POV-Ray : Newsgroups : povray.binaries.images : sphere_sweep object trace Server Time
2 Nov 2024 04:23:26 EDT (-0400)
  sphere_sweep object trace (Message 1 to 9 of 9)
Subject: sphere_sweep object trace
Date: 16 Oct 2011 15:05:01
Message: <web.4e9b2982cb6a6b1acc7740060@news.povray.org>
This is a first attempt at tracing an object with a sphere_sweep produced from a
non-random cube point cloud. Obviously needs a bit of work before it will be
useful for much.
Right now it kind of looks like the nasty wax-like icing on those wretched
little debbie/hostess cakes [no offense to those companies, just my personal
opinion..still...yuck].
Current issues:
1)    Inside() tests result in no points being usable (all eval as being
inside). Not sure how to reorient_trans() just a vector, as I think that macro
applies to objects. Intend to confirm. Currently consider reorient_trans() as a
possible fix until more information obtained.
2)    Obvious spiral due to method of point generation and array traversal.
3)    Need to pre-generate a spline of same type used in sphere_sweep for
intelligent object placement along said path, as well as ability to pre-evaluate
output of sphere_sweep for fitness and auto-modify to produce desired results.
4)    Finding a use for this. Solution seeking a problem.. Maybe pipes/greeble?
Who knows.
This image isn't particularly artistic, as I'm more interested in the logic of
solving the problem than I am much else, so...yeah.
Ian
Download 'toruscylinderconnection2011.gif' (12 KB)
Preview of image 'toruscylinderconnection2011.gif'
Subject: Re: sphere_sweep object trace
Date: 17 Oct 2011 15:40:00
Message: <web.4e9c837631f7e1e677e50e540@news.povray.org>
Due to lack of Array IndexOf, Contains, Resize, Shuffle [Fisher-Yates and
Bruteforce] and Count Defined Items, I created those macros [among others]. They
seem to work quite well.
This is the same thing as before, but with fisher-yates array reshuffle and
post-trace coincident point removal applied.
Still not pretty, but I had fun solving the problem and got some nifty macros
out of the deal.
If anyone wants the macros I'll post'em.
Ian
Download 'toruscylinderconnection2011_1.gif' (12 KB)
Preview of image 'toruscylinderconnection2011_1.gif'
Date: 19 Oct 2011 17:00:00
Message: <web.4e9f3a2f31f7e1e677e50e540@news.povray.org>
And the final output.
Download 'toruscylinderconnection2011_2_scaled.png' (143 KB)
Preview of image 'toruscylinderconnection2011_2_scaled.png'
Date: 20 Oct 2011 03:22:23
Message: <4e9fcc2f$1@news.povray.org>
It's a very strange object now.
Paolo
Date: 20 Oct 2011 15:05:01
Message: <web.4ea06ca731f7e1e6afac46ba0@news.povray.org>
> useful for much.
Hey Ian!
It's turning out to be an interesting study, especially that third image. Could
we get a closeup on that?
> applies to objects.
You can transform vectors. Here's the way:
    #include "transforms.inc"
    // central reference
    sphere{0, 0.1 pigment{rgb x}}
    // the untransformed point
    #declare Pt = <0,1,0>;
    sphere{Pt, 0.1 pigment{rgb y}}
    // the transformed point
    #declare Pt = vtransform(Pt, transform{Reorient_Trans(<0,1,0>,<1,0,0>)});
    sphere{Pt, 0.1 pigment{rgb z}}
You can also align an object or vector with exact precision using this
transformation macro from Rune:
    // Rune's macro for aligning an object based on the y and z axes.
    #macro Z_Align( NormalVector, ZVector )
     #local ObjectZ = vnormalize( ZVector );
     #local ObjectY = VPerp_Adjust( NormalVector, ZVector );
     #local ObjectX = vcross( ObjectY, ObjectZ );
     transform{ Shear_Trans( ObjectX, ObjectY, ObjectZ ) }
The argument "NormalVector" is the direction the object's y-axis will be facing.
