POV-Ray : Newsgroups : povray.binaries.images : hf_tools.inc Server Time
11 Apr 2026 07:27:59 EDT (-0400)
  hf_tools.inc (Message 1 to 10 of 26)
Subject: hf_tools.inc
Date: 15 Dec 2009 01:46:52
Message: <4b2730dc@news.povray.org>
Hello,
Here are some example shots from hf_tools.inc, which I just dropped at
p.b.scene-files.
The top two images show the edge pattern at work. The edge pigment in
the upper-left image was rendered at less than one third quality; it
does get better than that :) The upper-right image is using a
pre-rendered edge map at full quality. The edge radius is adjustable.
The bottom left image shows the superellisoidal pigment encasing a
height field. It lets you make smooth transitions from height field to
plane, while keeping more detail at the corners (as opposed to using,
say a spherical pigment).
The bottom right image shows how an angle map can be used to transform
textures according to the different angles of a height field.
Just a few features. Maybe they will prove useful...
Sam
P.S. The upper-right image shows some strange behavior at the height
field's edges. POV-Ray is handling image maps incorrectly, I think.
Download 'hf_tools.jpg' (156 KB)
Preview of image 'hf_tools.jpg'
Subject: Re: hf_tools.inc
Date: 15 Dec 2009 02:43:30
Message: <4b273e22@news.povray.org>
   I'm without words... really. :O
Jaime Vives Piqueres
http://www.ignorancia.org
Date: 15 Dec 2009 03:16:45
Message: <4b2745ed$1@news.povray.org>
"stbenge" <UN### [at] hotmailcom> schreef in bericht
news:4b2730dc@news.povray.org...
Well, that is easy for us to cut off in a difference or intersection.... :-)
This is really incredible. I need to experiment with this now!
You rule, Sam! You rule!
Date: 15 Dec 2009 07:12:54
Message: <4b277d46@news.povray.org>
High!
stbenge wrote:
> Hello,
> p.b.scene-files.
Awesome! When I saw the upper right and lower left image, I instantly
thought "Afghanistan!"... yes, this tool would be great for rugged
desert landscapes on DM +19 279 e XI (or Ghurghusht, how it is called by
its colonists). For real Afghanistan, I better rely on actual elevation
data... but perhaps there might be a way to enrich them with small-scale
erosion details!
See you in Khyberspace!
Yadgar
Date: 15 Dec 2009 10:28:05
Message: <4b27ab05$1@news.povray.org>
Two words:  A Mazing!  ;-)
On 2009-12-15 01:45, stbenge wrote:
> Hello,
> p.b.scene-files.
> Sam
Date: 15 Dec 2009 12:20:00
Message: <4b27c540@news.povray.org>
Holy grab!
Date: 15 Dec 2009 12:21:49
Message: <4b27c5ad$1@news.povray.org>
WOW!
That top left one looks like a polycrystalline surface under high
magnification, it already looks useful!
Date: 15 Dec 2009 13:46:00
Message: <4b27d968$1@news.povray.org>
> High!
Not yet! Maybe my second cup of coffee will do the trick ;)
> erosion details!
I hope you know that this file _does_not_ produce erosion... That height
map is an example I included from World Machine :/
Date: 15 Dec 2009 13:46:33
Message: <4b27d989$1@news.povray.org>
That's the best way to be, at least until you learn the tool's
limitations ;D
Date: 15 Dec 2009 13:53:12
Message: <4b27db18$1@news.povray.org>
Yeah, but it's an annoying way to go about it. You can always use the
boxed pigment to cut off the edges while building you HF.
After reading Yadgar's reply, I started to worry that everybody thinks
this file can produce erosion... it cannot... It only does what I said
it does, plus some near-useless red/green functions that I'm not
particularly proud of :/
