POV-Ray : Newsgroups : povray.binaries.images : concentric blobs clouds Server Time
27 May 2026 14:05:41 EDT (-0400)
  concentric blobs clouds (Message 41 to 50 of 66)
Subject: Re: concentric blobs clouds
Date: 28 Apr 2016 16:25:24
Message: <572271b4@news.povray.org>
> Jaime, glad my suggestion worked well. Honestly I nearly didn't say anything, I
> thought it was too obvious and that you were bound to have tried it already! I
> shall wheel out random suggestions more often in that case :)
   Nothing is too obvious, at least if I'm involved...
jaime
Date: 30 Apr 2016 07:28:11
Message: <572496cb@news.povray.org>
On 28-4-2016 12:59, Jaime Vives Piqueres wrote:
>    BTW, I've just found a way to avoid the "bottom" problem with df3
> clouds:
It makes for different types of clouds of course. Left image is the
original use of the df3 files as densities; right used as pigment
patterns and with a gradient y density.
I had to substantially increase samples to eliminate artifacts. While
left I could get away with samples 10, on the right - to keep on the
safe side - I used samples 100. I probably could easily get away with
samples 50 though.
Download 'my_makecloud2_test_day.png' (852 KB)
Preview of image 'my_makecloud2_test_day.png'
Date: 30 Apr 2016 12:26:10
Message: <5724dca2$1@news.povray.org>
> samples 50 though.
   That's strange... I'm getting good results with just 16 samples.
jaime
Date: 30 Apr 2016 12:29:43
Message: <5724dd77@news.povray.org>
Am 30.04.2016 um 18:26 schrieb Jaime Vives Piqueres:
>> samples 50 though.
Different version?
Media sampling method 3 had various bogosities until somewhen between
3.7.0 and today.
Date: 30 Apr 2016 13:10:00
Message: <web.5724e5f85193772e87fca9f40@news.povray.org>
How do you achieve the atmospheric haze effect?
Date: 1 May 2016 02:47:24
Message: <5725a67c$1@news.povray.org>
That is a fog. The scene is Gilles Tran's.
Date: 1 May 2016 02:52:26
Message: <5725a7aa$1@news.povray.org>
This is basically what I do; most other details are Gilles' original
settings (more or less):
   #declare P_cloud2_1 =
   pigment {density_file df3 "cloud2_1.df3"
     lambda 3
     omega 0.6
     interpolate 1
     translate -0.5
     scale <1, -1, 1>
   #declare Cloud1 =
   box {-0.5,0.5
     texture {pigment {Clear} finish {ambient 0 diffuse 0}}
     hollow
     interior {
       media {
         scattering {1, C_Sun*0.006 extinction 0.25}
         intervals 1
         samples 100, 1000
         density {
           gradient y
           density_map {
             [0 pigment_pattern {P_cloud2_1}
                turbulence Turbulence*0.1
             [1 pigment_pattern {P_cloud2_1}
                turbulence Turbulence*2
     scale <4/3,1,1>
Date: 1 May 2016 03:12:57
Message: <5725ac79$1@news.povray.org>
Sorry, forgot to mention: version 3.7.1 alpha (blablabla) +av123
Date: 1 May 2016 03:35:12
Message: <5725b1b0$1@news.povray.org>
   The only notable difference I see is that I'm using scattering type 2
with default extinction.
jaime
Date: 1 May 2016 04:32:04
Message: <5725bf04@news.povray.org>
The solution was straightforward (see also image):
   #declare Cloud1 =
   box {-0.5,0.5
     hollow
     interior {
       media {
         intervals 1
         samples 50, 1000
         density {
           gradient y
           density_map {
                scale 50 warp {turbulence 0.1} scale 1/50
                scale 50 warp {turbulence 2} scale 1/50
     scale <4/3,1,1>
I shall try your scattering now.
Download 'my_makecloud2_test_day_2016.png' (391 KB)
Preview of image 'my_makecloud2_test_day_2016.png'
