POV-Ray : Newsgroups : povray.binaries.images : Urbex - wip 12 Server Time
21 Aug 2025 09:53:25 EDT (-0400)
  Urbex - wip 12 (Message 1 to 10 of 31)
Subject: Urbex - wip 12
Date: 8 Aug 2014 08:10:11
Message: <53e4be23@news.povray.org>
Getting nearer a final render. A large one to be able to assess the details.
Output render in exr format; postprocessed in IC for luminosity balance;
this copy as jpg.
Now as Cathy's World #13.
Download 'urbex_12.jpg' (487 KB)
Preview of image 'urbex_12.jpg'
Subject: Re: Urbex - wip 12
Date: 8 Aug 2014 10:10:40
Message: <53e4da60@news.povray.org>
What do you think? This is a jpg copy of the original exr render,
without post-processing. Somehow, I prefer this although it is a bit too
dark.
Download 'urbex_12.jpg' (314 KB)
Date: 8 Aug 2014 10:26:48
Message: <53e4de28$1@news.povray.org>
Am 08.08.2014 16:10, schrieb Thomas de Groot:
> dark.
I prefer this one, too. I love images that play with light & darkness.
Date: 8 Aug 2014 19:38:08
Message: <53e55f60$1@news.povray.org>
> dark.
> Thomas
The very dark areas make the bright areas look brighter and beter, even
if I need to push the brightness of my monitor to the max. I think that
it beter show the often oppresive feeling you may have in this kind of
settin.
Date: 9 Aug 2014 03:10:19
Message: <53e5c95b$1@news.povray.org>
>> dark.
Yes, me too. Additionally, the post processing flattens out the colour
contrast. I shall play a bit more with that last aspect but just as an
experiment not towards a 'final' image.
Date: 9 Aug 2014 03:10:48
Message: <53e5c978$1@news.povray.org>
>> dark.
>> Thomas
> settin.
Yes, I agree.
Date: 9 Aug 2014 04:40:26
Message: <53e5de7a$1@news.povray.org>
>>> dark.
I would be tempted to use a fill light on the stairs just to bring out
some detail. I would not know how to do that with radiosity. Would using
a diffuse reflective object do it. The way that photographers would use
a white sheet in RL?
Regards
Date: 9 Aug 2014 07:16:33
Message: <53e60311$1@news.povray.org>
During testing I have used a shadowless light over the stairs. I am
thinking about a couple of things: a diffuse reflective screen is one
but may be too 'diffuse' to be effective; a skylight high in the wall
above the stairs is another. I am not too willing to use a direct light,
even an area one, as that would be counter to the state of the building ;-)
Date: 10 Aug 2014 10:01:14
Message: <53e77b2a@news.povray.org>
I believe I have a nice compromise now. I added a screen, simulating a
skylight in the upper wall of the staircase. With a bit of emission.
Download 'urbex_final3.jpg' (336 KB)
Preview of image 'urbex_final3.jpg'
Date: 11 Aug 2014 00:33:19
Message: <53e8478f$1@news.povray.org>
> dark.
> Thomas
Hmm. Haven't commented on this prior, but.. the walls are too
artificial. While its a good look, walls don't peel quite like that,
which I think if the problem. There would be color differences in the
paint itself, lighted in "protected" spots, and discolored in others.
Their might be bleed through of texture from individual panels (if wall
board), or other materials, where the same disruptions that peeled the
paint has warped the underlying material. Also, more protected areas may
be less patchy, due to be less exposed to the conditions that caused the
peel, and others might have much bigger patches missing, due to being
more exposed to the same.
It doesn't "look" uniform, but... its too obviously algorithmic. Too
"cleanly" non-uniformly damaged. If you get what I mean.
Its one of the things that bugs me about this stuff, and why I never
dove that far into it over the years, instead of just once in a while.
POVRay textures are good, when you can't see, in the scale, the
repetitiveness of them, but not so good in scenes like this, but.. on
the other hand, I suck even more at "painting" believable details, using
a static, non-generated texture. lol
Commander Vimes: "You take a bunch of people who don't seem any
different from you and me, but when you add them all together you get
this sort of huge raving maniac with national borders and an anthem."
