POV-Ray : Newsgroups : povray.binaries.images : Toroidal media Server Time
19 Nov 2025 08:28:45 EST (-0500)
  Toroidal media (Message 1 to 10 of 13)
Subject: Toroidal media
Date: 6 Dec 2014 15:01:35
Message: <5483609f@news.povray.org>
It started from a question in p.advanced-users.
Original source from portfolio allpattern.pov for cylindrical
#version 3.7;
global_settings {
  assumed_gamma 1.0
#declare Cylindrical   = pigment {cylindrical colour_map {[0, rgb 0][1,
rgb 1]}scale 0.8}
         box {
            -1.5,1.5
            hollow
            material {
                  pigment {rgbf 1}
                  finish {
                     ambient 0
                     diffuse 0
               interior {
                  media {
                     emission 0.3
                     samples 40,40
                     intervals 40
                     method 2
                     density {
                        cylindrical
                        color_map {
                           [0, rgb 0]
                           [0, rgb <0.5,0.5,0.4>]
                           [1, rgb <1,0,0>]
	rotate 90*z
	scale 4/7 //control minor radius
                        warp
                          toroidal  orientation z major_radius 1
            rotate <0,-35,0>
            rotate <-25,0,0>
            translate<0,0,-1.5>
     location  <0,0,-8>
     look_at   <0,-0.25, 0>
     angle 35
   light_source{<500,10,-500> rgb 1}
   light_source{<-500,500,-500> rgb <0.6,0.6,0.8>}
IQ of crossposters with FU: 100 / (number of groups)
IQ of crossposters without FU: 100 / (1 + number of groups)
IQ of multiposters: 100 / ( (number of groups) * (number of groups))
Download 'tm.png' (124 KB)
Preview of image 'tm.png'
Subject: Re: Toroidal media
Date: 7 Dec 2014 03:41:40
Message: <548412c4@news.povray.org>
Close, but not quite. Look at image: the torus is not complete.
Download 'torusmedia_test.png' (205 KB)
Preview of image 'torusmedia_test.png'
Date: 7 Dec 2014 04:24:32
Message: <54841cd0@news.povray.org>
The best way to achieve my initial question in p.advanced-users is the
solution given by Alain: using a torus function for the density:
#local Radius = 30;
#local F_pig = pigment {function {f_torus(x,y,z, 1.0, 0.15)}};
torus {1.0, 0.15
   hollow
   material {
       pigment {rgbt 1}
     interior {
       media {
         intervals 1
         samples 10
         emission 0.5/Radius
         density {
           pigment_pattern {F_pig}
           color_map {
             [0.8 rgb <0,1,0>]
             [1.0 rgb <1,0,0>]
   scale Radius
   rotate 10*x
   rotate 15*z
Now, I need to investigate further in combining this with toroidal warps
and other media matter. My ultimate goal is to achieve a credible Milky
Way that can be seen from a planet for instance.
Download 'planetgenesis.png' (191 KB)
Preview of image 'planetgenesis.png'
Date: 7 Dec 2014 05:25:28
Message: <54842b18@news.povray.org>
> Thomas
Yep, you are right, it's wrapping the media around the torus, not what
you expected.
So, I'm calling the hgpovray branch to the rescue.
http://wiki.povray.org/content/User:Le_Forgeron#torus
The inverse of the minor radius/scale is used as parameter.
box { -1.5,1.5 hollow material { texture { pigment {rgbf 1} finish {
ambient 0 diffuse 0 } } interior { media { emission 0.3 samples 40,40
intervals
40 method 2 density { cylindrical color_map
{ [0, rgb 0]
[1, rgb <1,0,0>] }
 warp { torus <0,0,0>, 1, <7/4,1,0>
Download 'tm.png' (100 KB)
Date: 7 Dec 2014 07:19:25
Message: <548445cd$1@news.povray.org>
>> Thomas
> you expected.
> intervals
> { [0, rgb 0]
> [1, rgb <1,0,0>] }
Excellent! So we have two methods now to choose from.
However, your warp code is not implemented in the latest version 3.7!
Date: 7 Dec 2014 12:28:19
Message: <54848e33@news.povray.org>
> Thomas
For a solution based on toroidal (original post), the solution is with
dist_exp 200 (or any big enough value) to neglect the effect of depth,
or changing the cylindrical to a pigment that has no influence due to
depth , value 1 at 0, value 0 at -1 and 1: it's planar !!!
so either :
intervals
40 method 2 density { planar
color_map
{ [0, rgb 0]
[1, rgb <1,0,0>] }
scale 4/7
 warp { toroidal orientation y major_radius 1
or
intervals
color_map
{ [0, rgb 0]
[1, rgb <1,0,0>] }
rotate 90*z
scale 4/7
 warp { toroidal orientation z major_radius 1 dist_exp 200
Strictly speaking, dist_exp is cheating. Planar is not.
Download 'pla.png' (100 KB) Download 'tm.png' (100 KB)
Preview of image 'pla.png'
Date: 7 Dec 2014 14:09:21
Message: <5484a5e1$1@news.povray.org>
> #local Radius = 30;
> torus {1.0, 0.15
>    hollow
>    material {
>      texture {
>        pigment {rgbt 1}
>      interior {
>        media {
>          intervals 1
>          samples 10
>          emission 0.5/Radius
>          density {
>            color_map {
>              [0.8 rgb <0,1,0>]
>              [1.0 rgb <1,0,0>]
>    scale Radius
>    rotate 10*x
>    rotate 15*z
> Thomas
The milky way is not toroidal but a barred spiral that is thicker in the
center and tapper off toward the edges in a lenticular way.
A combination of spherical, with uneven scalling for the central bulge,
and turbulated planar could be the best way to do it.
Date: 7 Dec 2014 17:11:02
Message: <5484d076$1@news.povray.org>
The spiral1 pattern may also be useful for this purpose.
Date: 8 Dec 2014 03:16:39
Message: <54855e67@news.povray.org>
Well, as you realize, seen from a planet's surface, the basic shape is
not really important. I could also just use a cylinder or a box within
the camera view ;-)
However, I want to go a little bit further than just that make-believe
and so came up with a torus. Btw, Nekar's spiral galaxy in the Objects
Collection might also be a possibility to investigate.
Date: 8 Dec 2014 03:20:11
Message: <54855f3b@news.povray.org>
[snip]
Interesting. I wondered how to use dist_exp as the docs are not very
clear on that issue and I did not know what it really represented.
Thanks indeed
