POV-Ray : Newsgroups : povray.binaries.images : The Colony Ship Server Time
28 Sep 2024 18:03:43 EDT (-0400)
  The Colony Ship (Message 21 to 30 of 73)
Subject: Re: The Colony Ship
Date: 9 Feb 2016 16:12:23
Message: <56ba5637@news.povray.org>
PLEASE PARTICIPATE
You see here the colors for the sunset part of the light. But what about
the morning light? At the moment, it is identical to our
sunset light. But in real life, it is not.
If you like, propose your own colors for the morning light. For that
purpose, I have attached my self-developed POV-Ray color mixer. And
below, see the existing Sunset code.
#declare LightSectionHalf = union
 light_source { < 0.0, LightDistance, 0.0 > rgb < 1.00000, 0.98824,
0.88235 > * MyLightMultiplicator*25 spotlight point_at < 000.0, -1500.0,
0.0 > radius 10 tightness 10 falloff 20 rotate < 0.0, 0.0,  2.5 > }
0.88235 > * MyLightMultiplicator*25 spotlight point_at < 050.0, -1350.0,
0.88235 > * MyLightMultiplicator*25 spotlight point_at < 100.0, -0950.0,
0.88235 > * MyLightMultiplicator*25 spotlight point_at < 150.0, -0700.0,
0.88235 > * MyLightMultiplicator*18 spotlight point_at < 175.0, -0600.0,
0.0 > radius MyRadius tightness MyTightness falloff MyFalloff rotate <
0.0, 0.0,  5.0 > }
 light_source { < 0.0, LightDistance, 0.0 > rgb < 1.00000, 0.88627,
0.50196 > * MyLightMultiplicator*15 spotlight point_at < 200.0, -0550.0,
0.0, 0.0,  7.5 > }
 light_source { < 0.0, LightDistance, 0.0 > rgb < 1.00000, 0.69412,
0.28235 > * MyLightMultiplicator*12 spotlight point_at < 225.0, -0500.0,
0.0, 0.0, 10.0 > }
 light_source { < 0.0, LightDistance, 0.0 > rgb < 0.99608, 0.35686,
0.08627 > * MyLightMultiplicator*09 spotlight point_at < 250.0, -0450.0,
0.0, 0.0, 12.5 > }
 light_source { < 0.0, LightDistance, 0.0 > rgb < 0.76863, 0.27059,
0.05882 > * MyLightMultiplicator*06 spotlight point_at < 275.0, -0400.0,
0.0, 0.0, 15.0 > }
 light_source { < 0.0, LightDistance, 0.0 > rgb < 0.54902, 0.10980,
0.10980 > * MyLightMultiplicator*04 spotlight point_at < 300.0, -0350.0,
0.0, 0.0, 17.5 > }
 light_source { < 0.0, LightDistance, 0.0 > rgb < 0.43922, 0.09412,
0.16078 > * MyLightMultiplicator*02 spotlight point_at < 325.0, -0300.0,
0.0, 0.0, 20.0 > }
 light_source { < 0.0, LightDistance, 0.0 > rgb < 0.31373, 0.07843,
0.14902 > * MyLightMultiplicator*00 spotlight point_at < 350.0, -0250.0,
0.0, 0.0, 22.5 > }
 light_source { < 0.0, LightDistance, 0.0 > rgb < 0.15294, 0.04706,
0.10588 > * MyLightMultiplicator*00 spotlight point_at < 375.0, -0200.0,
0.0, 0.0, 25.0 > }
Download 'sl - colony ship ib.png' (42 KB)
Preview of image 'sl - colony ship ib.png'
Date: 9 Feb 2016 16:15:18
Message: <56ba56e6@news.povray.org>
Here is the small Windows program I developed. It is a color picker for
POV-Ray. It is free, and please use it (if you like) for the sunrise
colors. Thanks for helping me.
Download 'povcolors.rar.dat' (174 KB)
Date: 11 Feb 2016 16:28:48
Message: <56bcfd10@news.povray.org>
At the moment, I am using around 2,000 light sources for my ship inside.
This is, to simulate a long stripe of light (5 km long) and with a white
inside and sunset colors to the side.
But I am considering to make the central cylinder along the middle axis
much thicker, and to put an .hdr image around it, emitting light. This
might MAYBE save me a lot of computing time.
Right now, I have to try to find out, how to create such an .hdr file.
The wise Internet will tell me...
