POV-Ray : Newsgroups : povray.binaries.images : Imitated Bricks Server Time
15 Jul 2026 18:20:27 EDT (-0400)
  Imitated Bricks (Message 8 to 17 of 27)
<<< Previous 7 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Imitated Bricks
Date: 7 Mar 2015 18:35:00
Message: <web.54fb8b05a78a3f0b282bc6050@news.povray.org>
> Obviously these are cheap imitations, but I thought I might share
> nonetheless...
These look great, is that just standard lighting? It looks too good for that to
me but the reflection of the sphere suggests it is.
Sean
Date: 7 Mar 2015 19:50:23
Message: <54fb9ccf$1@news.povray.org>
Am 08.03.2015 um 00:34 schrieb s.day:
>> nonetheless...
No image-based lighting involved, if that's what you mean - just a large
area light and a simple sky sphere. It does, however, make use of
UberPOV's uncached radiosity and blurred reflections.
Date: 8 Mar 2015 06:50:01
Message: <web.54fc2913a78a3f0ba6601e4f0@news.povray.org>
> >> nonetheless...
"uncached radiosity" ?
is that just progressive rendering?
Date: 8 Mar 2015 06:59:56
Message: <54FC2BAB.2040105@optusnet.com.au>
> nonetheless...
Wow.   Excellent finish for this sort of render.  Not totally like the
real thing but sort of 'hyper real'.  Low it.
Date: 8 Mar 2015 11:04:55
Message: <54fc6517$1@news.povray.org>
>>>> nonetheless...
from changes.txt:
Unbiased Diffuse Illumination:
   - UberPOV allows to disable the caching of radiosity samples, by
using the
     following syntax in the global radiosity block:
         no_cache [BOOL]
     It also changes the way the secondary ray directions are chosen, and
     effectively turns the radiosity algorithm into a purely stochastic
unbiased
     algorithm to compute diffuse illumination.
     Most radiosity settings are without effect in this mode, except for the
     following:
         adc_bailout FLOAT
         brightness FLOAT
         brilliance BOOL
         count FLOAT
         gray_threshold FLOAT
         media BOOL
         normal BOOL
         recursion_limit INT
         subsurface BOOL
     The current implementation does not translate classic radiosity
settings
     into useful parameters for this mode of operation; it is therefore
highly
     recommended to use a much lower setting for the "count" parameter than
     typical with standard radiosity.
     This syntax extension can be tested for using the #patch directive or
     patch() function with the patch name "upov-radiosity-no_cache"; the
current
     implementation is version 0.1.
from revision.txt
Commit 21cc3c6 on 2014-07-24 by Christoph Lipka
     Add support for stochastic diffuse computations.
     Specifying `no_cache` in the global radiosity block will disable
     and use a more random algorithm to generate secondary ray
directions, effectively using the
     radiosity code for straightforward stochastic computation of
Date: 4 Jun 2015 17:17:04
Message: <5570c050@news.povray.org>
This looks great.
I posted a link to this thread onto the LDraw forums and it has generated
some further comments:
http://forums.ldraw.org/read.php?20,14335,16426#msg-16426
I've tried doing some renders with UberPov using your suggested Plastic
finish settings, but I can't seem to get the same kind of result that you've
achieved (maybe it's the focul blur that I'm missing).
I would like try some more UberPov renders using the LDraw models that I've
already converted to POV-Ray - could you share the full code for your
example picture.
BTW - I couldn't get the latest version of UberPov to work - it kept
crashing (I'm using 64-bit Windows 8)
Reuben
"clipka" <ano### [at] anonymousorg> wrote in message
news:54f750ca@news.povray.org...
> nonetheless...
Date: 5 Jun 2015 17:39:21
Message: <55721709$1@news.povray.org>
Am 04.06.2015 um 23:17 schrieb Reuben Pearse:
> example picture.
See povray.binary.scene-files.
Date: 5 Jun 2015 18:01:50
Message: <55721c4e$1@news.povray.org>
Am 05.06.2015 um 23:39 schrieb clipka:
>> I've
>> example picture.
Sorry: povray.binaries.scene-files.
Date: 19 Sep 2015 22:30:03
Message: <55fe1a2b@news.povray.org>
I created an image using most of your settings as well as the LGEO part
library. I am not as impressed however. I guess from a distance the
details are not as noticeable.
Michael
Download 'building_007_firecompany_uber_04.png' (2155 KB)
Preview of image 'building_007_firecompany_uber_04.png'
Date: 19 Sep 2015 22:56:29
Message: <55fe205d$1@news.povray.org>
Am 20.09.2015 um 04:30 schrieb Mike Horvath:
My guess is that it wants more stuff around it. Doesn't have to be LEGO
bricks - maybe a HDR light probe mapped to the sky might already do the
trick.
In my scene, the camera is far enough "inside" the scene that the
various elements mutually serve as environment. In your scene, the
camera is way outside the building, and there's nothing besides.
