POV-Ray : Newsgroups : povray.binaries.images : Scattering media problem Server Time
25 Jun 2026 13:10:59 EDT (-0400)
  Scattering media problem (Message 15 to 24 of 24)
Subject: Re: Scattering media problem
Date: 10 Oct 2015 17:41:09
Message: <561985f5$1@news.povray.org>
Le 15-10-09 16:24, Stephen a écrit :
> On 10/9/2015 8:32 PM, Alain wrote:
>> Le 15-10-08 17:12, Stephen a écrit :
>>> On 10/8/2015 9:56 PM, Jörg 'Yadgar' Bleimann wrote:
>>>> I want to model my now-defunct bathroom scales
>>> Sorry I can't help with your media problem, Yadgar.
>>> But you reminded me of a jape I did a few years back.
>>> I had been working on a crane upgrading the load indicator. I took the
>>> old 100 ton scale and put it in my bathroom scales. My wife's screams
>>> could be heard from miles away.
>>> I did not know she could punch that hard. But it was worth it. ;-)
>> An 100 TON scale? In a bathroom? That's just plain mean !
> Bows :-)
> My wife is quite thin so it was an obvious joke.
> I also took a "Cold Work" permit book home as well, but chickened out
> giving that to her. She always had a list of jobs for me to do after
> being offshore for two weeks. In the end I thought that it was pushing it.
> In case you don't know UK electrical plugs and sockets look like this:
https://s-media-cache-ak0.pinimg.com/236x/5f/1b/a9/5f1ba98a5d187b3f733e8c867d8898eb.jpg
It's a standard socket, in the UK.
> It was fun watching my brother-in-law try to fit this plug into a
> standard socket.
http://www.flameport.com/electric_museum/plugs_13A_non_standard/walsall_gauge_13a_plug.jpg
The standard sockets in America are radicaly different from the standard
sockets in Europe whitch are different from those in Asia whitch are
different than...
I have a multi-standard adaptor. It have no less than 8 different plugs
for 8 regions of the world.
Date: 10 Oct 2015 19:40:15
Message: <5619a1df@news.povray.org>
Hi(gh)!
On 10.10.2015 04:53, Cousin Ricky wrote:
> I concur with Clipka and Alain.  Use fade_power 1001, fade_color, and
> fade_distance in the media block.  Absorbing media may be easier conceptually,
> but it is slower and (in my experience) artifact prone.
Now I added a (yet to be detailed further) plastic frame, replaced the
absorption media by the following:
     fade_color <0, 0.6, 0.35>
     fade_power 1001
     fade_distance 0.1
...but I wonder why the plastic parts below the glass pane are black now
(see attachment)! They should be of the same light grey as the side
parts, only slightly darkened by the glass...
See you in Khyberspace!
Yadgar
Download '2015-10-11 korona scales, take 35.jpg' (28 KB)
Preview of image '2015-10-11 korona scales, take 35.jpg'
Date: 10 Oct 2015 23:00:57
Message: <5619d0e9$1@news.povray.org>
> ....but I wonder why the plastic parts below the glass pane are black
> now (see attachment)! They should be of the same light grey as the side
Too low max_trace_level maybe?
Also, behaviour may differ depending on whether you make the glass and
plastic planes overlap, merely touch, or have a tiny gap.
Date: 11 Oct 2015 04:10:31
Message: <561a1977$1@news.povray.org>
> different than...
I know, I know. :-)
I've worked in more than a dozen different countries on every continent
except Antarctica. (Can't keep a job, it seems. ;-) )
I generally use a standard UK extension socket and replace its plug or
cable when I get there.
Regards
Date: 11 Oct 2015 06:45:13
Message: <561a3db9$1@news.povray.org>
Hi(gh)!
Meanwhile, I increased it to 10 - but still the plastic parts below the
glass are black!
Yes, I provided for a tiny gap... but it did not help!
Yadgar
Date: 11 Oct 2015 08:15:06
Message: <561a52ca$1@news.povray.org>
Hi(gh)!
This is how it should look:
http://img.dooyoo.de/DE_DE/orig/1/2/6/2/0/1262007.jpg
Yadgar
Date: 11 Oct 2015 13:17:15
Message: <561a999b$1@news.povray.org>
> Hi(gh)!
> glass are black!
<shrugs>
We'll probably need more information then.
Maybe you simply got the colour wrong?
Date: 11 Oct 2015 14:50:36
Message: <561aaf7c$1@news.povray.org>
Hi(gh)!