Date: 11 Feb 2016 16:44:49
Message: <56bd00d1@news.povray.org>
Hmmm, maybe making an .hdr image is too difficult. Basically, what I
need is an image with a color flow from black through the sunrise colors
to white, and from white through the sunset colors to black. Then using
emission 1.0 or more. Maybe I can do this with a regular image, not
sure. Let's see.
Date: 11 Feb 2016 18:14:59
Message: <56bd15f3$1@news.povray.org>
Am 11.02.2016 um 22:28 schrieb Sven Littkowski:
I wouldn't expect that to speed up rendering; this would require the
first "bounce" of light to be computed via radiosity, which is primarily
designed for computing light coming from all around, but performs rather
poorly (read: exhibits artifacts unless you invest a lot of rendering
time) for light coming predominantly from a comparatively small region
of the surroundings.
My personal suggestion would be to use a long 1-dimensional area light
(or a number thereof) with area_illumination active, wrapped in a
filtering cylinder.
Date: 11 Feb 2016 18:16:26
Message: <56bd164a$1@news.povray.org>
Am 11.02.2016 um 22:44 schrieb Sven Littkowski:
> sure. Let's see.
Why not simply use a patterned pigment? I think there is some pattern
that does the trick out of the box, but if not, a cylindrical warp
should get you there.
Date: 11 Feb 2016 23:42:24
Message: <56bd62b0$1@news.povray.org>
Yes, absolutely right. And that is, what I am going to do as a first try
(emission).
But I like your other suggestion (area light, area illuminated,
filtering cylinder), too, and want to have a look into it. Though I
don't understand wrapped things and such. But this is all about seeing
new ways, and learning them. :-)
Is it possible to create various light nuances (from bright white
daylight to sunset colors to night black) this way?
Date: 12 Feb 2016 01:26:36
Message: <56bd7b1c@news.povray.org>
Improved Illumination
Our engineers have installed the new emission-based color_map system
which replaces the previously used 2,000 light sources. This has a vast
reduction in the light bill and a vast increase in render speed.
What's missing now, is the bluish atmosphere.
Download 'sl - colony ship i.png' (96 KB)
Preview of image 'sl - colony ship i.png'
Date: 12 Feb 2016 03:36:41
Message: <56bd9999@news.povray.org>
UPDATE
Habitat was filled with air.
Problem:
while it looks acceptably good on the daytime side, the sunset side
misses a lot of those colors, and the nighttime side is also wrong.
Please have a try on your own and help, if you got some ideas. Thanks.
Scene Code ---------------------------------------------------------
#version 3.7;
#include "macros.inc"
#include "shapes.inc"
#declare MyRadiosity             = on; // on or off
#declare MediumRadiosity         = on;
#declare FastRadiosity           = off;
#declare CameraDaytime           = on;
#declare CameraSunset            = off; // Problem: doesn't look like sunset
#declare CameraNighttime         = off; // Problem: doesn't look like sunset
#declare CameraOutside           = off;
global_settings
 #if(MyRadiosity)
  radiosity
   media on
   pretrace_start 0.08
   #if(FastRadiosity)
    pretrace_end   0.015
