POV-Ray : Newsgroups : povray.binaries.images : Proof of concept: Edge detector (as pattern), sort of Server Time
10 Apr 2026 16:03:34 EDT (-0400)
  Proof of concept: Edge detector (as pattern), sort of (Message 1 to 6 of 6)
Subject: Proof of concept: Edge detector (as pattern), sort of
Date: 16 Mar 2011 07:15:25
Message: <4d809bcd@news.povray.org>
Edge detector (as pattern), sort of.
Just a quick (and bad) test, 100% SDL, 100% CSG.
Ambient & Diffuse : <1,0>,<1/2,1/2>,<0,1>
I do not like:
 - it's not a map (and a map cannot be used)
 - the distribution in space (crude square/line are visible)
 - it uses a lot of objects, hence memory!
 - the sampling is limited at 256 entries... here with 125.
How ? so far just with average pattern and many object patterns (with a
bit of translate).
Software is like dirt - it costs time and money to change it and move it
around.
Just because you can't see it, it doesn't weigh anything,
and you can't drill a hole in it and stick a rivet into it doesn't mean
it's free.
Download 'proximity0.png' (213 KB) Download 'proximity1.png' (218 KB) Download 'proximity2.png' (214 KB)
Preview of image 'proximity0.png'
Preview of image 'proximity1.png'
Preview of image 'proximity2.png'
Subject: Re: Proof of concept: Edge detector (as pattern), sort of
Date: 16 Mar 2011 10:25:01
Message: <web.4d80c7a8471774c081c811d20@news.povray.org>
> I do not like:
> bit of translate).
> around.
> it's free.
Looks alright.  I does look like you have some coincident surface at some faces.
Rather than applying the averaged object pattern directly, maybe trun it into a
function first, then you could maybe work on some interpolation that would help
smooth the blockiness.
-tgq
Date: 16 Mar 2011 11:22:30
Message: <4d80d5b6$1@news.povray.org>
where ?
I failed to spot that.
Could you provide some indication ? (if on front-face, you might provide
the ring number and the hour)
Date: 16 Mar 2011 11:50:01
Message: <web.4d80dbca471774c081c811d20@news.povray.org>
> where ?
I have circled some of the incidences in the pic attached.  Perhaps they are not
conicident surfaces but some other artifact.
-tgq
Download 'proximity0.png' (197 KB)
Date: 16 Mar 2011 18:18:49
Message: <4d813749@news.povray.org>
Le 16/03/2011 16:48, Trevor G Quayle nous fit lire :
>> where ?
Indeed, there was only one CSG-component there. I did say I did not like
the space distribution.
Here attached a test with an implementation which allow a map. (but
that's not SDL anymore). The object is sampled around the intersection
point in a sphere whose relative radius to the radius of the big sphere
(there is 3 of them) is the printed number.
Top object is the normal object with uniform texture.
The map is display around it with a gradient.
Download 'pp.jpg' (167 KB)
Preview of image 'pp.jpg'
Date: 16 Mar 2011 18:40:01
Message: <web.4d813ba6471774c0b05ef170@news.povray.org>
It is possible to get coincident surfaces from a pattern that has a sharp
transition that coincides with an object surface as well, not just two objects.
I noted it as possible coincident surface because it is only apparent on flat
surfaces.
-tgq
