POV-Ray : Newsgroups : povray.binaries.images : The Colony Ship Server Time
27 May 2026 16:41:20 EDT (-0400)
  The Colony Ship (Message 24 to 33 of 73)
Subject: Re: The Colony Ship
Date: 11 Feb 2016 16:44:49
Message: <56bd00d1@news.povray.org>
Hmmm, maybe making an .hdr image is too difficult. Basically, what I
need is an image with a color flow from black through the sunrise colors
to white, and from white through the sunset colors to black. Then using
emission 1.0 or more. Maybe I can do this with a regular image, not
sure. Let's see.
Date: 11 Feb 2016 18:14:59
Message: <56bd15f3$1@news.povray.org>
Am 11.02.2016 um 22:28 schrieb Sven Littkowski:
> At the moment, I am using around 2,000 light sources for my ship inside.
> This is, to simulate a long stripe of light (5 km long) and with a white
> inside and sunset colors to the side.
> But I am considering to make the central cylinder along the middle axis
> much thicker, and to put an .hdr image around it, emitting light. This
> might MAYBE save me a lot of computing time.
I wouldn't expect that to speed up rendering; this would require the
first "bounce" of light to be computed via radiosity, which is primarily
designed for computing light coming from all around, but performs rather
poorly (read: exhibits artifacts unless you invest a lot of rendering
time) for light coming predominantly from a comparatively small region
of the surroundings.
My personal suggestion would be to use a long 1-dimensional area light
(or a number thereof) with area_illumination active, wrapped in a
filtering cylinder.
Date: 11 Feb 2016 18:16:26
Message: <56bd164a$1@news.povray.org>
Am 11.02.2016 um 22:44 schrieb Sven Littkowski:
> sure. Let's see.
Why not simply use a patterned pigment? I think there is some pattern
that does the trick out of the box, but if not, a cylindrical warp
should get you there.
Date: 11 Feb 2016 23:42:24
Message: <56bd62b0$1@news.povray.org>
Yes, absolutely right. And that is, what I am going to do as a first try
(emission).
But I like your other suggestion (area light, area illuminated,
filtering cylinder), too, and want to have a look into it. Though I
don't understand wrapped things and such. But this is all about seeing
new ways, and learning them. :-)
Is it possible to create various light nuances (from bright white
daylight to sunset colors to night black) this way?
Date: 12 Feb 2016 01:26:36
Message: <56bd7b1c@news.povray.org>
Improved Illumination
Our engineers have installed the new emission-based color_map system
which replaces the previously used 2,000 light sources. This has a vast
reduction in the light bill and a vast increase in render speed.
What's missing now, is the bluish atmosphere.
Download 'sl - colony ship i.png' (96 KB)
Preview of image 'sl - colony ship i.png'
Date: 12 Feb 2016 03:36:41
Message: <56bd9999@news.povray.org>
UPDATE
Habitat was filled with air.
Problem:
while it looks acceptably good on the daytime side, the sunset side
misses a lot of those colors, and the nighttime side is also wrong.
Please have a try on your own and help, if you got some ideas. Thanks.