   #elseif(MediumRadiosity)
    pretrace_end   0.008
   #else
    pretrace_end   0.001
   count 400
   error_bound 0.75
   recursion_limit 1
 adc_bailout       0.0039
 ambient_light     rgb < 1.000, 1.000, 1.000 >
 assumed_gamma     1.000
 irid_wavelength   rgb < 0.250, 0.180, 0.140 >
 max_trace_level   5
 number_of_waves   10
 noise_generator   3
 charset           ascii
#default { pigment { rgb 1.0 } finish { ambient 0.0 specular 1.0 } }
#if(CameraDaytime)
camera // Daytime Position Inside
 location < 0.0, -1400.0, 100.0 >
 look_at  < 0.0, -1400.0, 200.0 >
 right 1.77*x
#elseif(CameraSunset)
camera // Sunset Position Inside
 location < 1400.0, 0.0, 100.0 >
 look_at  < 1400.0, 0.0, 200.0 >
 right 1.77*x
#elseif(CameraNighttime)
camera // Nighttime Position Inside
 location < 0.0, 1400.0, 100.0 >
 look_at  < 0.0, 1400.0, 200.0 >
 right 1.77*x
#elseif(CameraOutside)
camera // Outside
 location < -5000.0, 5000.0, -5000.0 >
 look_at < 0.0, 0.0, 0.0 >
 right 1.77*x
#declare Seed=seed(441);
#if(CameraOutside)
light_source
 < -10000.0, 10000.0, 10000.0 >
 color rgb < 1.0, 1.0, 1.0 >
#declare LightDistance = -253.1;
#declare LightWidth = 50.0;
#declare MyRadius = 5;
#declare MyTightness = 50;
#declare MyFalloff = 80;
#declare MyLightMultiplicator = 0.007;
0.88235 > * MyLightMultiplicator*05 spotlight point_at < 000.0, -1500.0,
0.88235 > * MyLightMultiplicator*05 spotlight point_at < 050.0, -1350.0,
0.88235 > * MyLightMultiplicator*05 spotlight point_at < 100.0, -0950.0,
0.88235 > * MyLightMultiplicator*05 spotlight point_at < 150.0, -0700.0,
0.88235 > * MyLightMultiplicator*05 spotlight point_at < 175.0, -0600.0,
0.0, 0.0,  5.0 > }
0.50196 > * MyLightMultiplicator*05 spotlight point_at < 200.0, -0550.0,
0.0, 0.0,  7.5 > }
0.28235 > * MyLightMultiplicator*04 spotlight point_at < 225.0, -0500.0,
0.0, 0.0, 10.0 > }
0.08627 > * MyLightMultiplicator*04 spotlight point_at < 250.0, -0450.0,
0.0, 0.0, 12.5 > }
0.05882 > * MyLightMultiplicator*04 spotlight point_at < 275.0, -0400.0,
0.0, 0.0, 15.0 > }
0.10980 > * MyLightMultiplicator*03 spotlight point_at < 300.0, -0350.0,
0.0, 0.0, 17.5 > }
0.16078 > * MyLightMultiplicator*03 spotlight point_at < 325.0, -0300.0,
0.0, 0.0, 20.0 > }
0.14902 > * MyLightMultiplicator*02 spotlight point_at < 350.0, -0250.0,
0.0, 0.0, 22.5 > }
0.10588 > * MyLightMultiplicator*02 spotlight point_at < 375.0, -0200.0,
0.0, 0.0, 25.0 > }
#declare LightSection = union
 object { LightSectionHalf scale <  1.0, 1.0, 1.0 > }
 object { LightSectionHalf scale < -1.0, 1.0, 1.0 > }
#declare RundeLight = 50.0;
#while(RundeLight<4950.0)
 object { LightSection  translate < 0.0, 0.0, RundeLight > }
 #declare RundeLight = RundeLight+50.0;
#macro
RoundCilinderSegment(StartHeight,EindHeight,Radius,StartHoek,EindHoek,Bevel,BevelHeight,MaxLength)
	#local Start=y*(StartHeight+Bevel);
	#local Eind=y*(EindHeight-Bevel);
	#local Start2=y*StartHeight;
	#local Eind2=y*EindHeight;
		#local StartHoek2=StartHoek+degrees(Bevel/Radius);
		#local EindHoek2=EindHoek-degrees(Bevel/Radius);
		#local TotaleLengte=radians(EindHoek-StartHoek)*(Radius+BevelHeight);
		#local Aantal=max(int(TotaleLengte/MaxLength),1);
		#local Tel=0;
