POV-Ray : Newsgroups : povray.binaries.images : Lego Helicopter 645 - Colouring Page Server Time
28 May 2026 15:15:41 EDT (-0400)
  Lego Helicopter 645 - Colouring Page (Message 9 to 18 of 18)
<<< Previous 8 Messages Goto Initial 10 Messages
Subject: Re: Lego Helicopter 645 - Colouring Page
Date: 18 Jun 2010 12:26:38
Message: <4c1b9e3e@news.povray.org>
Reuben Pearse wrote:
> stbenge wrote:
>> The attached image shows the result of an edge-finding function I just
>> slapped together.
> That looks great! Your macro seems to do a better job on certain parts
> of the image such as:
> 1) The line at the top of the propeller blade
> 2) The inside of the propeller blade
> 3) The handle on the door
> ..but I'm guessing that this may be do with the angle at which the
> camera is viewing the object?
Well, because it's a post-processing effect, anywhere there's a sharp
difference between one color and another is where the method will place
a line. It's a completely visual process and does not care whether an
object is a mesh or not, so you don't gain access to any special mesh
information.
> I've now uploaded the POV source files that I used to create the
> helicopter colouring page. See link below:
> http://www.pearse.co.uk/lego/colouring/helicopter
OK, I'll give it a try. I'll also try the original .obj file as well,
since I woke up with an idea in mind. How are you at manipulating
meshes? Can you, say, take a mesh, select polygons, and then apply
different colors to them? I ask because blocks can be colored randomly
to create the necessary color difference for my method to work. The
lines between bricks should then become visible. I'll give it a go later
on and post something if I make any headway.
Also, last night I came up with a one-step process using MegaPOV which
renders pretty quickly, all things considered. I'm using the LGEO Lego
parts library to test with (slower than a mesh), and those blocks are
beveled. But if my coloring technique for meshes works out, there won't
be any need to use LGEO. Getting away with only a single render pass
using MegaPOV would lighten the overall process.
> I think for certain types of shape, your macro may render a better
> result. I created a colouring page of a Star Wars Battle Droid using the
>  same technique, but the PovEdge macro picked up to many edges on the
> battle droids head. This can be seen on the following link:
> http://www.pearse.co.uk/lego/battle_droid.html
Ah yes, the outside edges of some rounded surfaces are hardly visible,
and some convex edges are much too apparent.
> If I upload the source of the battle droid image would you mind trying
> your technique with that model?
Sure, but it might be better to have an .obj mesh, depending on what
kind of progress I make today.
Hopefully in the end you'll find a process that works for you! Maybe
some other people around here will chime in with some ideas :)
Date: 18 Jun 2010 14:44:23
Message: <4c1bbe87@news.povray.org>
Attached is an image showing my progress so far. I randomly changed some
brick colors to highlight the spaces between bricks. It was rendered in
MegaPOV in a single pass and took 5 minutes, 41 seconds to render with
one core. You can see how the pegs break up here and there. Some of the
lines also seem to extend over others in funny places. It seems that
there's always a trade-off when finding edges. The missing line on the
propeller was my fault; I forgot to change the brick color there. The
missing lines under the front of the cab were caused by a lack of
definition in that area.
I'll post an image to help explain how I needed to color the bricks
differently.
Download 'edgefinder5_41.png' (34 KB)
Preview of image 'edgefinder5_41.png'
Date: 18 Jun 2010 14:51:30
Message: <4c1bc032@news.povray.org>
> differently.
And here's what the function uses for input. Anywhere two bricks of the
same color meet, I had to change the color of one. I didn't change the
entire brick color, since it wasn't needed.
Maybe if you use this method, you could make an extra model in which
bricks of the same color never touch each other? Or is there an option
somewhere which would let you add spaces between bricks? That might be
better, since it's kind of a pain to change brick colors by selecting
polygons and then having to export the mesh again, thus contending with
improper normals being generated. But even just assigning bricks
different colors in the Lego program you use would be better than
selecting polygons and changing colors.
Download 'edgefindercolors.jpg' (37 KB)
Preview of image 'edgefindercolors.jpg'
Date: 18 Jun 2010 15:39:56
Message: <4c1bcb8c@news.povray.org>
Oops, I left a bunch of stuff out of that one. Here's another version
that shows more of the edges. I changed the camera position slightly and
the light_source, and now the pegs looks even taller than they did. this
method is very touchy. It might as well be a MEGA Bloks model. Heck, if
it were any worse, it would start to resemble something you would make
with American Bricks.
Download 'edgefinder8_10.png' (36 KB)
Preview of image 'edgefinder8_10.png'
Date: 18 Jun 2010 17:23:02
Message: <4c1be3b6@news.povray.org>
Hello,
I have not been very active recently, but I'm happy to see that PovEdge
is used ! And happy too that other people are developping alternative
techniques (go on Sam :-) !)
Transparent objects should be ok with PovEdge : just give a fully
transparent texture to the windshield (like rgbt 1), and you should be
able to see the edges of the objects behind it (I have done that many
times for the windshield and windows of cars).
For the problem with the droid head (some message further in the
thread), did you try reducing the threshold for the crease edges
(parameter EdThresh) ? Btw on your picture, the silhouette edges seems
that have a color lighter than black, is this on purpose ?
Thibaut
> Hello everyone!
> I've created another Lego colouring page based on the Police Helicopter
> set 645.
> This image was created using a combination of MLCAD, LdrDat2Dxf (by Rolf
> Redford), PoseRay, POV-Ray 3.6 and the PovEdge macro (by Thibaut
> Jonckheere).
