POV-Ray : Newsgroups : povray.binaries.images : Inversion Server Time
27 May 2026 11:22:49 EDT (-0400)
  Inversion (Message 21 to 24 of 24)
Subject: Re: Inversion
Date: 11 Apr 2016 17:05:31
Message: <570c119b$1@news.povray.org>
On 04/11/2016 12:13 PM, Jaime Vives Piqueres wrote:
> El 11/04/16 a las 08:50, Thomas de Groot escribió:
>> What lame excuses! :-)
>     No, really... my back hurts now, as I had to be laying on the groun
d
> almost 2 hours to remove the obstruction on the drain pump. And my brai
n
> hurts too, after some more hours fiddling with the derivatives result t
o
> convert them into an usable pattern.
>> I am curious about the foam pattern. I have tried some ideas of my own
>> yesterday but to no conclusive results.
>     I will publish the code soon, but here it is an extract:
> // the derivatives
> #declare EPSILON = 1e-4;
> #declare
> f1x=function{(f_water(x+EPSILON,y,0)-f_water(x-EPSILON,y,0))/2*EPSILO
N}
> #declare
> f1y=function{(f_water(x,y+EPSILON,0)-f_water(x,y-EPSILON,0))/2*EPSILO
N}
> #declare f2x=function{(f1x(x+EPSILON,y,0)-f1x(x-EPSILON,y,0))/2*EPSIL
ON}
> #declare f2y=function{(f1y(x,y+EPSILON,0)-f1y(x,y-EPSILON,0))/2*EPSIL
ON}
	Well strictly speaking, you're missing a pair of parentheses around the
2*EPSILON. They should make it easier to tweak your parameters (for one
thing you can probably replace the 1000000000 with 10 which makes for
less unwieldy values).
	That being said, the result you got here is pretty good. Keep up the
good work!
		Jerome
mailto:jeb### [at] freefr
http://jeberger.free.fr
Jabber: jeb### [at] jabberfr
Download 'us-ascii' (1 KB)
Date: 11 Apr 2016 17:31:13
Message: <570c17a1$1@news.povray.org>
Ouch! Corrected... but now the multiplier has to be around 0.0000005.
> good work!
   Thanks!
jaime
Date: 12 Apr 2016 12:40:51
Message: <570d2513$1@news.povray.org>
he
e
	BTW, it would probably be faster to replace your code with:
// Will probably need tweaking
#declare M=0.0000005;
#declare d2xpd2y=function{
   (f_water(x+EPSILON,y,0)+f_water(x-EPSILON,y,0)+
    f_water(x,y+EPSILON,0)+f_water(x,y-EPSILON,0)-
    4*f_water(x,y,0))/
   (EPSILON*EPSILON)
#declare selected=function{select(x,abs(x))}
#declare t_ocean=
texture{
  pigment_pattern{
    function{selected(d2xpd2y(x,y,0))*M,0)}
  texture_map{
    [0.0 t_water]
    [0.1 t_foam]
	This only calls f_water 5 times where your code called it 16 times...
		Jerome
Date: 12 Apr 2016 14:21:27
Message: <570d3ca7$1@news.povray.org>
>      4*f_water(x,y,0))/
>     (EPSILON*EPSILON)
> #declare t_ocean=
> texture{
>    pigment_pattern{
>    texture_map{
>      [0.0 t_water]
>      [0.1 t_foam]
   Yes, it seems to render noticeably faster... but I had to correct
some things:
     4*f_water(x,y,0))/
    (EPSILON*EPSILON)
#declare selected=function(x){select(x,abs(x),0)}
#declare t_ocean=
texture{
   pigment_pattern{
     function{selected(d2xpd2y(x,y,0))*M}
   texture_map{
     [0.0 t_water]
     [0.1 t_foam]
That works! Thanks!
jaime