		mesh {
			triangle {
				vrotate(<Radius,StartHeight,0>,y*StartHoek),
				vrotate(<Radius,EindHeight,0>,y*StartHoek),
				vrotate(<Radius+BevelHeight,StartHeight+Bevel,0>,y*StartHoek2)
			triangle {
				vrotate(<Radius+BevelHeight,EindHeight-Bevel,0>,y*StartHoek2),
			triangle {
				vrotate(<Radius,EindHeight,0>,y*StartHoek2),
			triangle {
				vrotate(<Radius+BevelHeight,StartHeight+Bevel,0>,y*StartHoek2),
				vrotate(<Radius,StartHeight,0>,y*StartHoek2)
			triangle {
				vrotate(<Radius,StartHeight,0>,y*EindHoek),
				vrotate(<Radius,EindHeight,0>,y*EindHoek),
				vrotate(<Radius+BevelHeight,StartHeight+Bevel,0>,y*EindHoek2)
			triangle {
				vrotate(<Radius+BevelHeight,EindHeight-Bevel,0>,y*EindHoek2),
			triangle {
				vrotate(<Radius,EindHeight,0>,y*EindHoek2),
			triangle {
				vrotate(<Radius+BevelHeight,StartHeight+Bevel,0>,y*EindHoek2),
				vrotate(<Radius,StartHeight,0>,y*EindHoek2)
			#while (Tel<Aantal)
				#local H1=StartHoek2+(EindHoek2-StartHoek2)*(Tel/Aantal);
				#local H2=StartHoek2+(EindHoek2-StartHoek2)*((Tel+1)/Aantal);
				#local P1=vrotate(<Radius+BevelHeight,StartHeight+Bevel,0>,y*H1);
				#local P2=vrotate(<Radius+BevelHeight,EindHeight-Bevel,0>,y*H1);
				#local P3=vrotate(<Radius+BevelHeight,EindHeight-Bevel,0>,y*H2);
				#local P4=vrotate(<Radius+BevelHeight,StartHeight+Bevel,0>,y*H2);
				#local N1=vrotate(x,y*H1);
				#local N2=vrotate(x,y*H2);
				smooth_triangle {P1,N1,P2,N1,P4,N2}
				smooth_triangle {P2,N1,P3,N2,P4,N2}
				//triangle {P1,P2,P4}
				//triangle {P2,P3,P4}
				#local P2B=vrotate(<Radius,EindHeight,0>,y*H1);
				#local P3B=vrotate(<Radius,EindHeight,0>,y*H2);
				triangle {P2,P2B,P3}
				triangle {P2B,P3B,P3}
				#local P2B=vrotate(<Radius,StartHeight,0>,y*H2);
				#local P3B=vrotate(<Radius,StartHeight,0>,y*H1);
				triangle {P2B,P1,P3B}
				triangle {P1,P4,P2B}
				#local Tel=Tel+1;
#macro Verlaag(X)
	#local R=X-(1+rand(Seed)*2.5);
	R
#macro
CilinderGreeble(StartHeight,EindHeight,Radius,StartHoek,EindHoek,Bevel,BevelHeight,MaxLength,Detail)
	#local Start=(StartHeight+Bevel);
	#local Eind=(EindHeight-Bevel);
	#local StartH=StartHoek+degrees(Bevel/Radius);
	#local EindH=EindHoek-degrees(Bevel/Radius);
	//cilindertjes:
	#local Aantal=rand(Seed)*Detail;
	#while (Aantal>0)
		#local Size=(Bevel*.01)+rand(Seed)*Bevel*.99*2;
		#local Hoek=StartH+(EindH-StartH)*rand(Seed);
		#local Hoogte=Start+(Eind-Start)*rand(Seed);
		#local Depth=BevelHeight/2+rand(Seed)*BevelHeight/2;
		superellipsoid {<1,.1+rand(Seed)*.3> rotate y*90  scale
<Depth,Size,Size> translate x*Radius rotate y*Hoek translate y*Hoogte}
		#local Aantal=Aantal-1;
	//vakjes:
	#while (Aantal>0)
		#local S=Start+(Eind-Start)*rand(Seed);
		#local E=S+(Eind-S)*rand(Seed);
		#local SH=StartH+(EindH-StartH)*rand(Seed);
		#local EH=SH+(EindH-SH)*rand(Seed);
		#local H=BevelHeight/2+rand(Seed)*BevelHeight/2;
		RoundCilinderSegment(S,E,Radius,SH,EH,Bevel/2,H,AantalStapjes)
	//verticale buisjes
	#while (Aantal>0)
		//#local EH=SH+(EindH-SH)*rand(Seed);
		#local H=(BevelHeight/2+rand(Seed)*BevelHeight/2)/2;
		//RoundCilinderSegment(S,E,Radius,SH,EH,Bevel/2,H,AantalStapjes)
		cylinder {y*S,y*E,H translate x*Radius rotate y*SH}
