POV-Ray : Newsgroups : povray.binaries.images : My latest Saturn Server Time
28 May 2026 13:56:09 EDT (-0400)
  My latest Saturn (Message 1 to 4 of 4)
Subject: My latest Saturn
Date: 13 Apr 2010 19:10:44
Message: <4bc4f9f4@news.povray.org>
My friend is preparing an astronomy lecture and asked me to produce a video
of a saturn flyby, so I dusted of an old saturn I did, but I wasn't
satisfied with the rings.
The original version used a spherical pattern and a colour_map to do the
rings, but it looked flat and artificial.
Here is the latest version. The new version uses three images from Bjorn
Jonsson's excellent website (http://www.mmedia.is/~bjj/) for the rings. The
problem I had was that POV has no innate way of mapping an image_map
radially onto a flat plane (ie the rings). I solved this by writing some
functions that map a radial coordinate onto the linear image_map. The new
rings show far more detail and look much more realistic. If anyone knows an
easier way please tell me!
I have posted the source and image files into p.b.s-f
Now the animation is done, my friend has asked if I can do another of
Jupiter!
Rarius
Download 'Saturn.png' (237 KB)
Preview of image 'Saturn.png'
Subject: Re: My latest Saturn
Date: 14 Apr 2010 05:01:09
Message: <4bc58455$1@news.povray.org>
Am 14.04.2010 01:10, schrieb Rarius:
Using an image map with cylindrical warp should do the job, but you'll
have to rotate (and possibly translate and scale) the image map in a
suitable fashion first:
       image_map { png "foobar.png" }
       rotate <0,90,90>
       warp { cylindrical }
This assumes that the image map shows the rings as vertical stripes,
each representing a full 360 degrees arc.
Date: 14 Apr 2010 05:44:32
Message: <4bc58e80$1@news.povray.org>
"clipka" <ano### [at] anonymousorg> wrote in message
news:4bc58455$1@news.povray.org...
>     pigment {
>       rotate <0,90,90>
> This assumes that the image map shows the rings as vertical stripes, each
Many thanks for that clipka. I thought a warp might do it, but I just
couldn't find anything in the documentation about how warp{cylindrical}
worked and/or the parameters.
Your assumption is correct. the images are vertical bars...  Now all I need
to do is figure out how to combine the three images I have, colour,
transparency and albedo together!
Rarius
Date: 14 Apr 2010 08:17:52
Message: <4bc5b270@news.povray.org>
Am 14.04.2010 11:44, schrieb Rarius:
I'd try as follows:
- Use the colour file as a pigment image_map to get your hue.
- Use the albedo file as a texture image_pattern to mix between plain
black and the hue pigment.
- Use the transparency file as a texture image_pattern to mix between
transparent (rgbt 1) and that other mixed texture.
Or use some image processing software (Photoshop or Gimp or whatever you
have) to do the mixing into a .png with alpha channel, and use that
straight away as a pigment image_map.
