POV-Ray : Newsgroups : povray.binaries.images : Sky simulation Server Time
28 May 2026 05:11:43 EDT (-0400)
  Sky simulation (Message 51 to 58 of 58)
Subject: Re: Sky simulation
Date: 8 Sep 2016 03:54:23
Message: <57d1192f$1@news.povray.org>
On 9/8/2016 3:14 AM, Thomas de Groot wrote:
> On 8-9-2016 8:56, posfan12 wrote:
>> Thomas de Groot <tho### [at] degrootorg> wrote:
>>> I think I found the culprit: Your original SunPos() is divided by 1000!
>>> Thomas
>> What line number is that at? I am having the same issue.
>> Mike
> Goodness! That was three years ago! ;-)
> Without going over the whole discussion again, I guess it is about:
> // uncomment the below lines to have a physical sun in the scene with
> realistic brightness
> // and size (useful if using mcpov or perhaps radiosity?)
>   #local SunRadius = vlength(sp/1000)/214.8;
>   sphere{ sp/1000, SunRadius pigment{color rgb 1} finish{emission 1}
> no_shadow}
> Forgive me, I do not have the info freshly available in my mind anymore...
My problem is the darkness of the sky, not the color of the sun sphere.
I don't see how this has any effect.
Further, I made my own sun and did not realize this script does it too.
Mike
Date: 8 Sep 2016 03:57:59
Message: <57d11a07$1@news.povray.org>
> Mike
The blueness of the sky, rather. The default output is too desaturated IMO.
Mike
Date: 8 Sep 2016 04:04:30
Message: <57d11b8e$1@news.povray.org>
> no_shadow}
Also, I don't have these lines in my copy of SkySim.inc. Which version
are you using?
Mike
Date: 8 Sep 2016 05:56:07
Message: <57d135b7$1@news.povray.org>
>> Mike
What do you mean by "default output"? You realise that changing the sun
position and the turbidity parameter drastically affects the output?
Date: 8 Sep 2016 06:50:25
Message: <57d14271$1@news.povray.org>
>>> Mike
>> IMO.
I mean the settings recommended in the documentation.
My scene is set to POV version 3.6. Could gamma and the srgb keyboard be
an issue?
Mike
Date: 8 Sep 2016 07:21:04
Message: <57d149a0$1@news.povray.org>
>> no_shadow}
>> anymore...
> are you using?
> Mike
Not in the .inc file! It appears in the .pov file. Mine is called
SkySimTestGround.pov
Date: 8 Sep 2016 08:55:50
Message: <57d15fd6$1@news.povray.org>
>>>> Mike
>>> IMO.
> an issue?
Does it look ok if you change the version to 3.7?
Date: 8 Sep 2016 14:27:18
Message: <57d1ad86$1@news.povray.org>
>> an issue?
I tried to put #version 3.7 everywhere I could. It looks about the same
as without. On second thought it's not that bad. I can live with it.
Mike