Scene Code ---------------------------------------------------------
#version 3.7;
#include "macros.inc"
#include "shapes.inc"
#declare MyRadiosity             = on; // on or off
#declare MediumRadiosity         = on;
#declare FastRadiosity           = off;
#declare CameraDaytime           = on;
#declare CameraSunset            = off; // Problem: doesn't look like sunset
#declare CameraNighttime         = off; // Problem: doesn't look like sunset
#declare CameraOutside           = off;
global_settings
 #if(MyRadiosity)
  radiosity
   media on
   pretrace_start 0.08
   #if(FastRadiosity)
    pretrace_end   0.015
   #elseif(MediumRadiosity)
    pretrace_end   0.008
   #else
    pretrace_end   0.001
   count 400
   error_bound 0.75
   recursion_limit 1
 adc_bailout       0.0039
 ambient_light     rgb < 1.000, 1.000, 1.000 >
 assumed_gamma     1.000
 irid_wavelength   rgb < 0.250, 0.180, 0.140 >
 max_trace_level   5
 number_of_waves   10
 noise_generator   3
 charset           ascii
#default { pigment { rgb 1.0 } finish { ambient 0.0 specular 1.0 } }
#if(CameraDaytime)
camera // Daytime Position Inside
 location < 0.0, -1400.0, 100.0 >
 look_at  < 0.0, -1400.0, 200.0 >
 right 1.77*x
#elseif(CameraSunset)
camera // Sunset Position Inside
 location < 1400.0, 0.0, 100.0 >
 look_at  < 1400.0, 0.0, 200.0 >
 right 1.77*x
#elseif(CameraNighttime)
camera // Nighttime Position Inside
 location < 0.0, 1400.0, 100.0 >
 look_at  < 0.0, 1400.0, 200.0 >
 right 1.77*x
#elseif(CameraOutside)
camera // Outside
 location < -5000.0, 5000.0, -5000.0 >
 look_at < 0.0, 0.0, 0.0 >
 right 1.77*x
#declare Seed=seed(441);
#if(CameraOutside)
light_source
 < -10000.0, 10000.0, 10000.0 >
 color rgb < 1.0, 1.0, 1.0 >
#declare LightDistance = -253.1;
#declare LightWidth = 50.0;
#declare MyRadius = 5;
#declare MyTightness = 50;
#declare MyFalloff = 80;
#declare MyLightMultiplicator = 0.007;
#declare LightSectionHalf = union
 light_source { < 0.0, LightDistance, 0.0 > rgb < 1.00000, 0.98824,
0.88235 > * MyLightMultiplicator*05 spotlight point_at < 000.0, -1500.0,
0.0 > radius 10 tightness 10 falloff 20 rotate < 0.0, 0.0,  2.5 > }
0.88235 > * MyLightMultiplicator*05 spotlight point_at < 050.0, -1350.0,
0.88235 > * MyLightMultiplicator*05 spotlight point_at < 100.0, -0950.0,
0.88235 > * MyLightMultiplicator*05 spotlight point_at < 150.0, -0700.0,
0.88235 > * MyLightMultiplicator*05 spotlight point_at < 175.0, -0600.0,
0.0 > radius MyRadius tightness MyTightness falloff MyFalloff rotate <
0.0, 0.0,  5.0 > }
 light_source { < 0.0, LightDistance, 0.0 > rgb < 1.00000, 0.88627,
0.50196 > * MyLightMultiplicator*05 spotlight point_at < 200.0, -0550.0,
0.0, 0.0,  7.5 > }
 light_source { < 0.0, LightDistance, 0.0 > rgb < 1.00000, 0.69412,
0.28235 > * MyLightMultiplicator*04 spotlight point_at < 225.0, -0500.0,
0.0, 0.0, 10.0 > }
 light_source { < 0.0, LightDistance, 0.0 > rgb < 0.99608, 0.35686,
