POV-Ray : Newsgroups : povray.binaries.images : screen.inc in 3.7 - strange differences in lighting! Server Time
21 Dec 2025 06:38:40 EST (-0500)
  screen.inc in 3.7 - strange differences in lighting! (Message 1 to 10 of 13)
Subject: screen.inc in 3.7 - strange differences in lighting!
Date: 21 Aug 2015 17:42:47
Message: <55d79b57@news.povray.org>
Hi(gh)!
To add the scrolling info text (to be displayed when the ball runs
through one of the two rotating "i" characters), I now used screen.inc
in my POVigma project - and noticed a strange deviation in brightness
and contrast (lighting settings are not changed since)!
With screen.inc (nevertheless using a conventional camera, as a
straight-down top view otherwise would yield an error), the whole scene
is brighter and with less contrast, as showed in the two attached pictures.
How can I fix this?
See you in Khyberspace!
Yadgar
Download '2015-08-18 povigma level 1, take 3.jpg' (205 KB) Download '2015-08-21 povigma level 1, take 5.jpg' (164 KB)
Preview of image '2015-08-18 povigma level 1, take 3.jpg'
Preview of image '2015-08-21 povigma level 1, take 5.jpg'
Subject: Re: screen.inc in 3.7 - strange differences in lighting!
Date: 21 Aug 2015 20:36:04
Message: <55d7c3f4$1@news.povray.org>
On 8/21/2015 5:42 PM, "Jörg \"Yadgar\" Bleimann" wrote:
> Hi(gh)!
> How can I fix this?
> Yadgar
Is your gamma messed up? Make sure you are using "srgb" in color
declarations instead of "rgb".
Date: 22 Aug 2015 05:44:54
Message: <55d84496@news.povray.org>
Hi(gh)!
I tried assumed_gamma 1.6 (which in fact is my system gamma value), and
now it looks much better - not as dark as the original version, but
acceptable to me!
Yadgar
Download '2015-08-22 povigma level 1, take 6.jpg' (182 KB)
Preview of image '2015-08-22 povigma level 1, take 6.jpg'
Date: 22 Aug 2015 22:56:25
Message: <55d93659$1@news.povray.org>
Am 22.08.2015 um 11:45 schrieb "Jörg \"Yadgar\" Bleimann":
> Hi(gh)!
Don't!
Any value other than assumed_gamma 1.0 screws with the internal colour
computations in an unrealistic manner (or, maybe technically more to the
point, fails to screw with the supplied colour values in a realistic
manner). I guess I mentioned that already on one occasion or two...
If you're not happy with the look of the scene, indeed use "srgb"
instead of "rgb" to combat washed-out colours, and tweak the lighting to
combat overly bright scenes (if that's still an issue then); also, you
may want to reduce some materials' "ambient" settings or reduce
"ambient_light" (or use radiosity instead, which is a better idea anyway).
As for your system gamma value, that should go into the "Display_Gamma"
setting of your master .ini file, and nowhere else.
> and
> acceptable to me!
Congratulations - you just managed to hide some more fundamental flaw in
your scene, that might bite you again further down the road...
The fact that including "screen.inc" makes any difference indicates that
there's something wrong other than just a change in gamma handling
(which is just a symptom), because "screen.inc" has nothing to do with
gamma.
Have a close look at POV-Ray's log output. Does it happen to say
anything about the #version directive? If I'm guessing correctly about
what is happening, your scene fails to have any. (Also, I guess I happen
to know that you didn't include any standard include files before you
added "screen.inc").
As of POV-Ray 3.7, the #version directive is not only mandatory, but
/must/ be the /first/ non-comment statement in your scene to ensure
flawless operation. And you do get a warning about that (if you'd care
to read it ;)).
Date: 23 Aug 2015 17:52:03
Message: <55da4083$1@news.povray.org>
Hi(gh)!
Whatever values I tried for "s", I got completely weird hues - a green
"grass" texture changed to dark blue or magenta!
> to read it ;)).
Yes, I added #version 3.7, but it didn't help either...
Yadgar
Date: 23 Aug 2015 21:17:17
Message: <55da709d$1@news.povray.org>
Did you use assumed_gamma 1?  If so, then you should use srgb instead of
rgb wherever you define a color.  (If you use the named colors from
colors.inc, then put srgb before the color name and ignore the
"suspicious expression" warning.)
Date: 24 Aug 2015 09:30:42
Message: <55db1c82@news.povray.org>
Am 23.08.2015 um 23:52 schrieb "Jörg \"Yadgar\" Bleimann":
> Hi(gh)!
>> anyway).
What do you mean by "s"? And can you provide examples with a bit of SDL
code and the resulting imagery?
Green (i.e. a colour with the "green" channel having the highest value
of all channels) should never turn magenta (i.e. a colour with the
"green" channel having the lowest value of all channels), no matter the
gamma handling (as long as you're not trying pathological stuff like use
negative gamma values or some such). Therefore, if you actually see such
symptoms, my next best bet would be that there's something much more
fundamentally wrong about your POV-Ray binary and/or your hardware.
>> to read it ;)).
What do you mean by "didn't help"? If "help" = "fix the colour issues",
then you're approaching the situation with wrong expectations. If "help"
= "provoke the colour issues even without including 'screen.inc'", then
I'm pretty surprised it didn't.
Specifying the "#version" directive should do no more nor less than
"stabilize" POV-Ray's behaviour with regards to whether "screen.inc" is
included or not (and along the way suppress a warning you should get
otherwise). If the "#version" directive achieves that, it means that I'm
on the right track as to why the include file makes a difference (please
let me know whether that is the case), and also confirms that the colour
changes are probably related to gamma. If it doesn't, it means something
entirely different is at work.
Date: 24 Aug 2015 14:00:18
Message: <op.x3vwapf1ufxv4h@xena>
<yaz### [at] gmxde> wrote:
> Hi(gh)!
 to
u
>> anyway).
srgb is a 3_Term_Vector
-Nekar Xenos-
Date: 24 Aug 2015 14:19:43
Message: <55db603f@news.povray.org>
Hi(gh)!
O. k., meanwhile I also found out that srgb does not expect a four-part
color vector - I removed the fourth value, and now everything works fine
(see attachment)!
Yadgar
Download 'povigma000.png' (908 KB)
Preview of image 'povigma000.png'
Date: 24 Aug 2015 17:02:33
Message: <55db8669$1@news.povray.org>
"s" is not a value you supply. It just tells povray to use the newer
color system.
Mike
