like 69 miles square.
Once I figured out just HOW BIG the map was, corrected the scale, oriented
myself, found my way through it, and zoomed WAY WAY in to where I actually
wanted to be.... :O
I had to convert the original color png to a 16-color, and that brought out all
the elevation data, but at that resolution, it looks like Hell.
> A bit of extra roughness added to the png should do the trick.
> Thomas
Any recommendations for data sources, fixing up what I've got?
"extra roughness"?
>> Good work!
> wanted to be.... :O
Yes, those are huge. It has been more than 15 years ago when I last
played with USGS data (I must have a couple of CD-ROMs with DEM data
gathering dust somewhere) and they are great for overviews but not
detailed enough for close up. We always want better of course ;-)
>> Thomas
> "extra roughness"?
I think I miscalculated here :-) Now I seem to remember that the png are
processed elevation data, not something you can modify out of hand. Just
a thought: use the png inside a function with some randomisation?
However, I am afraid that would totally change the resulting landscape.
That 15 (or 20) years just blinks by, doesn't it?
> Just
Now there's something I wouldn't have thought of - or even thought I could do.
:O
I'll try to dig up some code to do that when I get back in tonight.
I tried blurring it, but that didn't work out so well.
Yes, it does. The memory is diffuse about the matter however.
>> Just
> :O
> Thanks :)
I'll try to dig through the accumulated dirt to find something useful.
Don't hold your breath though ;-)
This is something you can play with as an example:
#declare F_HF_01 =
function {
image_map {
tga "MyImage.tga" //gamma 1.0
map_type 0
interpolate 2
warp {repeat x}
warp {repeat y}
rotate 90*x
scale 50
warp {
turbulence 0.5
octaves 2 //[6]
lambda 1 //[2]
omega 0.2 //[0.5]
scale 1/50
#declare P =
function {
F_HF_01(x, y, z).hf
- f_hetero_mf(x,y,z, 0.8, 2, 5, 0, 0.9, 2)*0.3
//- f_noise3d(x,y*2,z)*0.5
- f_agate(x,y,z)*0.01
height_field{
function 500, 500 {P((x-0.5)*MyXscale+0.5, 0, (y-0.5)*MyZscale+0.5)}
translate <-0.5, 0, -0.5>
scale <MyScale>
pigment {MyPigment}
This is from an old test scene of mine, partly based on an example by
Mike Williams.
