POV-Ray : Newsgroups : povray.binaries.images : Just dawdling Server Time
25 Jun 2026 09:39:40 EDT (-0400)
  Just dawdling (Message 61 to 70 of 70)
Subject: Re: Just dawdling
Date: 23 May 2016 08:55:22
Message: <5742fdba$1@news.povray.org>
Am 23.05.2016 um 09:19 schrieb Thomas de Groot:
> I agree with Kenneth: while the rules are there to be followed
> strictly... they need also to be broken when artistic needs call for it
> and yield interesting results.
I'd like to put it this way:
Rules are there to be respected -- every one of them, always, and
without exception.
But there is a difference between respect and obedience.
Date: 24 May 2016 02:46:51
Message: <5743f8db$1@news.povray.org>
> without exception.
Absolutely. While I /respect/ the rules in every traditional way and for
every traditional purpose, I certainly shall /disobey/ them if, for any
reason, I can reach my goal through another way.
And let us be frank: if you were not told in the example under scrutiny,
you would not know. :-)
Date: 24 May 2016 03:04:45
Message: <5743fd0d@news.povray.org>
On 23-5-2016 14:45, Ive wrote:
> OK. While I still do not understand why the word "artistic" does popup
> within a context I consider a purely technical problem (it almost seems
> like a curse in these NG, as soon as someone mentions "gamma" inevitable
> someone else replies "but for artistic reasons" as if one would have
> anything to do with the other as I have tried to explain with the ironic
> Vermeer example).
In my view because creating an image is not just /only/ or /purely/ a
technical problem. To get the end result I want I shall not hesitate to
twist the rules. The technique is but a means to me towards an
"artistic" goal. That may sound very extreme but I can assure you that I
am very obedient towards the rules in general but I sometimes need to
punch them in the face :-)
> Anyway, I simply do not believe you have used the
> "straightforward/correct" way. So step by step: you are using a linear
> gradient to generate the depth-map image within POV-Ray. Right? Then you
> make sure that POV-Ray writes the depth-map image in linear color space
> by using the appropriate file output options (or, much easier use
> OpenEXR as output file format). Right? Then, when using the image again
> in POV-Ray you add gamma 1.0 to the image_map statement. Right? And in
> case you really need to edit the depth-map outside of POV-Ray you make
> sure that the used editor does not apply gamma correction when opening
> or saving the image file (hint: AFAIK this is not possible with Gimp,
> but can be done e.g. with Photoshop). Right?
I have done all that exactly to prescription (except I forgot about exr
indeed) and initially have not edited the image, and still it does not
give the result I want. My solution now would be to forget about most of
the head and concentrate the output exclusively to the face. It would
not matter as only the central part of the image is important for the
final isosurface. I have not tried that thoroughly yet but I will.
> Anything else will give you an distorted result and/or a loss of quickly
> estimated 85% of detail information.
Agreed.
>> I, modern Vermeer, do not paint the earring but glue the photograph of
>> one in its place (collage) :-)
> This *is* called artistic nowadays I guess, but this is certainly not my
> field of expertise.
Nor mine really but the field is larger than what we may consider
familiar or appropriate. The ready-mades of Surrealism can either be
considered brilliant concepts or a hoax.
Subject: Re: Just dawdling (from the stake)
Date: 24 May 2016 03:49:57
Message: <574407a5@news.povray.org>
Before I am condemned to the stake, here are my latest results, using an
exr depth_map (attached).
Two attached result images: SB_rockhead1a with, in the corresponding
section:
exr "Mapping_test.exr" gamma 1.0 interpolate 2
and SB_rockhead1b with, in the corresponding section:
exr "Mapping_test.exr" gamma 3.0 interpolate 2
The latest of course is what I want. I plead innocent M'Lord.
Download 'mapping_test.exr.dat' (126 KB) Download 'sb_rockhead1a.png' (410 KB) Download 'sb_rockhead1b.png' (366 KB)
Preview of image 'sb_rockhead1a.png'
Preview of image 'sb_rockhead1b.png'
Date: 24 May 2016 04:41:48
Message: <574413cc$1@news.povray.org>
> section:
Change your plea to not guilty you are innocent. :-P
I prefer the gamma 3.0 image.
I did some experimenting with images and gamma using PaintShop Pro (does
not auto gamma correct) and height fields.
Changing the gamma in the image changes the position of where the detail
is brought out. Or so it seems to me.
If that is the aim then it is a bonus that it can be done inside
Pov-Ray. Rather than using an external process that will slowdown the
workflow.
I will not let ignorance stand in the way of opening my gob.
Regards
Date: 24 May 2016 07:19:56
Message: <574438dc$1@news.povray.org>
>> section:
Oups, yes, that would be more correct indeed!
> workflow.
Exactly. I prefer not to mess with external processes and in this case
the final result can be controlled better inside POV-Ray.
Date: 24 May 2016 07:46:51
Message: <57443f2b$1@news.povray.org>
I tend to change the image but that is because of the tools I use. In
this instance the image is being used as a data source, to be
manipulated. So I don't see that there is a problem. Colour to position,
no break in the photorealism rules, there. ;)
Regards
Date: 25 May 2016 02:42:12
Message: <57454944$1@news.povray.org>
The problem is in the eye of the beholder :-)
Date: 25 May 2016 04:45:33
Message: <5745662d$1@news.povray.org>
And that problem would be a "beam"?
Sorry, I could not resist. :)
Regards
Date: 25 May 2016 07:21:52
Message: <57458ad0$1@news.povray.org>
Lol! I don't know. Too many rays in the Pov I guess.