		sphere {y*S,H translate x*Radius rotate y*SH}
		sphere {y*E,H translate x*Radius rotate y*SH}
	//horizontale buisjes simuleren, toruskes zouden wsl te traag gaan
	#while (Aantal>0)
		#local H=min((Eind-S),H*2)/2;
		#local E=S+H*2;
		RoundCilinderSegment(S,E,Radius,SH,EH,H,H,AantalStapjes)
#macro
VerdeelCilinder(StartHeight,EindHeight,Radius,StartHoek,EindHoek,Diepte,Bevel,BevelHeight)
	#if (Diepte<0)
		#ifndef(Detail) #local Detail=5; #end
		#local H=rand(Seed)*BevelHeight;
		#ifndef(MaxSegmentLength) #local AantalStapjes=Bevel; //(eigenlijk de
maximale lengte van een segment)
		#else #local AantalStapjes= MaxSegmentLength; #end
RoundCilinderSegment(StartHeight,EindHeight,Radius,StartHoek,EindHoek,Bevel,H,AantalStapjes)
CilinderGreeble(StartHeight,EindHeight,Radius+H,StartHoek,EindHoek,Bevel,H,AantalStapjes,Detail)
	#else
		// eerst es checken of 't nie onvoorstelbaar ongelijk verdeeld is:
		#local Lengte=radians(EindHoek-StartHoek)*Radius;
		#local Hoogte=EindHeight-StartHeight;
		#local PercentageU=.5+(rand(Seed)-rand(Seed))*.5*.9;
		#local PercentageV=.5+(rand(Seed)-rand(Seed))*.5*.9;
		#local MidHeight=StartHeight+(EindHeight-StartHeight)*PercentageU;
		#local MidHoek=StartHoek+(EindHoek-StartHoek)*PercentageV;
		// als't 2 keer zo hoog als breed is (of nog hoger), dan ff enkel in
de hoogte bijsnijden:
		#if ((Hoogte>(Lengte*2))&(rand(Seed)>.125))
VerdeelCilinder(StartHeight,MidHeight,Radius,StartHoek,EindHoek,Verlaag(Diepte),Bevel,BevelHeight)
VerdeelCilinder(MidHeight,EindHeight,Radius,StartHoek,EindHoek,Verlaag(Diepte),Bevel,BevelHeight)
		// als't 2 keer lager dan breed is (of nog lager), dan ff enkel in de
breedte bijsnijden:
		#else
			#if (((Hoogte*2)<Lengte)&(rand(Seed)>.125))
VerdeelCilinder(StartHeight,EindHeight,Radius,StartHoek,MidHoek,Verlaag(Diepte),Bevel,BevelHeight)
VerdeelCilinder(StartHeight,EindHeight,Radius,MidHoek,EindHoek,Verlaag(Diepte),Bevel,BevelHeight)
			#else
VerdeelCilinder(StartHeight,MidHeight,Radius,StartHoek,MidHoek,Verlaag(Diepte),Bevel,BevelHeight)
VerdeelCilinder(MidHeight,EindHeight,Radius,StartHoek,MidHoek,Verlaag(Diepte),Bevel,BevelHeight)
VerdeelCilinder(StartHeight,MidHeight,Radius,MidHoek,EindHoek,Verlaag(Diepte),Bevel,BevelHeight)
VerdeelCilinder(MidHeight,EindHeight,Radius,MidHoek,EindHoek,Verlaag(Diepte),Bevel,BevelHeight)
//#include "textures.inc"
#declare HabitatOutside = union
 #declare Detail=5;
 #declare MaxSegmentLength=.1;
 VerdeelCilinder(-3,3,1,0,360,10,.002,.0075)
 cylinder {-3*y,3*y,1}
 //Metaal()
 rotate < 90.0, 0.0, 0.0 >
 translate < 0.0, 0.0, 3.0 >
 scale < 1.0*1600.0, 1.0*1600.0, (1.0/6.0)*5200.0 >
 translate < 0.0, 0.0, -100.0 >
#declare Backbone = union
 #declare Detail=5;
 //Metaal()
 scale < 750.0, 750.0, (1.0/6.0)*5000.0 >
 translate < 0.0, 0.0, 0.0 >
#declare MyLight = difference  // Backbone Light
 cylinder { < 0.0, 0.0, 0.0 > < 0.0, 0.0, 5000.0 > 760.0 }
 box { < -760.1, 0.0, -0.1 > <  760.1, 760.1, 5000.1 > }
 pigment
  gradient x
  color_map
   [ 0.00 rgb < 0.00000, 0.00000, 0.00000 > * 1 ]
   [ 0.05 rgb < 0.15294, 0.04706, 0.10588 > * 1 ]
   [ 0.10 rgb < 0.31373, 0.07843, 0.14902 > * 1 ]
   [ 0.30 rgb < 1.00000, 0.69412, 0.28235 > * 1 ]
