POV-Ray : Newsgroups : povray.binaries.images : rounded_lsweep, an object macro Server Time
19 Feb 2026 03:37:32 EST (-0500)
  rounded_lsweep, an object macro (Message 1 to 10 of 21)
Subject: rounded_lsweep, an object macro
Date: 13 Jul 2010 22:45:51
Message: <4c3d24df@news.povray.org>
I went searching for a macro to round out the corners of linear
sphere_sweeps, but was not successful. So I made my own :) It's easy to
use: you just provide the spline points (and optionally the arc radii)
for each point. It automatically joins the first and last points if they
are the same. Since the object is made out of cylinders, tori and discs,
the render time is pretty good.
The include file and an example scene are available over at p.t.scene-files:
http://news.povray.org/povray.text.scene-files/thread/%3C4c3d20db%40news.povray.org%3E/
Happy Ray Tracing!
Sam
Download 'rounded_lsweep_render.jpg' (114 KB)
Preview of image 'rounded_lsweep_render.jpg'
Subject: Re: rounded_lsweep, an object macro
Date: 14 Jul 2010 03:33:17
Message: <4c3d683d$1@news.povray.org>
You did it again, Sam! Congratulations and thank you indeed!
Something for the Object Collection, no doubt.
Date: 14 Jul 2010 11:37:19
Message: <4c3dd9af$1@news.povray.org>
Cool! Thanks for looking beyond the horribly sterile image :) The macro
does not perform any bounds checking to properly fit the arcs to the
segments. Doing so would have been too complex. The current behavior
actually gives you more control, I think.
Can you think of a better name than "rounded_lsweep"? I tried to choose
a name that would conform to the Object Collection's naming convention,
just in case I decided to post it there.
I can already think of a couple more useful macros based on this
technique. Hopefully I can make progress on at least one of them, to
finish a modeling project.
Date: 14 Jul 2010 11:53:29
Message: <4c3ddd79@news.povray.org>
> The macro does not perform any bounds checking to properly fit the arcs to the
> segments.
To clarify, the arc segments *do* conform to the angles as they should.
But if they are too large they will extend past the arcs from another
corner, so the arc radius will not automatically adjust itself to keep
this from happening... which amounts to you having to give the offending
corner a smaller arc radius. I hope that makes sense. As usual I didn't
express myself properly :(
Date: 15 Jul 2010 04:15:00
Message: <4c3ec384@news.povray.org>
"stbenge" <myu### [at] hotmailcom> schreef in bericht
news:4c3dd9af$1@news.povray.org...
It looks very reasonable to me indeed and useful for most cases I am sure.
Purists might want something more sophisticated, but generalist like me are
very happy with it!
> Can you think of a better name than "rounded_lsweep"? I tried to choose a
> name that would conform to the Object Collection's naming convention, just
This seems acceptable to me, simple and descriptive. I cannot come up with
something better...
Waiting impatiently for further contributions ;-)
Date: 15 Jul 2010 04:19:31
Message: <4c3ec493$1@news.povray.org>
news:4c3ddd79@news.povray.org...
Clear enough for me, Sam. Good to keep in mind. I see that you have put this
in your caveats.
Date: 15 Jul 2010 12:23:28
Message: <4c3f3600@news.povray.org>
> very happy with it!
Glad to hear it. The purists can be such snobs sometimes ;)
It all depends on how stuck I get. I found myself stumped for hours
yesterday on a single problem. I finally found the solution by analyzing
the problem carefully, but now I need the implementation... I ended up
learning the basics of Coordinate Geometry to figure out the problem,
since I was never taught higher math in school... I can make a line and
find the y-intercept, but now I need to find it for three dimensions. If
I take it a step at a time, the pieces should fall into place like they
did for rounded_lsweep.
Date: 15 Jul 2010 19:57:44
Message: <4c3fa078@news.povray.org>
stbenge wrote:
> I can make a line and find the y-intercept, but now I need to find it
If you have a problem just ask in the newsgroups and I'm sure
people will be queueing up for the honor of answering ;)
Date: 15 Jul 2010 22:21:56
Message: <4c3fc244@news.povray.org>
I know, I know. And it's appreciated! Usually I try to figure these
things out for myself, asking questions only when I'm stuck. Which I'm
not this time, because right when I decided to start hammering out a
method for 3D line/plane intersection, a thought occurred to me: Luke,
use the trace(). So now I'm unstuck :D
Date: 15 Jul 2010 23:49:38
Message: <4c3fd6d2$1@news.povray.org>
I thought a cheat-sheet kind of thing for this sort of basic geometric
equations would be handy.  A book that goes into the basics of the geometric
math in a way that's easy to look things up, for (say) inside/outside calcs,
intersections of various simple shapes, calculating angles in various
situations, and so on.
    C# - a language whose greatest drawback
    is that its best implementation comes
    from a company that doesn't hate Microsoft.
