POV-Ray : Newsgroups : povray.binaries.images : Isosurface problem Server Time
23 Dec 2025 17:04:23 EST (-0500)
  Isosurface problem (Message 1 to 8 of 8)
Subject: Isosurface problem
Date: 3 Feb 2010 09:06:26
Message: <4b6982e2@news.povray.org>
I started re-modelling my pocketwatch, and am using an isosurface for
the detail relief on the casing.  After a bit of reading documentation,
I've reached a stumbling block.
#include "functions.inc"
#declare fn_deco1=function{
   pigment{
     image_map{
       tga "D:\Personal\0\0\6\6\Textures\watchdecor1.tga"
       map_type 2 once interpolate 4
     scale <-1,1,1> rotate 90*x
     scale <1,1,0.05> translate <0,0,0.035>
#declare sl=1.1;
isosurface{
   function{
     sqrt(pow(x/sl,2)+pow(y/sl,2))+z-0.808
     -(fn_deco1(x,y,z).grey*0.013)
   contained_by{box{<-0.9,-0.9,0.035>,<0.9,0.9,0.085>}}
   max_gradient 36.655
   texture{pigment{rgb 1} finish{ambient 0 diffuse 0.5 reflection{0.3}}}
My problem is this:  I want the extrusion to be along the normal of the
slope, not parallel to the xy-plane.  How would I do this?
Tim Cook
http://empyrean.freesitespace.net
Download 'pocketwatch.png' (106 KB)
Preview of image 'pocketwatch.png'
Subject: Re: Isosurface problem
Date: 3 Feb 2010 10:01:35
Message: <4b698fcf$1@news.povray.org>
That sounds like a job for mesh displacement.
Date: 4 Feb 2010 15:43:56
Message: <4b6b318c@news.povray.org>
Current state of things.  Map in major need of improvement in addition
to fixing extrusion direction.
Tim Cook
Date: 5 Feb 2010 00:31:12
Message: <4b6bad20@news.povray.org>
If extruding the outer surface of a torus is close enough, this type of
construction might work for you.  You may need to make the image taller,
with the pattern centered vertically, so it doesn't wrap around to the
donut-hole-side of the torus.
   pigment{
     image_map{
       png "decoband.png"
       map_type 5 interpolate 4
#local r_major=1;    //This matches the map_type 5 major radius.
#local r_minor=0.05;
isosurface{
     function{f_torus(x,y,z, r_major, r_minor)
             -fn_deco1(x,y,z).grey*0.013 }
//max_gradient, contained_by, and whatnot...
//scale, rotate, and translate as needed.
~David
Download 'watchdeco.png' (34 KB) Download 'decoband.png' (4 KB)
Preview of image 'watchdeco.png'
Preview of image 'decoband.png'
Date: 5 Feb 2010 01:52:36
Message: <4b6bc034@news.povray.org>
Say, that's rather clever.  Now to figure out if I can scale it enough
to get an approximately equivalent base surface...
Tim Cook
Date: 5 Feb 2010 16:25:57
Message: <4b6c8ce5$1@news.povray.org>
It occurs to me that I can use a sphere just as well as a torus...
Sometimes the simplest solution is the best, after all.
Tim Cook
Date: 5 Feb 2010 19:17:27
Message: <4b6cb517$1@news.povray.org>
I'm looking forward to seeing how it comes along.  :)
~David
Date: 6 Feb 2010 18:45:57
Message: <4b6dff35@news.povray.org>
Could use some improvement for accuracy, but I guess I'm ready to forge
ahead to the rest of the watch.
Tim Cook
Download 'pocketwatch.png' (92 KB)
