Le 15-03-28 18:34, Sven Littkowski a écrit :
> Thanks to both of you.
> As wished, I am attaching now a rendered image.
> Color Depth: great reminder! Of course. I won't reduce their dimensions as i
> need them in hi-res, and i cannot adjust compression levels in PNGs. but yes, I
> will make them gray-scale. Let's see. :-)
> I also created already a first animation, but the ship is still very far from
> complete.
> Sven Littkowski <jam### [at] yahoo com> wrote:
>> Hi,
>> currently, I am using large images for my spaceship project as hull
>> textures (please see the attached image). But that takes plenty memory
>> and increases a lot the rendering time.
>> If you look to the attached hull texture, is there any way to create
>> something like this with a function or formula? Please assists. Thanks.
If you use IrfanView, you can easily change the compression level from 0
(barely any) to 9 (maximum).
Other graphic tools may also offer such an option, or always use some
hard coded setting.
> Hi,
If you are applying your single image_map *many* times to your model (for
example, like many randomly-placed 'decals'), another way to save memory is to
first #declare the image_map in a pigment statement:
#declare my_hull_pigment = pigment{image_map{.....}}
......then use that in your scene, as the pigment in your (many) textures,
instead of a new image_map statement every time. This way, the original image
takes up memory only once. The idea is similar in concept to using a single mesh
object many times in a scene: one mesh which is 're-used', requiring no
additional memory.
>> dimensions as i
>> but yes, I
>> far from
>> complete.
>>> Hi,
> hard coded setting.
The GIMP offers that possibility too.
>> Hi,
> additional memory.
Good point! I did not know that, but is obvious indeed.
On 29-3-2015 14:22, Thomas de Groot wrote:
> On 29-3-2015 11:11, Sven Littkowski wrote:
>> Tiles! Yes, of course! Thanks.
> You could play with a combination of tiling patterns and pavement patterns.
Reminder: When using patterns for uv_mapping, remember that tiling and
pavement patterns are oriented according to the x/z plane while uv
coordinates lie in the x/y plane. For use on an object you need to
rotate your texture by -90*x
I discovered that trick several years(?) ago, while working on a complex
animation scene. It greatly reduces scene-parsing time, when re-using an
image_map.