 > <shrugs>
O.k., here is the code:
// begin code
#version 3.7;
#include "glass.inc"
global_settings
   max_trace_level 10
// TEXTURES
#declare T_Grey_Matted_Plastic=
texture
   pigment { color rgb 0.7 }
   finish
     ambient 0.1
     diffuse 1
     brilliance 0.4
     phong 0.8
     phong_size 60
   normal
     granite
     turbulence 100
// MATERIALS
#declare M_PaneGlass=
material
   texture
     pigment
       color rgbft <0.99, 1, 0.99, 0.49, 0.49>
     finish { F_Glass5 }
   interior
     ior 1.52
     fade_power 1001
     fade_distance 0.1
light_source
   <0, 2.4, -0.5>
   color rgb 1
sky_sphere
   pigment
     gradient y
     color_map
       [0 rgb 1]
       [1 rgb 0]
/* plane
   y, 0
   texture
     pigment { color rgb 1 }
     finish { ambient 0.15 diffuse 1 brilliance 0.2 }
#declare Glass_Pane_Bevel_Cutoff =
box
   <-0.155, -0.001*sqrt(2)/2, -0.025>, <0.155, 0.001*sqrt(2)/2, 0.025>
#declare Glass_Pane =
difference
   box
     0, <0.28, 0.013, 0.3>
   object // upper front bevel
     rotate <315, 0, 0>
     translate <0.14, 0.013, 0>
   object // lower front bevel
     rotate <45, 0, 0>
     translate <0.14, 0, 0>
   object // upper right bevel
     rotate <45, 90, 0>
     translate <0.28, 0.013, 0.15>
   object // lower right bevel
     rotate <315, 90, 0>
     translate <0.28, 0, 0.15>
   object // upper left bevel
     rotate <45, -90, 0>
     translate <0, 0.013, 0.15>
   object // lower left bevel
     rotate <315, -90, 0>
     translate <0, 0, 0.15>
   object // upper back bevel
     rotate <45, 0, 0>
     translate <0.14, 0.013, 0.3>
   object // lower back bevel
     rotate <315, 0, 0>
     translate <0.14, 0, 0.3>
   hollow
#declare Frame_Corner_Base_Raw=
union
   box { 0, <0.00788, 0.02214, 0.06224> }
   difference
     cylinder { <0.00788, 0, 0.03112>, <0.00788, 0.02214, 0.03112>,
0.03112 }
     box { <-0.05, -0.01, -0.01>, <0.00788, 0.03, 0.07> }
#declare Plastic_Frame_Side_Part=
difference
   cylinder
     0, <0, 0, 0.302>, 1
     scale <0.02, 0.03056, 1>
   box
     <-0.05, -0.05, -0.01>, <0.05, 0, 0.31>
   box
     <0, -0.05, -0.01>, <0.05, 0.1, 0.31>
#declare Central_Unit_Block=
union
   cylinder { 0, <0, 0.02214, 0>, 0.03112 }
   box { <0, 0, -0.03112>, <0.07566, 0.02214, 0.03112> }
   cylinder { <0.07566, 0, 0>, <0.07566, 0.02214, 0>, 0.03112 }
#declare Fillet=
box
   0, <0.036, 0.009, 0.011>
#declare Plastic_Frame=
union
   object { Plastic_Frame_Side_Part }
   object { Frame_Corner_Base_Raw }
   object { Frame_Corner_Base_Raw  translate <0, 0, 0.23976>}
   object { Plastic_Frame_Side_Part rotate <0, 180, 0> translate <0.28,
0, 0.302>}
   object { Frame_Corner_Base_Raw rotate <0, 180, 0> translate <0.28, 0,
0.06224>}
0.302>}
   object { Central_Unit_Block translate <0.10217, 0, 0.27088> }
   object { Fillet translate <0.03718, 0.01314, 0.26538> }
   object { Fillet translate <0.20713, 0.01314, 0.26538> }
// 0.03236 x
// 0.009 y
// 0.011 z
object
   Glass_Pane
   material { M_PaneGlass }
   translate <0, 0.022141, 0>
object
   Plastic_Frame
   texture { T_Grey_Matted_Plastic }
#declare view=4;
camera
   #switch(view)
     #case (0)
       location <0.01, 0.015, -0.2>
       look_at <0.01, 0.015, 0.30>
     #break
     #case (1)
       location <0.14, 0.65, -0.7>
       look_at <0.14, 0.0125, 0.001>
     #break
     #case (2)
       location <0.95, 0.65, 0.15>
       look_at <0.14, 0.0065, 0.15>
     #break
     #case (3)
     #break
     #case (4)
       location <0.14, 1, 0.15>
       look_at <0.14, 0, 0.15>
     #break
   angle 40
// end code
Yadgar
Date: 13 Oct 2015 03:05:50
Message: <561cad4e@news.povray.org>
Looks like the gap between the frame and glass pane is too small. You
may want to use a different scale to increase your absolute scene size.
Date: 13 Oct 2015 18:01:28
Message: <561d7f38@news.povray.org>
Hi(gh)!
Yes, originally the gap was only 0.000001 POV units wide... I increased
this to 0.00016 POV units, and now it looks as it was meant to look (see
attachment)!
Yadgar
Download '2015-10-13 korona scales, take 36.jpg' (30 KB)
Preview of image '2015-10-13 korona scales, take 36.jpg'
