POV-Ray : Newsgroups : povray.binaries.images : Realistic indoor radiosity - I still don't get it! Server Time
21 Jul 2026 09:20:48 EDT (-0400)
  Realistic indoor radiosity - I still don't get it! (Message 5 to 14 of 24)
<<< Previous 4 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Realistic indoor radiosity - I still don't get it!
Date: 17 Nov 2011 03:11:57
Message: <4ec4c1cd@news.povray.org>
Everything has already been said above I guess, still allow me a few
thoughts:
- Hildur's radiosity settings are intended for version 3.6 and megapov,
NOT 3.7 RC3.
- For the latest image of a similar scene to yours (see the attachment)
and which I believe is satisfyingly illuminated inside and outside, I
use the following settings:
Radiosity:
   radiosity {
     pretrace_start 0.08
     pretrace_end   0.004
     count 100
     nearest_count 10, 5
     error_bound 1
     recursion_limit 2
     low_error_factor .3
     gray_threshold 0.0
     minimum_reuse 0.015
     maximum_reuse 0.1
     brightness 1
     adc_bailout 0.01/2
     normal off
     media off
     always_sample off
As sunlight (only lightsource) I use the LightSysIV system:
   #include "CIE.inc"
   #declare SunColor     = Blackbody(6500)*2;
My skysphere is a simple sphere with the following finish:
   finish {emission 1 diffuse 0}
Typically, the finish of the textures shown here are as follows:
material {
     uv_mapping
     pigment{srgb <0.9,0.9,0.9> transmit  0/100}
     finish {
       specular 0.1
       roughness 0.00286312
       ambient rgb <0.00,0.00,0.00>
       diffuse 0.8
       brilliance 1
       reflection{0.0}
       conserve_energy
I hope this helps. Particularly, check out the gamma settings like
Clipka told you in his message! This is essential with version 3.7.
Download 'at the jackal.png' (624 KB)
Preview of image 'at the jackal.png'
Date: 17 Nov 2011 15:27:30
Message: <4ec56e32@news.povray.org>
High!
> thoughts:
> NOT 3.7 RC3.
> Radiosity:
> radiosity {
> pretrace_start 0.08
> pretrace_end 0.004
> count 100
> nearest_count 10, 5
> error_bound 1
> recursion_limit 2
> low_error_factor .3
> gray_threshold 0.0
> minimum_reuse 0.015
> maximum_reuse 0.1
> brightness 1
> adc_bailout 0.01/2
> normal off
> media off
> always_sample off
I tried this (see below) - and simply was stunned: few artifacts and
FAST! However, one problem remains: increasing gray_threshold doesn't
help this time, the shadows remain bluish! Where do I find a 3.7 manual
to look it up (no, I don't have the Windows version)?
> #include "CIE.inc"
Currently I only use a cheap point light sun...
I instead use a proper sky_sphere with a gradient y from almost white
cyan to rgb <0, 0.3, 1>!
Once more my question: where do I find a 3.7 manual?
See you in Khyberspace!
Yadgar
Download '2011-11-17 port whatmough residential building 1, take 274 - view from north, 2011 thomas de groot radiosity (modified).' (28 KB) Download '2011-11-17 port whatmough residential building 1, take 283 - inside kitchen, looking west into atelier, 2011 thomas de g' (22 KB)
Preview of image '2011-11-17 port whatmough residential building 1, take 274 - view from north, 2011 thomas de groot radiosity (modified).'
Preview of image '2011-11-17 port whatmough residential building 1, take 283 - inside kitchen, looking west into atelier, 2011 thomas de g'
Date: 17 Nov 2011 16:12:36
Message: <4ec578c4$1@news.povray.org>
http://wiki.povray.org/content/Documentation:Contents
This is our most up to date documentation ... all the RC4 changes are
here but for what you're looking for it will do!
Date: 17 Nov 2011 19:37:44
Message: <4ec5a8d8@news.povray.org>
an after thought ... take a peek in /usr/local/share/doc/povray-3.7
Date: 18 Nov 2011 03:05:49
Message: <4ec611dd$1@news.povray.org>
The bluish hue comes from the sky. I think that in RL the same happens,
only we unconsciously compensate for it :-) In my image this also
happens by the way. Like me, you can reduce its effect by (1) creating
(e.g. white) objects around your house, blocking the horizon and part of
the sky. Where they are not visible by the camera, simple screens may
do. This is a simple trick I learned from Hildur by the way.
