POV-Ray : Newsgroups : povray.binaries.images : Afghan highlands - problems with mesh2 Server Time
2 Nov 2024 14:16:46 EDT (-0400)
  Afghan highlands - problems with mesh2 (Message 1 to 4 of 4)
Subject: Afghan highlands - problems with mesh2
Date: 20 Nov 2010 13:15:00
Message: <web.4ce80f3f5cf11f532d2a0edd0@news.povray.org>
High!
Resuming my long-cherished Khyberspace project, I once more started downloading
SRTM radar elevation data tiles and converting them into PNG 16-bit
heightfields.
For performance reasons, I pre-created the huge mesh2 code to be read in by the
scene script proper (as the mesh2 code is some 120 MB large, I just included
here the PNG heightfield and the mesh2writer script rather than the mesh2
itself).
When I render the scene, two problems occur:
First, between most of the mesh2 triangles, ugly black gaps show up (see
attached image file - no, it's NOT a anti-aliasing issue, the very scene you see
was rendered using +a0.3!). I remember that problem from back in 2005, when I
also tried a Khyberspace scene from SRTM data, and back then, I was told by Mike
Williams (if my notes are right) that it has got something to do with floating
point accuracy. So I got the suggestion to define each vertex of the mesh2 as
close to the origin as possible and then to re-translate the whole mesh.
But when I looked up the old script from 2005, I found that the I wrote back
then was a true Heath Robinson contraption, much too complicated to make use of
it now, so I did not implement Mike William's solution up to now.
The second problem is that whenever I give Earth rotation angles other than 0
(or include the axial tilt), the mesh2 is rotated "out of sight" for the trace()
vector to place the camera on the surface - though in the definition of the
mesh2, all vertices are defined with respect to the origin (as you might look up
in mesh2writer.pov)! So when I try to render such a scene, I just get empty
black space...
Any suggestion how to fix that?
See you in Khyberspace!
Yadgar
Download '2010-11-20 afghan highlands south of koh-e baba range, take 1.jpg' (42 KB)
Preview of image '2010-11-20 afghan highlands south of koh-e baba range, take 1.jpg'
Subject: Re: Afghan highlands - problems with mesh2
Date: 20 Nov 2010 14:42:52
Message: <4ce824bc@news.povray.org>
> High!
> heightfields.
> itself).
> black space...
> Yadgar
Did you try applying the rotations before translating to the final location?
If you translate then rotate, the mesh will orbit around the origin.
You may also use min_extent() and max_extent() to locate the final
location of the mesh and trace accordingly.
Date: 20 Nov 2010 19:23:23
Message: <4ce8667b$1@news.povray.org>
"Alain" <aze### [at] qwertyorg> schrieb im Newsbeitrag
news:4ce824bc@news.povray.org...
> location?
Yes, I did - see here:
#declare Earth_Slice=
object
  Earth_Slice_N34E067
  texture
    pigment { color rgb <1, 0.9, 0.4> }
    finish { ambient 0.1 diffuse 1 brilliance 0.4 }
  rotate <0, -Earth_Rot, 0>
  translate Earth_Pos
  // rotate <Earth_Tilt, 0, 0>
...and the original mesh2 definition does not contain any rotate statement
at all!
Date: 22 Nov 2010 19:44:39
Message: <4ceb0e77@news.povray.org>
> "Alain"<aze### [at] qwertyorg>  schrieb im Newsbeitrag
>> location?
> object
>    Earth_Slice_N34E067
>    texture
>      pigment { color rgb<1, 0.9, 0.4>  }
>    rotate<0, -Earth_Rot, 0>
>    translate Earth_Pos
>    // rotate<Earth_Tilt, 0, 0>
> at all!
Then, you need to use min_extent() and max_extent() to locate the actual
bounding box of the mesh and trace to somewhere into that bounding box.
