POV-Ray : Newsgroups : povray.binaries.images : concentric blobs clouds Server Time
20 May 2024 14:15:01 EDT (-0400)
  concentric blobs clouds (Message 57 to 66 of 66)
Subject: Re: concentric blobs clouds
Date: 4 May 2016 01:53:24
Message: <57298e54@news.povray.org>
Thanks, Thomas, John... see if these cirrus look better.
jaime
Download 'ocean-22c.jpg' (142 KB)
Preview of image 'ocean-22c.jpg'
Date: 4 May 2016 02:57:01
Message: <57299d3d$1@news.povray.org>
The wizard did it again! :-)
Yes, that is much, much better.
Date: 4 May 2016 05:47:44
Message: <5729c540@news.povray.org>
> jaime
You're not supposed to use a camera ;-)
Much better. Good work.
John
Protect the Earth
It was not given to you by your parents
You hold it in trust for your children
Date: 4 May 2016 08:07:23
Message: <5729e5fb@news.povray.org>
Am 04.05.2016 um 07:53 schrieb Jaime Vives Piqueres:
Something's still odd about this. Can't put my finger on it though.
Maybe thick low-hanging cumulus together with cirrus is a weather
situation we don't normally see?
Maybe there's a 3D-component to your cirrus clouds, whereas in reality
they seem to be quite flat?
Date: 4 May 2016 12:28:58
Message: <572a234a@news.povray.org>
> jaime
Usualy, cirrus clouds looks rather flat due to their altitude and their
small vertical extent.
My take would be to use a plane or very large, somewhat flattened,
sphere and use an image_map. Just be sure to set that to no_shadow.
Anyway, normaly, cirrus don't cast noticeable shadows as they are so thin.
Personaly, I'v seen some cases where you have cirrus above some other
clouds formations. Even cirrus above other cirrus, in this case, it's
usualy strato-cirrus above cirrus.
Date: 4 May 2016 16:45:44
Message: <572a5f78@news.povray.org>
   Well, it's not really that strange to have cirrus over cumulus, tough
most of the time there is a clear sky over them.
> reality they seem to be quite flat?
   The media shell is very thin, so I think that's not the problem. I
think it was the fact that I forgot to map them spherically, so they
don't look to be as high as they should.
jaime
Date: 4 May 2016 16:47:21
Message: <572a5fd9@news.povray.org>
> their small vertical extent. My take would be to use a plane or very
> large, somewhat flattened, sphere and use an image_map. Just be sure
> to set that to no_shadow. Anyway, normaly, cirrus don't cast
   I tried first the image map, but it was hard to match the lighting on
the photo with the sun on the scene, so I opted to use the photo as a
pattern for scattering media.
>  clouds formations.
   Me too...
jaime
Date: 22 Feb 2018 15:56:25
Message: <5a8f2e79@news.povray.org>
On 4/28/2016 10:52 AM, Simon J. Cambridge wrote:
> Jaime Vives Piqueres <jai### [at] ignoranciaorg> wrote:
>>> I ended up using a single containing object (box or plane) and then filling it
>>> with a skewed y-gradient density to get a flat bottom and then adding a mixture
>>> of wrinkles, bozo and crackle (form<1, 0, 0>) to try to approximate fluffy tops.
>>> Some of my images over at www.landofthefirst.com were created using this. I am
>>> still not 100% happy with them.
>>     The ones at Othil Homtoh look very nice...
>> jaime
> Here is the code:
>      #macro SkyShell(minAlt, maxAlt, Int)
>          difference
>              sphere {<0, 0, 0> 1000000+maxAlt}
>              sphere {<0, 0, 0> 1000000+minAlt}
>              hollow
>              texture {pigment {color rgbf 1}}
>              interior {Int}
>              translate <0, -1000000, 0>
>      #end
>      SkyShell(4000, 5000,
>          interior {
>              media {
>                  method 3
>                  samples 20
>                  scattering {2, color rgb 0.0075 extinction 1}
>                  density
>                      wrinkles
>                      scale <4000, 1000, 4000>
>                      warp { turbulence 2 }
>                      lambda 4
>                      color_map
>                          [0.00 color rgb 1.0]
>                          [0.50 color rgb 0.8]
>                          [0.55 color rgb 0.0]
>                          [1.00 color rgb 0.0]
>                      translate <-4000, 0, -1000>
>                  density
>                      gradient y
>                      scale 1000
>                      color_map
>                          [0.0  color rgb 0.00]
>                          [0.4  color rgb 1.00]
>                          [0.9  color rgb 1.00]
>                          [1.0  color rgb 0.00]
> I lied. It was concentric spheres!
> And nice solution for the artifacts! One to remember.
I am having trouble adapting this code. Here's what I have:
#declare lego_units = 20;	// LDU per foot
#declare earth_radius	= 20900000 * lego_units;
#declare earth_circum	= floor(2 * pi * earth_radius / 640) * 640;
#declare earth_radius	= earth_circum/2/pi;
#declare cloud_min_radius	= 6000 * lego_units;
#declare cloud_max_radius	= 9000 * lego_units;
	#local inner_radius = earth_radius + cloud_min_radius;
	#local outer_radius = earth_radius + cloud_max_radius;
	#local bound_radius = sin(acos(earth_radius/outer_radius)) * outer_radius;
	#local cloud_scale = 1;
	#local cloud_media = media
         method 3
         samples 20
         density
             wrinkles
             scale outer_radius * 300 * <1,1/4,1>
             lambda 4
             color_map
         density
             gradient y
             scale (cloud_max_radius - cloud_min_radius)
             color_map
		scale 1
	#local cloud_sphere = difference
		sphere {0, outer_radius}
		sphere {0, inner_radius}
//		bounded_by {cylinder {<0,-earth_radius,0,>, <0,-outer_radius,0,>,
bound_radius}}
		hollow
		material
			texture {pigment {color srgbft <1,1,1,0,1>}}
			interior
				media {cloud_media}
			scale cloud_scale
		translate +y * earth_radius
	object {cloud_sphere}
However, the effect is very grainy and dark. If I continue to scale it
upward, it turns nearly black. If I scale it downward, I can't see the
clouds any more. Does anyone know what I am doing wrong? Thanks.
Mike
Download 'wrapper_townview_normal.png' (1118 KB)
Preview of image 'wrapper_townview_normal.png'
Date: 22 Feb 2018 17:00:56
Message: <5a8f3d98$1@news.povray.org>
> Mike
Never mind. I think I have a handle on it.
Mike
Date: 22 Feb 2018 18:39:02
Message: <5a8f5496$1@news.povray.org>
On 5/3/2016 6:38 AM, Jaime Vives Piqueres wrote:
> Latest development:
> + new and improved cumulus shapes using trace() over a rough base shape.
> There are 10 different clouds using 500 blob components each one.
> + added cirrus layer using a panoramic photograph of real clouds as
> pattern for the media density (had to "cheat" because I could not find
> any convincing pattern).
> jaime
Does anyone have any actual code for these poofy clouds? They look so nice!
Mike
