POV-Ray : Newsgroups : povray.binaries.images : Sky simulation Server Time
27 May 2026 23:38:13 EDT (-0400)
  Sky simulation (Message 49 to 58 of 58)
Subject: Re: Sky simulation
Date: 8 Sep 2016 03:14:52
Message: <57d10fec$1@news.povray.org>
On 8-9-2016 8:56, posfan12 wrote:
>> I think I found the culprit: Your original SunPos() is divided by 1000!
>> Thomas
> What line number is that at? I am having the same issue.
> Mike
Goodness! That was three years ago! ;-)
Without going over the whole discussion again, I guess it is about:
// uncomment the below lines to have a physical sun in the scene with
realistic brightness
// and size (useful if using mcpov or perhaps radiosity?)
  #local SunRadius = vlength(sp/1000)/214.8;
  sphere{ sp/1000, SunRadius pigment{color rgb 1} finish{emission 1}
no_shadow}
Forgive me, I do not have the info freshly available in my mind anymore...
Date: 8 Sep 2016 03:22:04
Message: <57d1119c$1@news.povray.org>
>>> Thomas
>> Mike
> no_shadow}
IIRC I think the consensus was that the 1000 factor (used on both lines)
should be tweaked to make the sphere seem "far away" in your specific
scene (but not too far away it causes accuracy issues). I think without
the /1000 the sun is just too far away for the maths to cope when
dealing with normal scenes of the order of a few metres.
Date: 8 Sep 2016 03:54:23
Message: <57d1192f$1@news.povray.org>
>>> Thomas
>> Mike
> no_shadow}
My problem is the darkness of the sky, not the color of the sun sphere.
I don't see how this has any effect.
Further, I made my own sun and did not realize this script does it too.
Mike
Date: 8 Sep 2016 03:57:59
Message: <57d11a07$1@news.povray.org>
> Mike
The blueness of the sky, rather. The default output is too desaturated IMO.
Mike
Date: 8 Sep 2016 04:04:30
Message: <57d11b8e$1@news.povray.org>
> no_shadow}
Also, I don't have these lines in my copy of SkySim.inc. Which version
are you using?
Mike
Date: 8 Sep 2016 05:56:07
Message: <57d135b7$1@news.povray.org>
>> Mike
What do you mean by "default output"? You realise that changing the sun
position and the turbidity parameter drastically affects the output?
Date: 8 Sep 2016 06:50:25
Message: <57d14271$1@news.povray.org>
>>> Mike
>> IMO.
I mean the settings recommended in the documentation.
My scene is set to POV version 3.6. Could gamma and the srgb keyboard be
an issue?
Mike
Date: 8 Sep 2016 07:21:04
Message: <57d149a0$1@news.povray.org>
>> no_shadow}
>> anymore...
> are you using?
> Mike
Not in the .inc file! It appears in the .pov file. Mine is called
SkySimTestGround.pov
Date: 8 Sep 2016 08:55:50
Message: <57d15fd6$1@news.povray.org>
>>>> Mike
>>> IMO.
> an issue?
Does it look ok if you change the version to 3.7?
Date: 8 Sep 2016 14:27:18
Message: <57d1ad86$1@news.povray.org>
>> an issue?
I tried to put #version 3.7 everywhere I could. It looks about the same
as without. On second thought it's not that bad. I can live with it.
Mike
