POV-Ray : Newsgroups : povray.binaries.images : A speed enhancement for blurred reflections (144KB PNG) Server Time
28 May 2026 11:47:03 EDT (-0400)
  A speed enhancement for blurred reflections (144KB PNG) (Message 9 to 18 of 18)
<<< Previous 8 Messages Goto Initial 10 Messages
Subject: Re: A speed enhancement for blurred reflections (144KB PNG)
Date: 23 Jan 2011 15:07:57
Message: <4d3c8a9d@news.povray.org>
On 1/23/2011 9:59 AM, Mr wrote:
>   stbenge<myu### [at] hotmailcom>  wrote:
>   >  A speed enhancement can be used to cut the render time down
>   >  significantly, with an arguably acceptable loss of accuracy. Under this
>   >  setup, two instances of the same object are used. One copy is visible,
>   >  uses blurred reflection, and has a no_reflection modifier applied to it.
>   >  The other copy uses non-blurred reflection, but with a no_image modifier
>   >  applied.
> Would there be a corresponding technique for speeding up blurred refractions?
There would, if POV had a "no_refraction" modifier. The best (and
fastest) method for blurred refractions that I can think of is to bake
all your scene's textures to meshes (and/or use Rune's illusion.inc),
add a small surface normal to the refractive material and use high focal
blur settings.
~Sam
Date: 23 Jan 2011 17:42:27
Message: <4d3caed3$1@news.povray.org>
Even then a scene might not benefit much, as a second
blurred refraction object would need to be positioned
such that it appears in the first blurred refraction
for this technique to help. Refraction tends to be
less annoyingly recursive than reflection ;)
BTW I just tried: if the refraction leads to total
internal reflection the no_reflection modifier will
take effect.
Date: 24 Jan 2011 03:23:57
Message: <4d3d371d@news.povray.org>
>> refractions?
If you want no refraction, why don't you just turn the transmit & filter
to 0.0 (of the deepest texture in case of layered texture) ?
It seems so simple, I must have missed something.
Date: 24 Jan 2011 05:37:08
Message: <4d3d5654$1@news.povray.org>
Am 24.01.2011 09:23, schrieb Le_Forgeron:
> If you want no refraction, why don't you just turn the transmit&  filter
You have indeed ;-)
Date: 24 Jan 2011 06:30:01
Message: <web.4d3d618dce9e302b207c1e20@news.povray.org>
I posted that idea back in 2006. Anyone beat me to it? :)
http://news.povray.org/povray.binaries.images/message/%3Cweb.45509993b8175aee696633280%40news.povray.org%3E
Regards Roman
"Dave Blandston" <nomail@nomail> wrote:
> That's a great idea and it works like a charm, but...
http://news.povray.org/povray.binaries.images/message/%3C4baab97a%241%40news.povray.org%3E/#%3C4baab97a%241%40news.po
vr
> ay.org%3E
> -Just shows you guys are both very sharp!
> Regards,
> Dave Blandston
Date: 24 Jan 2011 11:00:00
Message: <web.4d3da1d2ce9e302b1df6284f0@news.povray.org>
stbenge <myu### [at] hotmailcom> wrote:
> At any rate, it's a good speed enhancement that needed more exposure ;)
There's a blurred reflection entry in the wiki thing describing how to use the
averaged normals, maybe that entry could be enhanced a little to describe the
speed enhancement trick as well. It's a really good tip!
http://wiki.povray.org/content/Knowledgebase:Language_Questions_and_Tips
Dave Blandston
Date: 24 Jan 2011 13:15:33
Message: <4d3dc1c5@news.povray.org>
> take effect.
It's good to know, though not something I would rely on ;)
Date: 24 Jan 2011 13:23:16
Message: <4d3dc394@news.povray.org>
This is beginning to look like the "stacked planes" scenerio all over
again :D
Date: 24 Jan 2011 13:24:24
Message: <4d3dc3d8@news.povray.org>
Hmm, I forgot all about the Wiki...
Date: 24 Jan 2011 15:16:09
Message: <4d3dde09@news.povray.org>
clipka wrote:
> You have indeed ;-)
Actually I fell into the same trap when first reading
the original post, my mind completely flowed over trying to
understand why anyone would go to the trouble of averaging
256 reflective textures just to tell the object it would
be "not reflecting" after all ;)