0.08627 > * MyLightMultiplicator*04 spotlight point_at < 250.0, -0450.0,
0.0, 0.0, 12.5 > }
 light_source { < 0.0, LightDistance, 0.0 > rgb < 0.76863, 0.27059,
0.05882 > * MyLightMultiplicator*04 spotlight point_at < 275.0, -0400.0,
0.0, 0.0, 15.0 > }
 light_source { < 0.0, LightDistance, 0.0 > rgb < 0.54902, 0.10980,
0.10980 > * MyLightMultiplicator*03 spotlight point_at < 300.0, -0350.0,
0.0, 0.0, 17.5 > }
 light_source { < 0.0, LightDistance, 0.0 > rgb < 0.43922, 0.09412,
0.16078 > * MyLightMultiplicator*03 spotlight point_at < 325.0, -0300.0,
0.0, 0.0, 20.0 > }
 light_source { < 0.0, LightDistance, 0.0 > rgb < 0.31373, 0.07843,
0.14902 > * MyLightMultiplicator*02 spotlight point_at < 350.0, -0250.0,
0.0, 0.0, 22.5 > }
 light_source { < 0.0, LightDistance, 0.0 > rgb < 0.15294, 0.04706,
0.10588 > * MyLightMultiplicator*02 spotlight point_at < 375.0, -0200.0,
0.0, 0.0, 25.0 > }
#declare LightSection = union
 object { LightSectionHalf scale <  1.0, 1.0, 1.0 > }
 object { LightSectionHalf scale < -1.0, 1.0, 1.0 > }
#declare RundeLight = 50.0;
#while(RundeLight<4950.0)
 object { LightSection  translate < 0.0, 0.0, RundeLight > }
 #declare RundeLight = RundeLight+50.0;
#macro
RoundCilinderSegment(StartHeight,EindHeight,Radius,StartHoek,EindHoek,Bevel,BevelHeight,MaxLength)
	#local Start=y*(StartHeight+Bevel);
	#local Eind=y*(EindHeight-Bevel);
	#local Start2=y*StartHeight;
	#local Eind2=y*EindHeight;
		#local StartHoek2=StartHoek+degrees(Bevel/Radius);
		#local EindHoek2=EindHoek-degrees(Bevel/Radius);
		#local TotaleLengte=radians(EindHoek-StartHoek)*(Radius+BevelHeight);
		#local Aantal=max(int(TotaleLengte/MaxLength),1);
		#local Tel=0;
		mesh {
			triangle {
				vrotate(<Radius,StartHeight,0>,y*StartHoek),
				vrotate(<Radius,EindHeight,0>,y*StartHoek),
				vrotate(<Radius+BevelHeight,StartHeight+Bevel,0>,y*StartHoek2)
			triangle {
				vrotate(<Radius+BevelHeight,EindHeight-Bevel,0>,y*StartHoek2),
			triangle {
				vrotate(<Radius,EindHeight,0>,y*StartHoek2),
			triangle {
				vrotate(<Radius+BevelHeight,StartHeight+Bevel,0>,y*StartHoek2),
				vrotate(<Radius,StartHeight,0>,y*StartHoek2)
			triangle {
				vrotate(<Radius,StartHeight,0>,y*EindHoek),
				vrotate(<Radius,EindHeight,0>,y*EindHoek),
				vrotate(<Radius+BevelHeight,StartHeight+Bevel,0>,y*EindHoek2)
			triangle {
				vrotate(<Radius+BevelHeight,EindHeight-Bevel,0>,y*EindHoek2),
			triangle {
				vrotate(<Radius,EindHeight,0>,y*EindHoek2),
			triangle {
				vrotate(<Radius+BevelHeight,StartHeight+Bevel,0>,y*EindHoek2),
				vrotate(<Radius,StartHeight,0>,y*EindHoek2)
			#while (Tel<Aantal)
				#local H1=StartHoek2+(EindHoek2-StartHoek2)*(Tel/Aantal);
				#local H2=StartHoek2+(EindHoek2-StartHoek2)*((Tel+1)/Aantal);
				#local P1=vrotate(<Radius+BevelHeight,StartHeight+Bevel,0>,y*H1);
				#local P2=vrotate(<Radius+BevelHeight,EindHeight-Bevel,0>,y*H1);
				#local P3=vrotate(<Radius+BevelHeight,EindHeight-Bevel,0>,y*H2);
