POV-Ray : Newsgroups : povray.binaries.images : Sky simulation Server Time
28 May 2026 00:54:39 EDT (-0400)
  Sky simulation (Message 1 to 10 of 58)
Subject: Sky simulation
Date: 7 Jun 2013 03:36:29
Message: <51b18d7d@news.povray.org>
I've created a macro called SkySim (I'll post it in p.b.s-f once I've
tidied it up and added comments) that creates a realistic looking sky
pigment in a sky_sphere based on the sun position and the "haziness" of
the sky.
The algorithm used is from this paper:
www.cs.utah.edu/~shirley/papers/sunsky/sunsky.pdf
It is the same algorithm used by the open-source software Stellarium, so
I already had a starting point in code for the POV version.
If you also use "sunpos.inc" to get the sun position then you can create
the correct sky based on just the longitude/latitude and time of day
(this is how I've done it in the test scene).
The renders below are from the test scene with an isosurface ground and
fog, however I've patched my version of POV so that the fog colour
matches the sky_sphere and is not a constant colour. I think this gives
a realistic perception of depth and renders very quickly.
Obviously in a real scene you may want to add clouds, but I hope it's a
useful starting point for a realistic looking sky.
Download 'skysimtestground1.png' (351 KB) Download 'skysimtestground2.png' (237 KB) Download 'skysimtestground3.png' (259 KB) Download 'skysimtestground4.png' (262 KB) Download 'skysimtestground5.png' (301 KB) Download 'skysimtestground6.png' (197 KB) Download 'skysimtestground7.png' (173 KB)
Preview of image 'skysimtestground1.png'
Preview of image 'skysimtestground2.png'
Preview of image 'skysimtestground3.png'
Preview of image 'skysimtestground4.png'
Preview of image 'skysimtestground5.png'
Preview of image 'skysimtestground6.png'
Preview of image 'skysimtestground7.png'
Subject: Re: Sky simulation
Date: 7 Jun 2013 04:04:25
Message: <51b19409$1@news.povray.org>
> the sky.
Interestingly, I use the following code to the same effect. I do not
remember who proposed this code first unfortunately.
//code start
#declare fn_horizon = function {max(y, 0)}
#declare fn_sun =
function {
   pattern {
     spherical
     scale 3
     translate z
     rotate -Al*x
     rotate Az*y
sky_sphere {
     function {pow(fn_horizon(x,y,z)*(1-fn_sun(x,y,z)), 0.400)}
     color_map {
       [0.000 color SunColor]
       [0.426 color srgb <94,  115,  215>/255]
//code end
Al (altitude) and Az (azimuth) are found using sunpos.inc; SunColor with
CIE.inc.
Date: 7 Jun 2013 06:24:26
Message: <51b1b4da$1@news.povray.org>
> the sky.
Not a tool I have in my tool box and one I would like to have. I look
forward to trying your macro.
Bill P.
Date: 7 Jun 2013 11:05:01
Message: <web.51b1f5b959bb636148146bbd0@news.povray.org>
It looks great; I'll have to try it out soon.
Ah, I wish POV-Ray supported that kind of fog! My POV-SDL hack is just too
inflexible to work with things like media clouds. Will you be posting the patch
someday? (In fact, why aren't coders posting more patches? Is everyone waiting
till 3.7 Final or something?)
Sam
Date: 9 Jun 2013 03:44:50
Message: <51b43272$1@news.povray.org>
Question:
For the visible Sun, you give: #local SunRadius = vlength(sp)/214.8;
I seem to remember that Cousin Ricky evaluated the apparent size of the
Sun as to be twice as much, i.e.: #local SunRadius = vlength(sp)*2/214.8;
I don't know who is right or wrong but personally I prefer the larger
size :-) Somehow, it looks more like the natural aspect of the Sun, but
that may very well not be at all objective.
Date: 9 Jun 2013 05:19:24
Message: <51b4489c@news.povray.org>
For my sun radius calculation I used the values from wikipeda, distance
to sun is 1.5e8 and radius of the sun is 6.96e5, dividing those two
gives the 214.8.
IMO it also depends heavily on the angle/focal length of the camera you
are using, you can easily make the sun or moon look way too big or way
too small (IRL and in POV). In Stellarium there's even a toggle to make
the moon 4x realistic size because it just seems more "natural", it may
be a similar reason why Cousin Ricky put in the factor of 2.
Note that if you increase the size artificially and are using the sun
sphere as an accurate light source for radiosity (or mcpov) you probably
want to reduce the emission value accordingly (if making the radius 2x
bigger the area will be 4x bigger, so reduce the emission by a factor 4).
Date: 9 Jun 2013 07:23:36
Message: <51b465b8$1@news.povray.org>
> gives the 214.8.
It is probably an unconscious tendency to 'see' the Sun (or Moon) bigger
than they really are.
True.
Date: 9 Jun 2013 09:12:44
Message: <51b47f4c$1@news.povray.org>
actually I seem to recall the license / source code comments did not
allow the publishing of modified sources for beta versions. Not sure if
that also holds for release candidates.
Date: 9 Jun 2013 09:49:36
Message: <51b487f0$1@news.povray.org>
> gives the 214.8.
Yes, that is the correct value known since antiquity (the ratio is
simply the sine of the apparent angle that is readily observable). It
was the figuring out the actual distances/ radii that took longer ;)
http://en.wikipedia.org/wiki/Aristarchus_of_Samos
Regarding the Sun at least we rarely see the actual disk as it is lost
in the glare, and this has a larger size. And at sunset when we see it
we perceive it as larger than we would overhead:
Overhead, we tend to assume an object is not so far away (maybe typical
cloud distance). On the horizon an object is perceived to be very far
away. So the same angular size is interpreted as a larger object. This
effect persists even when no objects are available for comparison, so
that often heard explanation is an urban myth.
The thing here is that the angular size of the sun is fixed, but the
angular size of other objects in the scene depends on the distance. And
in a photo or render the distance is not readily apparent, we need to
estimate it from the scale of objects.
As an extreme example suppose you simulate a telescopic view with angle
1 degree on a house on the horizon. Now the image contains a house of
reasonable size with a sun filling half the image behind it, so it looks
way to big. But if we were smarter we would judge scale from the Sun and
conclude the house is either a tiny model or very far away).
Date: 9 Jun 2013 10:05:01
Message: <web.51b48ac359bb6361e52a27db0@news.povray.org>
> the sky.
These look great, I am struggling with creating a realistic sky colour at the
moment so would look forward to giving this a try.
Sean