The argument "ZVector" is the direction the z-axis of the object will face; it
has a secondary influence over the final result.
As usual, these things parse more quickly when you don't have to include files.
That's what POV-Ray is good for: everything ranging from artistic works to
scientific visualization :)
~Sam
Date: 21 Oct 2011 06:55:00
Message: <web.4ea14e8a31f7e1e677e50e540@news.povray.org>
"Samuel Benge" <stb### [at] hotmailcom> wrote:
Hows it going Sam? :)
Remind me to send you the code for the N-state N-dimensional CA [still not 100%
done with it, work keepin me busy]...you will need MS XNA framework to run it
though for the 3D window.
Thanks, and yes. This is the full image. I'm not entirely satisfied with the
superquads for lights, or the texture on large grey bendy bit.
The clear bendys remind me of bean noodles.
>> snippage
A-ha! Thanks man! I'll have to give those a shot.
Essentially all this file is consists of:
1) point cloud traced to object [vlength=0 and coincident points removed]
2) remaining points shuffled
3) fork to:
   3a) spline interpolation and generic object translation along spline macro
   3b) sphere sweep
A lot of neat reusable macros resulted from this experiment. All utility macros
return values/objects.
Having difficulty getting include files to talk to eachother, so Vector.inc and
Array.inc are merged curently [names are close to standard inc files because
they extend their namesakes].
Thats why pov kicks so much arse. :)
I do wish SDL was strongly typed though. Oh well. I'll live.
> ~Sam
Ian
Download 'toruscylinderconnection2011_2_big.jpg' (125 KB)
Preview of image 'toruscylinderconnection2011_2_big.jpg'
Date: 21 Oct 2011 07:15:50
Message: <4ea15466$1@news.povray.org>
That's impressive indeed.
Date: 22 Oct 2011 21:40:01
Message: <web.4ea36f6a31f7e1e6f8e75d050@news.povray.org>
Oh, pretty good. Got the 2D CA program just about completed, though I haven't
worked on it for a couple of weeks. It's approximately 98.5% finished, however
it's severely lacking a proper GUI. I should probably post it somewhere, since
it's a very useful app.
> done with it, work keepin me busy]...you will need MS XNA framework to run it >
Sounds cool.
> Thanks, and yes. This is the full image. I'm not entirely satisfied with the >
Hmm, very neat. What will it be used for? Or are you just following an idea?
> >> snippage
No problem.
> Array.inc are merged curently [names are close to standard inc files because > they
What do you mean? Usually when you include all the correct files everything
meshes smoothly.
> > That's what POV-Ray is good for: everything ranging from artistic works to > >
Yeah, me too. But it's still a fun language. Some OOP functionality would be
nice :/
~Sam
Date: 31 Oct 2011 07:05:00
Message: <web.4eae7fed31f7e1e677e50e540@news.povray.org>
Sweeeet! CA are so addictive.
I had to pause development of the various simulation programs I was working on,
but they do a *lot*. I'm not sure how recent the code I sent you is, but I'll
7z and send the source for them in a few days.
Well, I'm not entirely sure. I was initially trying to make a sphere_sweep based
pipe macro that could wrap all/portions of an object, but then I started chasing
butterflies with the idea, and here we are. :)
I will find something to do with it pretty soon though. Maybe I'll just post the
macros that "do stuff" at the core of this, because they are pretty useful
(especially the array function macros and object trace spline generator).
> meshes smoothly.
I tried referencing .inc files from inside other .inc files and tried .mcr
files, but I kept getting weird messages that basically said pov couldn't find
the included file. These are not in the main include path, but I don't see why
that would have stopped it, since .inc files in the same folder as the pov file
calling them present no problem.
> nice :/
Yes, it very much would be!
> ~Sam