Alternatively, you can make the sky less blue; (2) you can increase the
light's intensity which will drown out the sky hue to some measure; (3)
If you want to use the LightSys IV system you can control the way in
which horizon and/or overhead atmosphere influence the sunlight.
Like Jim says below, there are the online docs for 3.7 to browse through ;-)
Obviously, my code was not complete. My complete sky code is:
sphere { <0, 0, 0>, 1
     gradient y
     color_map {
       [0.0 rgb <0.6,0.7,1.0>]
       [0.7 rgb <0.0,0.1,0.8>]
   scale 5*10e4
   inverse
Date: 18 Nov 2011 04:28:09
Message: <4ec62529@news.povray.org>
High!
> pigment {
> gradient y
> color_map {
> scale 5*10e4
> inverse
Meanwhile, before I even tried this, I tried to modularize my scene
script (which started to become difficult to handle, at 1,800 lines of
code) by placing the radiosity, pigment, finish and texture definition
in separate files - and instantly messed up the code completely!
Your sophisticated radiosity is gone (though I did not change
anything!), instead I once more got some dull, contrastless rendering!
I obviously am too stupid to learn anything from any mistake...
I'm about to catch the next time machine to some Nazi death camp and get
myself gassed... I HATE MYSELF FOR BEING SO DYSFUNCTIONAL!!!
Or is there anyone among you who would like to kill me? I'm totally fed
up with myself!!!
UARGH!!!!
Date: 18 Nov 2011 07:20:54
Message: <4ec64da6$1@news.povray.org>
Building a scene from modules is a good way to go instead. It is
something I often do myself. Learning from past errors: I always start
from a copy of the original scene :-) I know perfectly well what you are
going through.
However, you can best leave the radiosity statement in the main scene
file along with all general things like the light, the sky, etc, and
include the texture definitions from an external file.
Don't hate yourself. Shit happens, like they say...
> up with myself!!!
Before you go, or before the next hitman makes an appointment with you,
just take a beer and consider life without POV-Ray ;-)
> UARGH!!!!
Now, that should have relieved you! Yell again!
Date: 18 Nov 2011 13:30:01
Message: <web.4ec6a36c4ccf544d85de7b680@news.povray.org>
I don't believe you.
Look back at your personal Web site.  You confess to having lots of setbacks and
mistakes over the years trying to model Afghanistan.  And you learned.
You can do it again.  Just give it more time and effort.
I hope you're just kidding.  If not, then please see a doctor.
> up with myself!!!
If we kill you, then you'll *never* learn about radiosity.  Plus, we'll lose a
fellow POV-Ray user.
This too, shall pass.
Sleep on it.
Date: 18 Nov 2011 18:30:01
Message: <web.4ec6ea0b4ccf544d94d713cc0@news.povray.org>
Shadows actually /are/ bluish on a sunny day with clear blue sky, and your sky
is very blue; I think the radiosity is taking that into account, just as in the
real world.
Try changing your sky color to red and see if you get red shadows...
Cheers,
Rob
www.McGregorFineArt.com
Date: 19 Nov 2011 16:24:17
Message: <4ec81e81$1@news.povray.org>
Hi(gh)!
Am 18.11.2011 19:26, schrieb Cousin Ricky:
But my learning curve is very, very flat... when I compare myself to
those whizkids who know PoV-Ray barely for a year and come up with
sophisticated scenes, then I really would like to kill not myself (I'm
even too phlegmatic for suicide!), but to delete all PoV-Ray
applications and project data and from now on content myself with
watching TV and drinking cheap canned beer like all the other underclass
losers do...
And that's the problem... I'm not used to giving effort (in any fields
of life) anymore, effort just HURTS! And when I try and try and try and
even the 22nd attempt is the same failure as the first, then I wonder
Fortunately, there are no time machines... and as I mentioned, I'm even
too dysfunctional to kill myself! If I tried, I probably would totally
blow the job and instead of simply ceasing to exist (or, the Christian
version, ending up in Satan's eternal Auschwitz, as I'm no born-again
turbo-evangelical), I would find myself as a coma patient for years and
years in some intensive neurology ward...
> Sleep on it.
Not even this works after gallons of strong "programmer's coffee"...
Yadgar
