POV-Ray : Newsgroups : povray.binaries.images : Lens flare in scene Server Time
11 Apr 2026 03:22:44 EDT (-0400)
  Lens flare in scene (Message 1 to 5 of 5)
Subject: Lens flare in scene
Date: 7 Mar 2010 06:29:01
Message: <4b938dfd@news.povray.org>
I've had no internet at home for the last 2 months, but that doesn't mean I
haven't been povving! This is something I came up with a few weeks ago. I'm
probably not the first person to attempt this, but I decided to experiment
with lens flare/bloom effects without any post-processing.
The trick is there's a mirror behind the camera with multiple normal maps
blended together (by averaging the texture), and another mirror just in
front of the camera that's part-reflective part-transparent. The transparent
part lets us see the scene, the reflective part shows the mirror behind,
which reflects multiple rays to trace all the samples needed for lens flare.
This is a ludicrously elaborate way to do things, and makes a simple scene
take AGES to render, but it's kind of fun to play with these things :)
I'll post an animation in p.b.a and source in p.b.s-f shortly...
Tek
http://evilsuperbrain.com
Download 'lens_flare_in_scene.jpg' (36 KB)
Preview of image 'lens_flare_in_scene.jpg'
Subject: Re: Lens flare in scene
Date: 7 Mar 2010 11:03:44
Message: <4b93ce60$1@news.povray.org>
Nice trick.
You can probably do with one less mirror.
Instead of having a miror behind the camera and a partialy transparent
one in front, use only one in front of the camera and place the scene
itself behind the camera. The mirror need a flat normal. Give that flat
normal a higher weight than the others.
For a sample, there is a scene named "hot thing" that use that trick. It
use specular highlight and several lights to create a bloom effect.
Another way would be to have a transparent poligon in front of the
camera. Give that poligon an averaged normal and an ior.
Date: 7 Mar 2010 13:45:00
Message: <web.4b93f2d63b6032157052cdec0@news.povray.org>
I tried a similar thing in the past, but not this exact Teknique. I used a
transparent plane with several averaged normals via a texture map. I can't
remember how it turned out, only that it took for frickin' ever, and there
wasn't the benefit of specular highlights...
Your method looks pretty good! It's actually quite natural, at least where you
can't see the flare from the light directly.
Sam
Date: 7 Mar 2010 20:23:13
Message: <4b945181$1@news.povray.org>
I thought about using ior, but it's harder to control the direction of the
rays (reflections are pretty simple) and you can't get specular highlights
on the light source.
However, the backwards camera is a good point. I'll do that if I ever want
to use this in a real image (unlikely unless I have a few months for
rendering!).
Tek
"Alain" <aze### [at] qwertyorg> wrote in message
news:4b93ce60$1@news.povray.org...
>> I
>> I'm
>> experiment
>> transparent
>> flare.
>> scene
> Nice trick.
> Instead of having a miror behind the camera and a partialy transparent one
> in front, use only one in front of the camera and place the scene itself
> behind the camera. The mirror need a flat normal. Give that flat normal a
> Another way would be to have a transparent poligon in front of the camera.
> Alain
Date: 7 Mar 2010 20:25:26
Message: <4b945206$1@news.povray.org>
"Samuel Benge" <stb### [at] hotmailcom> wrote in message
news:web.4b93f2d63b6032157052cdec0@news.povray.org...
> you
Thanks! I think I could make it look a lot better if I spent time tweaking
it, but I think I've spent long enough on this incredibly slow technique!
Tek
