On 5/03/2015 5:36 AM, clipka wrote:
> Obviously these are cheap imitations, but I thought I might share
> nonetheless...
Wow. Excellent finish for this sort of render. Not totally like the
real thing but sort of 'hyper real'. Low it.
On 03/08/2015 06:48 AM, Mr wrote:
> clipka <ano### [at] anonymous org> wrote:
>> Am 08.03.2015 um 00:34 schrieb s.day:
>>>> nonetheless...
>>> These look great, is that just standard lighting? It looks too good for that to
>>> me but the reflection of the sphere suggests it is.
>> No image-based lighting involved, if that's what you mean - just a large
>> area light and a simple sky sphere. It does, however, make use of
>> UberPOV's uncached radiosity and blurred reflections.
> "uncached radiosity" ?
> is that just progressive rendering?
from changes.txt:
Unbiased Diffuse Illumination:
- UberPOV allows to disable the caching of radiosity samples, by
using the
following syntax in the global radiosity block:
no_cache [BOOL]
It also changes the way the secondary ray directions are chosen, and
effectively turns the radiosity algorithm into a purely stochastic
unbiased
algorithm to compute diffuse illumination.
Most radiosity settings are without effect in this mode, except for the
following:
adc_bailout FLOAT
brightness FLOAT
brilliance BOOL
count FLOAT
gray_threshold FLOAT
media BOOL
normal BOOL
recursion_limit INT
subsurface BOOL
The current implementation does not translate classic radiosity
settings
into useful parameters for this mode of operation; it is therefore
highly
recommended to use a much lower setting for the "count" parameter than
typical with standard radiosity.
This syntax extension can be tested for using the #patch directive or
patch() function with the patch name "upov-radiosity-no_cache"; the
current
implementation is version 0.1.
from revision.txt
Commit 21cc3c6 on 2014-07-24 by Christoph Lipka
Add support for stochastic diffuse computations.
Specifying `no_cache` in the global radiosity block will disable
and use a more random algorithm to generate secondary ray
directions, effectively using the
radiosity code for straightforward stochastic computation of
This looks great.
I posted a link to this thread onto the LDraw forums and it has generated
some further comments:
http://forums.ldraw.org/read.php?20,14335,16426#msg-16426
I've tried doing some renders with UberPov using your suggested Plastic
finish settings, but I can't seem to get the same kind of result that you've
achieved (maybe it's the focul blur that I'm missing).
I would like try some more UberPov renders using the LDraw models that I've
already converted to POV-Ray - could you share the full code for your
example picture.
BTW - I couldn't get the latest version of UberPov to work - it kept
crashing (I'm using 64-bit Windows 8)
Reuben
"clipka" <ano### [at] anonymous org> wrote in message
news:54f750ca@news.povray.org...
> nonetheless...
Am 04.06.2015 um 23:17 schrieb Reuben Pearse:
> example picture.
See povray.binary.scene-files.
Am 05.06.2015 um 23:39 schrieb clipka:
>> I've
>> example picture.
Sorry: povray.binaries.scene-files.
I created an image using most of your settings as well as the LGEO part
library. I am not as impressed however. I guess from a distance the
details are not as noticeable.
Michael
Download 'building_007_firecompany_uber_04.png' (2155 KB)
Preview of image 'building_007_firecompany_uber_04.png'
Am 20.09.2015 um 04:30 schrieb Mike Horvath:
My guess is that it wants more stuff around it. Doesn't have to be LEGO
bricks - maybe a HDR light probe mapped to the sky might already do the
trick.
In my scene, the camera is far enough "inside" the scene that the
various elements mutually serve as environment. In your scene, the
camera is way outside the building, and there's nothing besides.
> Michael
Tried again with a plain white background. The shadows look pretty filthy.
Michael
Download 'l3p_building_007_firecompany_uber_05.png' (675 KB)
Preview of image 'l3p_building_007_firecompany_uber_05.png'
Am 22.09.2015 um 13:16 schrieb Mike Horvath:
>> Michael
Technically that doesn't seem to be the shadows, but the radiosity.
Are you sure you're using UberPOV's "no_cache" keyword in the radiosity
settings?
>>> Michael
> settings?
I used your radiosity settings exactly, and it does look better. Except
for the grainy speckles in the shadowed regions where radiosity is working.
Download 'l3p_building_021_houseporchyard_uber_01.png' (1187 KB)
Preview of image 'l3p_building_021_houseporchyard_uber_01.png'
Am 24.09.2015 um 08:23 schrieb Mike Horvath:
>>> filthy.
>> settings?
See? Just listen to old people's advice ;)
As for the grainy speckles, those have the pleasant property that they
can be reduced simply by throwing more computing time at it. UberPOV's
anti-aliasing mode 3 is your friend there.
What is that device attached to the attic roof on the right end?
Well, young man. In the days before satellites... :-P
Regards
>>>> filthy.
>>> settings?
I do not have this time, unfortunately. I have about a hundred models,
and each render is taking me 16+ hours.
Michael
keep at it mikey,
Download 'legospace_phtons.png' (337 KB)
Preview of image 'legospace_phtons.png'
Hi(gh)!
> keep at it mikey,
This very set I had when I was 10 years old, back in 1979! And also the
LL 918, and, somewhat later, the LL 928 (my younger brother had the LL 924)!
See you in Khyberspace!
Yadgar
Am 26.11.2015 um 19:32 schrieb Jörg 'Yadgar' Bleimann:
> Hi(gh)!
>> keep at it mikey,
> 924)!
Interestingly enough, 891 (442 in the US) was one of just two sets from
the European 1979 generation of space series my brother and I did /not/
own (not counting baseplate sets).
My very first classic space set was the 889 radar vehicle; from that day
on, the percentage of non-space sets among our subsequent new
acquisitions dropped to almost zero, and never recovered.
LL 928 will probably always be my favorite LEGO space set, rivaled only
by 6929 (which we never owned).