				#local P4=vrotate(<Radius+BevelHeight,StartHeight+Bevel,0>,y*H2);
				#local N1=vrotate(x,y*H1);
				#local N2=vrotate(x,y*H2);
				smooth_triangle {P1,N1,P2,N1,P4,N2}
				smooth_triangle {P2,N1,P3,N2,P4,N2}
				//triangle {P1,P2,P4}
				//triangle {P2,P3,P4}
				#local P2B=vrotate(<Radius,EindHeight,0>,y*H1);
				#local P3B=vrotate(<Radius,EindHeight,0>,y*H2);
				triangle {P2,P2B,P3}
				triangle {P2B,P3B,P3}
				#local P2B=vrotate(<Radius,StartHeight,0>,y*H2);
				#local P3B=vrotate(<Radius,StartHeight,0>,y*H1);
				triangle {P2B,P1,P3B}
				triangle {P1,P4,P2B}
				#local Tel=Tel+1;
#macro Verlaag(X)
	#local R=X-(1+rand(Seed)*2.5);
	R
#macro
CilinderGreeble(StartHeight,EindHeight,Radius,StartHoek,EindHoek,Bevel,BevelHeight,MaxLength,Detail)
	#local Start=(StartHeight+Bevel);
	#local Eind=(EindHeight-Bevel);
	#local StartH=StartHoek+degrees(Bevel/Radius);
	#local EindH=EindHoek-degrees(Bevel/Radius);
	//cilindertjes:
	#local Aantal=rand(Seed)*Detail;
	#while (Aantal>0)
		#local Size=(Bevel*.01)+rand(Seed)*Bevel*.99*2;
		#local Hoek=StartH+(EindH-StartH)*rand(Seed);
		#local Hoogte=Start+(Eind-Start)*rand(Seed);
		#local Depth=BevelHeight/2+rand(Seed)*BevelHeight/2;
		superellipsoid {<1,.1+rand(Seed)*.3> rotate y*90  scale
<Depth,Size,Size> translate x*Radius rotate y*Hoek translate y*Hoogte}
		#local Aantal=Aantal-1;
	//vakjes:
	#while (Aantal>0)
		#local S=Start+(Eind-Start)*rand(Seed);
		#local E=S+(Eind-S)*rand(Seed);
		#local SH=StartH+(EindH-StartH)*rand(Seed);
		#local EH=SH+(EindH-SH)*rand(Seed);
		#local H=BevelHeight/2+rand(Seed)*BevelHeight/2;
		RoundCilinderSegment(S,E,Radius,SH,EH,Bevel/2,H,AantalStapjes)
	//verticale buisjes
	#while (Aantal>0)
		//#local EH=SH+(EindH-SH)*rand(Seed);
		#local H=(BevelHeight/2+rand(Seed)*BevelHeight/2)/2;
		//RoundCilinderSegment(S,E,Radius,SH,EH,Bevel/2,H,AantalStapjes)
		cylinder {y*S,y*E,H translate x*Radius rotate y*SH}
		sphere {y*S,H translate x*Radius rotate y*SH}
		sphere {y*E,H translate x*Radius rotate y*SH}
	//horizontale buisjes simuleren, toruskes zouden wsl te traag gaan
	#while (Aantal>0)
		#local H=min((Eind-S),H*2)/2;
		#local E=S+H*2;
		RoundCilinderSegment(S,E,Radius,SH,EH,H,H,AantalStapjes)
#macro
VerdeelCilinder(StartHeight,EindHeight,Radius,StartHoek,EindHoek,Diepte,Bevel,BevelHeight)
	#if (Diepte<0)
		#ifndef(Detail) #local Detail=5; #end
		#local H=rand(Seed)*BevelHeight;
		#ifndef(MaxSegmentLength) #local AantalStapjes=Bevel; //(eigenlijk de
maximale lengte van een segment)
		#else #local AantalStapjes= MaxSegmentLength; #end
RoundCilinderSegment(StartHeight,EindHeight,Radius,StartHoek,EindHoek,Bevel,H,AantalStapjes)
CilinderGreeble(StartHeight,EindHeight,Radius+H,StartHoek,EindHoek,Bevel,H,AantalStapjes,Detail)
	#else
		// eerst es checken of 't nie onvoorstelbaar ongelijk verdeeld is:
		#local Lengte=radians(EindHoek-StartHoek)*Radius;
		#local Hoogte=EindHeight-StartHeight;
		#local PercentageU=.5+(rand(Seed)-rand(Seed))*.5*.9;