   [ 0.425 rgb < 1.00000, 0.98824, 0.88235 >* 2 ]
   [ 0.575 rgb < 1.00000, 0.98824, 0.88235 >* 2 ]
   [ 0.70 rgb < 1.00000, 0.69412, 0.28235 > * 1 ]
   [ 0.90 rgb < 0.31373, 0.07843, 0.14902 > * 1 ]
   [ 0.95 rgb < 0.15294, 0.04706, 0.10588 > * 1 ]
   [ 1.00 rgb < 0.00000, 0.00000, 0.00000 > * 1 ]
  translate < -0.5, 0.0, 0.0 >
  scale < 1520.0, 1.0, 1.0 >
 finish { emission 1.0 }
 translate < 0.0, -10.0, 0.0 >
#declare MyAtmosphere = cylinder // Air
 < 0.0, 0.0,  0.0 > < 0.0, 0.0, 5000.0 > 1500.0
 pigment { rgbt < 1.0, 1.0, 1.0, 1.0 > }
 hollow
 interior
  fade_colour < 0.4, 0.66, 0.9 >
  fade_distance 5000.0
  fade_power 1001
  media
   emission 0.0005
   density
    gradient y
    density_map
     [ 0.0 rgb < 0.5, 0.7, 1.0 > * 0.1 ]
     [ 0.4 rgb < 0.5, 0.7, 1.0 > ]
     [ 0.5 rgb < 0.5, 0.7, 1.0 > ]
     [ 1.0 rgb < 0.0, 0.0, 0.0 > ]
    translate < 0.0, -0.5, 0.0 >
    scale < 3000.0, 3000.0, 1.0 >
//   absorption 1000.0
/*   scattering
    1
    < 0.5, 0.7, 1.0 >
    extinction 1.0
#declare Fn_1 = function(x,y,z)
 1-(-f_snoise3d(x*5,y*3,z*5)*0.8)
#declare TheLandscape = object
 HF_Cylinder( Fn_1, // Function,
                 0, // UseUVheight:  0 or 1
                 1, // UseUVtexture: 0 or 1
           <50,50>, // Resolution,
                 1, // Smooth: 0 or 1
                "", // FileName, ""=no file,
           <0,0,0>, // EndA,
         <0,1.5,0>, // EndB
              1.60 ,// Radius
               0.05  // Depth
 scale < 0.58, 0.67, 0.58 >
 scale < 1500.0, 1500.0, 2500.0 >
#declare MyLandscape = union
 object { TheLandscape scale < 1.0, 1.0,  1.0 > translate < 0.0, 0.0,
0000.0 > }
 object { TheLandscape scale < 1.0, 1.0, -1.0 > translate < 0.0, 0.0,
5000.0 > }
 pigment { rgb < 0.05, 0.25, 0.0 > }
 finish { emission 0.0 }
#declare MyWaterLevel = 1440.0;
#declare fn_pattern = function
 pattern { bozo scale 0.15 }
#declare fn_water = function
 z - fn_pattern(x, y, 0)*0.25
#declare MyWater = difference // Water
 cylinder { < 0.0, 0.0,  0.0 > < 0.0, 0.0, 5000.0 > 1500.0 }
 cylinder { < 0.0, 0.0, -0.1 > < 0.0, 0.0, 5000.1 > MyWaterLevel }
 material
  texture
   pigment { color rgbt < 0.2, 0.7, 0.3, 0.5 > }
   finish
    ambient 0.0
    diffuse 0.0
    emission 0.0
    reflection
     0.0, 1.0
     falloff 5
     fresnel on
    specular 0.4
    roughness 0.003
   normal
    function { f_ridged_mf(x, y, z, 0.1, 3.0, 7, 0.7, 0.7, 2) } 0.8
    scale 0.13
  interior
   ior 1.3
   fade_distance 10
   fade_power 1001
   fade_color < 0.8, 0.2, 0.2, 0.5 >
   media
//    absorption < 0.8, 0.6, 1.0, 0.5 >
    scattering
     3
     < 0.5, 0.65, 0.4 >
     extinction 1.0
 normal
  0.8
  scale < 0.13, 0.4, 0.13 >
object { HabitatOutside hollow }
object { Backbone hollow }
object { MyLight }
object { MyAtmosphere }
object { MyLandscape }
object { MyWater }
Download 'sl - colony ship i.png' (106 KB)
Date: 12 Feb 2016 03:44:18
Message: <56bd9b62$1@news.povray.org>
On 12-2-2016 9:35, Sven Littkowski wrote:
> UPDATE
Your atmosphere and habitat boundaries are exactly overlapping, showing
unwanted artefacts. Make the atmosphere cylinder a tiny bit larger (or
smaller) than the habitat.