> I created the black and white image by setting all the objects to white,
> and then used the "outdoor radiosity" option from PoseRay. I had to add
> a couple of extra light sources to saturate the image with light. I had
> some problems trying to maintain the transparency of the windscreen, but
> happy with it for now (I'm not sure how the PovEdge macro copes with
> transparent objects - perhaps I need to do some more experiments).
> Does anyone have any other tricks for creating these kind of images
> (i.e. rendering shape outlines of 3d objects)?
> You can download printable PDF's and other 3D model formats, including
> POV-Ray scene files at the following links.
> http://www.pearse.co.uk/lego/colouring/helicopter/
> http://www.pearse.co.uk/lego/models/helicopter/
> Bye for now
> Reuben
> reu### [at] pearsecouk
Date: 18 Jun 2010 17:26:31
Message: <4c1be487@news.povray.org>
PS : to reduce aliasing (visible on some parts of your helicopter), one
simple effective technique (in addition to parameters like +a0.0 +am2
+r3 ...) is to render the picture on a larger size, and then rescale
with some image manipulation tool. Usually, render time is not a problem
with this kind of picture, so it is possible to render very large images.
Thibaut
> Hello,
> Thibaut
>> Hello everyone!
>> Helicopter set 645.
>> Rolf Redford), PoseRay, POV-Ray 3.6 and the PovEdge macro (by Thibaut
>> Jonckheere).
>> white, and then used the "outdoor radiosity" option from PoseRay. I
>> had to add a couple of extra light sources to saturate the image with
>> light. I had some problems trying to maintain the transparency of the
>> windscreen, but happy with it for now (I'm not sure how the PovEdge
>> macro copes with transparent objects - perhaps I need to do some more
>> experiments).
>> Bye for now
>> Reuben
Date: 18 Jun 2010 18:13:56
Message: <4c1befa4@news.povray.org>
And yet another version with the light's position changed slightly. I
think I'll quit for now. It's been fun :) I dropped the MegaPOV file for
finding edges over at p.t.scene-files in case you're interested:
http://news.povray.org/povray.text.scene-files/thread/%3C4c1beb00%40news.povray.org%3E/
I'm not sure it will work for your purposes, since there are still many
errors present. If I could discover a way to keep the lines from
drifting in weird ways, it could be more useful. There is still one more
idea I have left to try, but it's a long shot.
I took a gander at your helicopter-colouring files, and I'm not sure I
can make that method work with mine. Also, I got my edge pattern to work
with an obj file of the helicopter, but really ugly effects crop up.
Download 'edgefinder8_01.png' (36 KB)
Preview of image 'edgefinder8_01.png'
Date: 20 Jun 2010 16:56:57
Message: <4c1e8099$1@news.povray.org>
Thibaut Jonckheere wrote:
> Hello,
Hi Thibaut,
It's great to see you posting again. Thanks for contributing to the
discussion.
I've enjoyed using your PovEdge macros, but there are probably lots of
options and settings that I haven't explored or understood :-)
Would it be possible to amend the macro so that it somehow visually
labelled each edge that was drawn with a number? You could then
optionally instruct the macro not to draw certain edges by passing it a
list of edges numbers. As well as giving greater control over the
render, it could also provide a way of creating "dot to dot" type
colouring pictures (see example links below).
http://www.lego.com/ToyStory/en-us/Downloads/Dot-to-Dot.aspx
Let me know your thoughts on this.
Reuben
Date: 24 Jun 2010 03:08:26
Message: <4c23046a@news.povray.org>
Hi Reuben,
In short :
- drawing 'dots' in place of 'edges' (which means, for Povray, sphere
rather than cylinder) is a simple modification to the macro
EdgeMesh.inc, which I can implement if you want to play with that. Note
that the result you get will depend a lot of the definition of the mesh
(for a very fine mesh, with lots of vertices/faces/..., the spheres will
be so close that you won't see the difference with the cylinders; if the
mesh has fewer vertices, then it might show as a "dot to dot" picture)
- visually labelling the edges seems very difficult (at lest to get a
decent result), as the numbers involved could easily be large, and also
the placement of the numbers is by no means easy (3D objects for the
numbers, or post-process 2d numbers ?, ...) .
-modifying povedge to get, in one click, a "dot by dot" picture with the
numbers for the dots is also not possible because the edges are not
ordered along the contours (I mean that, if you follow the silhouette of
an object, the internal numbering of these edges by povedge can be
anything, and is not 1,2,3,4... ). So I think that it is possible to
produce a "dot to dot" picture, by you'll need to add the numbers by
yourself after rendering the picture in Povray.
Thibaut
PS : I had a quick look at your helicopter model. It seems that there
are some artefacts in the silhouette contour (which is why, I guess, you
put the width of this contour to nearly 0, to hide it). These artefacts
are related to problems with the normals in the model itself (typically,
if one normal is wrongly oriented with respect to its neighbours, it
will create one spurious silhouette edge). I tried to mend that on the
.obj model with Poseray ("calculate normals" in the Groups tab), but
without success.  How did you create the model, and it there a way to
check the normal of it before exporting it to .obj format ?
> Reuben
Date: 23 Aug 2010 17:18:54
Message: <4C72E5C3.5020601@pearse.co.uk>
>> a list of edges numbers. As well as giving greater control over the
> Hi Reuben,
> In short :
It would be great if you could amend your macro to draw 'dots' in place
of 'edges'. I could then experiment with different meshes to try and
create a "dot to dot" image.
Thanks
Reuben
> Thibaut
>> Reuben