		#local PercentageV=.5+(rand(Seed)-rand(Seed))*.5*.9;
		#local MidHeight=StartHeight+(EindHeight-StartHeight)*PercentageU;
		#local MidHoek=StartHoek+(EindHoek-StartHoek)*PercentageV;
		// als't 2 keer zo hoog als breed is (of nog hoger), dan ff enkel in
de hoogte bijsnijden:
		#if ((Hoogte>(Lengte*2))&(rand(Seed)>.125))
VerdeelCilinder(StartHeight,MidHeight,Radius,StartHoek,EindHoek,Verlaag(Diepte),Bevel,BevelHeight)
VerdeelCilinder(MidHeight,EindHeight,Radius,StartHoek,EindHoek,Verlaag(Diepte),Bevel,BevelHeight)
		// als't 2 keer lager dan breed is (of nog lager), dan ff enkel in de
breedte bijsnijden:
		#else
			#if (((Hoogte*2)<Lengte)&(rand(Seed)>.125))
VerdeelCilinder(StartHeight,EindHeight,Radius,StartHoek,MidHoek,Verlaag(Diepte),Bevel,BevelHeight)
VerdeelCilinder(StartHeight,EindHeight,Radius,MidHoek,EindHoek,Verlaag(Diepte),Bevel,BevelHeight)
			#else
VerdeelCilinder(StartHeight,MidHeight,Radius,StartHoek,MidHoek,Verlaag(Diepte),Bevel,BevelHeight)
VerdeelCilinder(MidHeight,EindHeight,Radius,StartHoek,MidHoek,Verlaag(Diepte),Bevel,BevelHeight)
VerdeelCilinder(StartHeight,MidHeight,Radius,MidHoek,EindHoek,Verlaag(Diepte),Bevel,BevelHeight)
VerdeelCilinder(MidHeight,EindHeight,Radius,MidHoek,EindHoek,Verlaag(Diepte),Bevel,BevelHeight)
//#include "textures.inc"
#declare HabitatOutside = union
 #declare Detail=5;
 #declare MaxSegmentLength=.1;
 VerdeelCilinder(-3,3,1,0,360,10,.002,.0075)
 cylinder {-3*y,3*y,1}
 //Metaal()
 rotate < 90.0, 0.0, 0.0 >
 translate < 0.0, 0.0, 3.0 >
 scale < 1.0*1600.0, 1.0*1600.0, (1.0/6.0)*5200.0 >
 translate < 0.0, 0.0, -100.0 >
#declare Backbone = union
 #declare Detail=5;
 //Metaal()
 scale < 750.0, 750.0, (1.0/6.0)*5000.0 >
 translate < 0.0, 0.0, 0.0 >
#declare MyLight = difference  // Backbone Light
 cylinder { < 0.0, 0.0, 0.0 > < 0.0, 0.0, 5000.0 > 760.0 }
 box { < -760.1, 0.0, -0.1 > <  760.1, 760.1, 5000.1 > }
 pigment
  gradient x
  color_map
   [ 0.00 rgb < 0.00000, 0.00000, 0.00000 > * 1 ]
   [ 0.05 rgb < 0.15294, 0.04706, 0.10588 > * 1 ]
   [ 0.10 rgb < 0.31373, 0.07843, 0.14902 > * 1 ]
   [ 0.30 rgb < 1.00000, 0.69412, 0.28235 > * 1 ]
   [ 0.425 rgb < 1.00000, 0.98824, 0.88235 >* 2 ]
   [ 0.575 rgb < 1.00000, 0.98824, 0.88235 >* 2 ]
   [ 0.70 rgb < 1.00000, 0.69412, 0.28235 > * 1 ]
   [ 0.90 rgb < 0.31373, 0.07843, 0.14902 > * 1 ]
   [ 0.95 rgb < 0.15294, 0.04706, 0.10588 > * 1 ]
   [ 1.00 rgb < 0.00000, 0.00000, 0.00000 > * 1 ]
  translate < -0.5, 0.0, 0.0 >
  scale < 1520.0, 1.0, 1.0 >
 finish { emission 1.0 }
 translate < 0.0, -10.0, 0.0 >
#declare MyAtmosphere = cylinder // Air
 < 0.0, 0.0,  0.0 > < 0.0, 0.0, 5000.0 > 1500.0
 pigment { rgbt < 1.0, 1.0, 1.0, 1.0 > }
 hollow
 interior
  fade_colour < 0.4, 0.66, 0.9 >
  fade_distance 5000.0
  fade_power 1001
  media
   emission 0.0005
   density
    gradient y
    density_map
     [ 0.0 rgb < 0.5, 0.7, 1.0 > * 0.1 ]
     [ 0.4 rgb < 0.5, 0.7, 1.0 > ]
