POV-Ray : Newsgroups : povray.binaries.images : Toroidal media Server Time
27 May 2026 15:17:07 EDT (-0400)
  Toroidal media (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: Toroidal media
Date: 7 Dec 2014 05:25:28
Message: <54842b18@news.povray.org>
On 07/12/2014 09:41, Thomas de Groot wrote:
> Close, but not quite. Look at image: the torus is not complete.
> Thomas
Yep, you are right, it's wrapping the media around the torus, not what
you expected.
So, I'm calling the hgpovray branch to the rescue.
http://wiki.povray.org/content/User:Le_Forgeron#torus
The inverse of the minor radius/scale is used as parameter.
box { -1.5,1.5 hollow material { texture { pigment {rgbf 1} finish {
ambient 0 diffuse 0 } } interior { media { emission 0.3 samples 40,40
intervals
40 method 2 density { cylindrical color_map
{ [0, rgb 0]
[0, rgb <0.5,0.5,0.4>]
[1, rgb <1,0,0>] }
 warp { torus <0,0,0>, 1, <7/4,1,0>
IQ of crossposters with FU: 100 / (number of groups)
IQ of crossposters without FU: 100 / (1 + number of groups)
IQ of multiposters: 100 / ( (number of groups) * (number of groups))
Download 'tm.png' (100 KB)
Preview of image 'tm.png'
Date: 7 Dec 2014 07:19:25
Message: <548445cd$1@news.povray.org>
>> Thomas
> you expected.
> intervals
> { [0, rgb 0]
> [1, rgb <1,0,0>] }
Excellent! So we have two methods now to choose from.
However, your warp code is not implemented in the latest version 3.7!
Date: 7 Dec 2014 12:28:19
Message: <54848e33@news.povray.org>
> Thomas
For a solution based on toroidal (original post), the solution is with
dist_exp 200 (or any big enough value) to neglect the effect of depth,
or changing the cylindrical to a pigment that has no influence due to
depth , value 1 at 0, value 0 at -1 and 1: it's planar !!!
so either :
intervals
40 method 2 density { planar
color_map
{ [0, rgb 0]
[1, rgb <1,0,0>] }
scale 4/7
 warp { toroidal orientation y major_radius 1
or
intervals
color_map
{ [0, rgb 0]
[1, rgb <1,0,0>] }
rotate 90*z
scale 4/7
 warp { toroidal orientation z major_radius 1 dist_exp 200
Strictly speaking, dist_exp is cheating. Planar is not.
Download 'pla.png' (100 KB) Download 'tm.png' (100 KB)
Preview of image 'pla.png'
Date: 7 Dec 2014 14:09:21
Message: <5484a5e1$1@news.povray.org>
Le 14-12-07 04:24, Thomas de Groot a écrit :
> The best way to achieve my initial question in p.advanced-users is the
> solution given by Alain: using a torus function for the density:
> #local Radius = 30;
> #local F_pig = pigment {function {f_torus(x,y,z, 1.0, 0.15)}};
> torus {1.0, 0.15
>    hollow
>    material {
>      texture {
>        pigment {rgbt 1}
>      interior {
>        media {
>          intervals 1
>          samples 10
>          emission 0.5/Radius
>          density {
>            pigment_pattern {F_pig}
>            color_map {
>              [0.8 rgb <0,1,0>]
>              [1.0 rgb <1,0,0>]
>    scale Radius
>    rotate 10*x
>    rotate 15*z
> Now, I need to investigate further in combining this with toroidal warps
> and other media matter. My ultimate goal is to achieve a credible Milky
> Way that can be seen from a planet for instance.
> Thomas
The milky way is not toroidal but a barred spiral that is thicker in the
center and tapper off toward the edges in a lenticular way.
A combination of spherical, with uneven scalling for the central bulge,
and turbulated planar could be the best way to do it.
Date: 7 Dec 2014 17:11:02
Message: <5484d076$1@news.povray.org>
The spiral1 pattern may also be useful for this purpose.
Date: 8 Dec 2014 03:16:39
Message: <54855e67@news.povray.org>
Well, as you realize, seen from a planet's surface, the basic shape is
not really important. I could also just use a cylinder or a box within
the camera view ;-)
However, I want to go a little bit further than just that make-believe
and so came up with a torus. Btw, Nekar's spiral galaxy in the Objects
Collection might also be a possibility to investigate.
Date: 8 Dec 2014 03:20:11
Message: <54855f3b@news.povray.org>
[snip]
Interesting. I wondered how to use dist_exp as the docs are not very
clear on that issue and I did not know what it really represented.
Thanks indeed
Date: 8 Dec 2014 03:53:33
Message: <5485670d$1@news.povray.org>
> [snip]
Not clear ? Not extensive, maybe confusing, but seems clear:
 to cite the wiki:
 With the cylindrical, spherical and toroidal warps you can wrap
checkers, bricks and other patterns around cylinders, spheres, toruses
and other objects. In essence, these warps use the same mapping as the
image maps use.
However it does 3D mapping and some concession had to be made on depth.
This is controllable by dist_exp (distance exponent). In the default of
0, imagine a box <0,0> to <1,1> (actually it is <0,0>,
<dist^dist_exp,dist^dist_exp>) stretching to infinity along the
orientation vector. The warp takes its points from that box.
> Thanks indeed
> Thomas
Just because nobody complains does not mean all parachutes are perfect.
Date: 8 Dec 2014 04:23:17
Message: <54856e05$1@news.povray.org>
>   to cite the wiki:
> image maps use.
Indeed. I understood the meaning :-) but I assumed that the distance was
to be used /within/ the boundary of the minor radius, so in my trials it
was always rather small.
Date: 8 Dec 2014 14:37:24
Message: <5485fdf4$1@news.povray.org>
> the camera view ;-)
Oh I see, you want to render an inside view ;)
In that case the shape is indeed not so important ... absorption is
so high (at visible wavelengths) that most light you see from the Milky
Way is from our "local" galactic neighborhood only (~ 1 kpc radius).
