POV-Ray : Newsgroups : povray.binaries.images : Gancaloon - urbanism wip Server Time
27 Jul 2025 07:23:38 EDT (-0400)
  Gancaloon - urbanism wip (Message 1 to 10 of 28)
Subject: Gancaloon - urbanism wip
Date: 31 Jul 2011 03:45:49
Message: <4e35082d@news.povray.org>
This is a first approach towards simulating urbanism in Gancaloon,
following a pattern of streets. Flat roofs are considered the norm. ;-)
- blocks were drawn on a bitmap;
- scaled up and reworked a bit/added to;
- transformed to svg paths in Inkscape;
- exported as one prism to POV;
- scaled down and translated to correct position in POV;
- intersected with copy of height_field;
- textured with a cell pattern.
Comments:
 From far away, the illusion is almost perfect, but close up the defects
show. First of all, the buildings on steeper slopes were the roofs
should be horizontal are looking like anything except buildings. The
blocks should also be a bit more smoothed I guess. The cell texture is
too regular despite a bit of warp added. Building height differences are
needed. Building- and texture orientation should be more random.
Download 'gancaloon1.png' (391 KB) Download 'gancaloon2.png' (376 KB)
Preview of image 'gancaloon1.png'
Preview of image 'gancaloon2.png'
Subject: Re: Gancaloon - urbanism wip
Date: 31 Jul 2011 10:42:34
Message: <4e3569da@news.povray.org>
With the intersecting height_field slightly perturbed by averaging with
a cell pattern, the result is more interesting.
Download 'gancaloon.png' (409 KB)
Preview of image 'gancaloon.png'
Date: 31 Jul 2011 11:04:25
Message: <4e356ef9$1@news.povray.org>
That does look better. To my eyes the buildings on the right look right
but the ones on the left look like rocks. As if the scale has changed.
Regards
Date: 1 Aug 2011 08:07:07
Message: <4e3696eb@news.povray.org>
Yes, I agree. The technique is not really perfect. Still, it gives some
interesting results. In the present image I decreased still more the
influence of the cell pattern, which reduces the rock-like effect I
guess. Some artefacts are visible from the averaging and/or pixel level
of the images. They may add to the illusion or not however. The problem
is still with the *flat* roofs. I guess I have to avoid steep slopes :-)
at least for the time being.
Download 'gancaloon.png' (403 KB)
Date: 1 Aug 2011 18:29:55
Message: <4e3728e3$1@news.povray.org>
> The problem is still with the *flat* roofs. I guess I have to avoid
> steep slopes :-) at least for the time being.
Instead of averaging with the cell pattern you could multiply the
cell function value with coarsely sampled evaluations of the original
height_field image. That would give "city blocks" of constant height
appropriate for local average terrain. It will introduce steps on
roofs that fall on a cell boundary but maybe it looks like an
intended structure ;)
Date: 2 Aug 2011 04:29:50
Message: <4e37b57e$1@news.povray.org>
Yes, of course! <bangs head with the mouse> I should have thought of
that, especially as I used this technique profusely with my Geomorph
macro which was completely function controlled.
Date: 2 Aug 2011 05:35:00
Message: <web.4e37c3ebb0e954806dd25f0b0@news.povray.org>
Thomas de Groot <tenDOTlnDOTretniATtoorgedDOTt> wrote:
No particular comments, other than to say this looks an interesting project!
Also, I quite like the surreal nature of your placeholder axes and grids
combined with what is shaping up to be a high-detail cityscape.
I shall be watching with interest. :)
Date: 2 Aug 2011 07:13:24
Message: <4e37dbd4$1@news.povray.org>
Thanks Bill. Much appreciated.
In another context I could quite easily use those placeholders as
integral (and surreal indeed) part of the scene :-) Here I find them
very useful for the placement of object and to get a feel for the
dimensions of the landscape. And of course they are easily switched on
or off according to need.
Date: 2 Aug 2011 08:22:28
Message: <4e37ec04$1@news.povray.org>
Sort of like a holo-suite malfunction ;)
Date: 3 Aug 2011 08:03:40
Message: <4e39391c$1@news.povray.org>
Well, this is not as simple as it seems, or I am doing something wrong
(probably).
I wrote a simple test code which I think explains things. Just insert it
in a basic scene:
//Start code
#declare HF_pig =
   image_map {
    png "plasma3.png"
   rotate -90*x
#declare F_cells =
function {
     cells
     color_map {
       [0.1 rgb 0.4]
       [0.9 rgb 0.6]
     //warp {turbulence <0.1, 0, 0.1>}
     scale 0.03
#declare F_HF_00 =
function {
     image_map {
       png "plasma3.png" gamma 1.0
       map_type 0
       interpolate 2
#declare F_flatroof =
function {
     F_cells(x,y,z).hf
   * F_HF_00 (x,y,z).hf
#declare hf_cut =
intersection {
height_field {
   function 500, 500 {F_flatroof(x,y,z)}
   smooth
   translate <-0.5, 0, -0.5>
   scale <10, 1, 10>
   box {
     <-0.5, -0.5, -0.5>, <0.5, 0.5, 0.5>
     scale <10, 1, 10> * <0.99, 20, 0.99>
   translate 1.0*y
intersection {
   object {hf_cut}
   box {
     scale <3, 10, 5>
     rotate 45*y
   pigment {rgbt <1,1,0,0.1>}
intersection {
height_field {
   function 1000, 1000 {F_HF_00(x,y,z).hf}
   smooth
   pigment {HF_pig}
   translate <-0.5, 0.0, -0.5>
   scale <10, 1, 10>
   box {
     scale <10, 1, 10> * <0.99, 10, 0.99>
//End code
