POV-Ray : Newsgroups : povray.binaries.images : Die, cast Server Time
28 May 2026 12:05:54 EDT (-0400)
  Die, cast (Message 6 to 15 of 25)
<<< Previous 5 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Die, cast
Date: 22 Feb 2011 19:45:48
Message: <4d6458bc@news.povray.org>
For comparison, a version without subsurface scattering.
Download 'ssltdie_.png' (120 KB)
Preview of image 'ssltdie_.png'
Date: 23 Feb 2011 03:15:01
Message: <web.4d64c13244ccc9921df6284f0@news.povray.org>
> How about this one?
Perfect!
The with/without comparison is very interesting as well.
Dave Blandston
Date: 23 Feb 2011 07:11:49
Message: <4d64f985$1@news.povray.org>
On 02/22/2011 08:40 PM, clipka wrote:
> The die is actually an isosurface I had modelled earlier for a different
> scene; DON'T TRY THIS AT HOME WITH SSLT! Kudos to Kevin Loney, Jaap
> Frank & Tor Olav Kristensen for their isosurface approximator include
> file, which cut down the rendering time by a guesstimated 98-99% (!) to
> "only" 3.5 hours.
no kidding ... why is that with isosurfaces the render times skyrocket
(besides the obvious isosurface slow downs) ... i tried to make coral
material for my mandel goodie and after overnight on 13% progress ...my
guess is that up until now that fairly simple objects have been used as
demo. you guys are getting fairly decent times with mesh objects am i
correct? iso's are just a more complicated surface to consider
(sslt-wise) is that the reason? btw: did that test with RC3 bits ...
should i expect similar performance with updated method?
Date: 23 Feb 2011 13:25:01
Message: <web.4d65501344ccc99294d713cc0@news.povray.org>
Yes, meshes typically render very quickly. Isosurfaces are always going to be
slow, there's so much math going on in there... and with transparency or SSLT,
yikes, that could be a real rendering-time nightmare.
www.McGregorFineArt.com
Date: 23 Feb 2011 14:03:26
Message: <4d6559fe@news.povray.org>
I second that.
Regards
Date: 23 Feb 2011 14:30:27
Message: <4d656053$1@news.povray.org>
Am 23.02.2011 13:11, schrieb Jim Holsenback:
Actually it /is/ the obvious isosurface slow downs. SSLT is very
intersection-test-intensive, and that's exactly where isosurfaces suck.
Yup. Updated stuff includes bugfixes & an easier-to-use syntax, but no
performance improvements yet.
Date: 23 Feb 2011 17:15:01
Message: <web.4d6586bc44ccc99294d713cc0@news.povray.org>
I've noticed a weird X-pattern on superellipsoid faces with SSLT in RC3, just
wondering if you get the same thing with the new method.
Here's an image that illustrates what I mean - the left superellipsoid has the
X-pattern (like triangular faces with non-planar normals), the right
superellipsoid is the exact same but with no SSLT and using reflection &
transmit instead, but it looks as expected.
So, how does your die scene look using a superellipsoid instead of the
isosurface approximation mesh?
Download 'sslt_embossed_superellipsoid.png' (217 KB)
Preview of image 'sslt_embossed_superellipsoid.png'
Date: 23 Feb 2011 17:20:01
Message: <web.4d6587d344ccc99294d713cc0@news.povray.org>
For comparison here's an SSLT box using the same basic setup - no X-pattern in
the box though, just in the superellipsoid...
Download 'sslt_box.png' (284 KB)
Preview of image 'sslt_box.png'
Date: 23 Feb 2011 22:14:51
Message: <4d65cd2b$1@news.povray.org>
Am 23.02.2011 23:14, schrieb Robert McGregor:
> superellipsoid is the exact same but with no SSLT and using reflection&
Did you use radiosity for those images? If so, can you try again without
radiosity?
If it appears only when radiosity is enabled, chances are it will be
fixed with the next release.
Otherwise there might be some distance threshold hidden in the
superellipsoid intersection testing code; SSLT is quite sensitive to
such things, as it needs to shoot rays from just slightly below the
surface. I know that blobs have such issues, for instance. To really fix
that, I'd need to do some changes deep in the bowels of POV-Ray - which
of course is a no-go during release candidate phase.
Date: 23 Feb 2011 23:22:50
Message: <4d65dd1a@news.povray.org>
No such artifacts here, so I'm optimistic that it's something I fixed.
