POV-Ray : Newsgroups : povray.binaries.images : Some last minute raytracing ... Server Time
30 Sep 2024 01:15:59 EDT (-0400)
  Some last minute raytracing ... (Message 1 to 10 of 10)
Subject: Some last minute raytracing ...
Date: 26 Oct 2011 09:44:23
Message: <4ea80eb7@news.povray.org>
Well I'm almost packed up, but before the computer gets boxed up I
thought I'd do a little raytracing, because I don't know when I'll be
setup in my new location. It's a work in progress, but I like where it
appears to be headed. The open crock is something (lathe object) I've
used in other scenes, but I reworked the texture. BTW: the leaf is a
photo of I snapped the other day (fall colors almost all gone)
Download 'work.png' (644 KB)
Preview of image 'work.png'
Subject: Re: Some last minute raytracing ...
Date: 27 Oct 2011 03:02:13
Message: <4ea901f5$1@news.povray.org>
Very nice, Jim! Happy moving ;-)
[Don't forget to pack the jar]
Date: 1 Nov 2011 21:36:54
Message: <4eb09eb6$1@news.povray.org>
High!
The floor tiles look very neat - are they flattened superellipsoids or
isosurfaces... or heightfields? And how did you achieve the blurred
reflection? Did you use HDRI?
See you in Khyberspace!
Yadgar
Now playing: Angels Don't Fall In Love (Bangles)
Date: 1 Nov 2011 23:57:48
Message: <4eb0bfbc$1@news.povray.org>
> High!
Thanks ... I used a macro by Sam Benge (OTO.inc) ... it calls
Round_Box_Union that's in shapes.inc. The tile texture has a very slight
granite normal (granite 1e-3 poly_wave 0.35) that helps create the
blurred reflection ... and yes I used a HDR image textured on the inside
of a sphere to provide the environment that you see reflected on the
floor ... it's an image of an abandoned paper-mill
Date: 7 Nov 2011 15:46:22
Message: <4eb8439e@news.povray.org>
OK ... so the acorn didn't turn out like I wanted, maybe with a bit of
tweaking, but the shell turned out nice. It's a parametric I found on
Mike's page: http://www.econym.demon.co.uk/ I also played around a
little with the positioning of the HDR map ... a bit more pleasing
results, don't you think?
Download 'work.png' (788 KB)
Date: 8 Nov 2011 03:34:39
Message: <4eb8e99f$1@news.povray.org>
The scene is very pleasant, what kind of texture have you used for the vase?
Paolo
Date: 8 Nov 2011 03:48:07
Message: <4eb8ecc7@news.povray.org>
Yes, nicely done indeed. Maybe you remember the SeaShell plugin for
Moray, built by Philippe Gibone (2003)? In the end I have not used it
much but it was a neat application.
The position of the hdr map is indeed better. To make better use of the
tile reflection you could also move some objects in order to show their
reflections too. Now the objects seem without reflection.
Date: 8 Nov 2011 08:24:34
Message: <4eb92d92$1@news.povray.org>
> vase?
> Paolo
two separate textures in a texture_map. used agate to distribute the
pigment and for the normal as well ... cylindrical warp.
Date: 8 Nov 2011 08:41:49
Message: <4eb9319d$1@news.povray.org>
never used Moray ... I just used the wood pattern for the pigment and a
granite micro-normal. uv_mapping for the overall texture.
yikes ... didn't notice that until you pointed it out. Guess I need a
bit more practice with variable reflection. I'm also using exponent, and
falloff on the tile floor.
Date: 8 Nov 2011 09:15:44
Message: <4eb93990@news.povray.org>
>> vase?
>> Paolo
Thank you, I will do a try.
Paolo
