POV-Ray : Newsgroups : povray.binaries.images : rc4 subsurface + radiosity test Server Time
2 Nov 2024 08:20:02 EDT (-0400)
  rc4 subsurface + radiosity test (Message 1 to 7 of 7)
Subject: rc4 subsurface + radiosity test
Date: 24 Mar 2011 22:01:53
Message: <4d8bf791@news.povray.org>
This is the 1st time I've tried a pure radiosity illuminated scene. I
also wanted to demo the most recent round of changes to RC4 ... ie:
subsurface + radiosity. The important settings are listed below ... Oh
and the test object I found at: http://shapes.aim-at-shape.net/ it was
in Stanford triangle format converted to mesh2.
First off I think I got darn close on the radiosity settings for a first
attempt. I think the obvious question here is what's going on where the
sitting figure meets the base. Is that the base pigment in it's
material, showing through the subsurface effect? If so I'd expect it has
more to do with my choices for the subsurface globals ... mm_per_unit?
When dialing it in I noticed that starting at about 75% of the final
setting (12.7) the material started to almost become see through, after
about 250% greater the subsurface effect became non existent ... that's
my range, correct? I used a conventional light source while doing the
subsurface tuning. The settings I settled for left a slight over hint of
the effect in the shadow of the right-sided arm and the same with the
shadow the leg cast onto the base.
Lastly ... yikes a render time of 54 hours 31 minutes. I was doing other
stuff (@#$%! tax time) so definitely not a fair performance indicator,
but wow won't be doing this type of render any time soon. I'm wondering
... is 2 pass radiosity still an option with this incantation of
subsurface? What about the other radiosity time savers like
Radiosity_Vain_Pretrace ... the last paragraph of it's doc entry reads
like probably not:
"At the moment, turning vain pretrace off will affect only classic
lighting computations (diffuse lighting, highlights and iridescence);
other features expendable during pretrace may follow in future versions."
Subsurface globals:
mm_per_unit 12.7
subsurface {
   radiosity on
   samples 256,128
Subsurface material: unglazed bone china, like some Wedgwood or Doulton
figurines
material {
     pigment { rgb <0.9600,0.8000,0.6900> }
     finish {
     subsurface { translucency rgb <0.4350,0.2580,0.2580> }
     diffuse 0.5
     ambient 0
     emission 0
     specular 0.1
     roughness 1e-2
     reflection {0.01}
   interior {ior 1.486}  // coral
	// chalk 1.510
Radiosity globals:
   subsurface on
   pretrace_start 0.08
   pretrace_end   0.008
   nearest_count 15
   count 150
   gray_threshold 0
   error_bound 0.5
   recursion_limit 3
   low_error_factor 0.5
   minimum_reuse 0.005
   maximum_reuse 0.05
Download 'fertility.png' (598 KB)
Preview of image 'fertility.png'
Subject: Re: rc4 subsurface + radiosity test
Date: 25 Mar 2011 05:23:17
Message: <4d8c5f05@news.povray.org>
Very nice, could be interesting even in kenya soapstone material.
Paolo
Date: 25 Mar 2011 08:07:56
Message: <4d8c859c$1@news.povray.org>
> Paolo
Good suggestion ... since this version was basically a test, I wanted
wanted to stay pretty basic. Being that the object is African maybe
ivory would be another option.
I like the object and hope I can come up with something that does it
justice ... back to the drawing board ;-)
Date: 25 Mar 2011 09:43:05
Message: <4d8c9be9$1@news.povray.org>
OK ... the render time was really bugging me, so I did a little
postmortem and I've uncovered an epic fail on my part (a real news flash
... eh) ... what a goober :-(
Date: 25 Mar 2011 09:47:59
Message: <4d8c9d0f$1@news.povray.org>
> attempt.
I think you did. Very nice, I missed that model it reminds me of Barbara
Hepworth's "Mother and Child.
54 hours 31 minutes O_O
Regards
Date: 25 Mar 2011 18:08:06
Message: <4d8d1246@news.povray.org>
> Paolo
I did some looking around ... I had no idea that there were so many
varieties of soapstone. Different from region to region.
This version didn't turn out to bad ... thanks for the nudge!
Download 'fertility.png' (901 KB)
Date: 28 Mar 2011 06:51:33
Message: <4d906835$1@news.povray.org>
>> Paolo
Thank you for the image!
Is very fine,
Paolo