     [ 0.5 rgb < 0.5, 0.7, 1.0 > ]
     [ 1.0 rgb < 0.0, 0.0, 0.0 > ]
    translate < 0.0, -0.5, 0.0 >
    scale < 3000.0, 3000.0, 1.0 >
//   absorption 1000.0
/*   scattering
    1
    < 0.5, 0.7, 1.0 >
    extinction 1.0
#declare Fn_1 = function(x,y,z)
 1-(-f_snoise3d(x*5,y*3,z*5)*0.8)
#declare TheLandscape = object
 HF_Cylinder( Fn_1, // Function,
                 0, // UseUVheight:  0 or 1
                 1, // UseUVtexture: 0 or 1
           <50,50>, // Resolution,
                 1, // Smooth: 0 or 1
                "", // FileName, ""=no file,
           <0,0,0>, // EndA,
         <0,1.5,0>, // EndB
              1.60 ,// Radius
               0.05  // Depth
 scale < 0.58, 0.67, 0.58 >
 scale < 1500.0, 1500.0, 2500.0 >
#declare MyLandscape = union
 object { TheLandscape scale < 1.0, 1.0,  1.0 > translate < 0.0, 0.0,
0000.0 > }
 object { TheLandscape scale < 1.0, 1.0, -1.0 > translate < 0.0, 0.0,
5000.0 > }
 pigment { rgb < 0.05, 0.25, 0.0 > }
 finish { emission 0.0 }
#declare MyWaterLevel = 1440.0;
#declare fn_pattern = function
 pattern { bozo scale 0.15 }
#declare fn_water = function
 z - fn_pattern(x, y, 0)*0.25
#declare MyWater = difference // Water
 cylinder { < 0.0, 0.0,  0.0 > < 0.0, 0.0, 5000.0 > 1500.0 }
 cylinder { < 0.0, 0.0, -0.1 > < 0.0, 0.0, 5000.1 > MyWaterLevel }
 material
  texture
   pigment { color rgbt < 0.2, 0.7, 0.3, 0.5 > }
   finish
    ambient 0.0
    diffuse 0.0
    emission 0.0
    reflection
     0.0, 1.0
     falloff 5
     fresnel on
    specular 0.4
    roughness 0.003
   normal
    function { f_ridged_mf(x, y, z, 0.1, 3.0, 7, 0.7, 0.7, 2) } 0.8
    scale 0.13
  interior
   ior 1.3
   fade_distance 10
   fade_power 1001
   fade_color < 0.8, 0.2, 0.2, 0.5 >
   media
//    absorption < 0.8, 0.6, 1.0, 0.5 >
    scattering
     3
     < 0.5, 0.65, 0.4 >
     extinction 1.0
 normal
  0.8
  scale < 0.13, 0.4, 0.13 >
object { HabitatOutside hollow }
object { Backbone hollow }
object { MyLight }
object { MyAtmosphere }
object { MyLandscape }
object { MyWater }
Download 'sl - colony ship i.png' (106 KB)
Date: 12 Feb 2016 03:44:18
Message: <56bd9b62$1@news.povray.org>
On 12-2-2016 9:35, Sven Littkowski wrote:
> UPDATE
Your atmosphere and habitat boundaries are exactly overlapping, showing
unwanted artefacts. Make the atmosphere cylinder a tiny bit larger (or
smaller) than the habitat.
Date: 12 Feb 2016 03:59:16
Message: <56bd9ee4$1@news.povray.org>
> Right now, I have to try to find out, how to create such an .hdr file.
> The wise Internet will tell me...
IIRC POV-ray has a limit of 128 light sources.
Mike
Date: 12 Feb 2016 08:14:02
Message: <56bdda9a$1@news.povray.org>
Am 12.02.2016 um 09:59 schrieb Mike Horvath:
IIRC you're wrong ;)
Date: 12 Feb 2016 08:15:54
Message: <56bddb0a$1@news.povray.org>
Am 12.02.2016 um 09:35 schrieb Sven Littkowski:
> UPDATE
> Problem:
As soon as you use media, you really need to use regular light sources.
