POV-Ray : Newsgroups : povray.binaries.images : hf_tools.inc Server Time
22 Apr 2026 21:36:12 EDT (-0400)
  hf_tools.inc (Message 7 to 16 of 26)
<<< Previous 6 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: hf_tools.inc
Date: 15 Dec 2009 12:21:49
Message: <4b27c5ad$1@news.povray.org>
stbenge wrote:
> The top two images show the edge pattern at work. The edge pigment in
> the upper-left image was rendered at less than one third quality; it
> does get better than that :)
> Just a few features. Maybe they will prove useful...
WOW!
That top left one looks like a polycrystalline surface under high
magnification, it already looks useful!
Date: 15 Dec 2009 13:46:00
Message: <4b27d968$1@news.povray.org>
> High!
Not yet! Maybe my second cup of coffee will do the trick ;)
> Awesome! When I saw the upper right and lower left image, I instantly
> thought "Afghanistan!"... yes, this tool would be great for rugged
> desert landscapes on DM +19 279 e XI (or Ghurghusht, how it is called by
> its colonists). For real Afghanistan, I better rely on actual elevation
> data... but perhaps there might be a way to enrich them with small-scale
> erosion details!
I hope you know that this file _does_not_ produce erosion... That height
map is an example I included from World Machine :/
Date: 15 Dec 2009 13:46:33
Message: <4b27d989$1@news.povray.org>
>   I'm without words... really. :O
That's the best way to be, at least until you learn the tool's
limitations ;D
Date: 15 Dec 2009 13:53:12
Message: <4b27db18$1@news.povray.org>
Thomas de Groot wrote:
> "stbenge" <UN### [at] hotmailcom> schreef in bericht
> news:4b2730dc@news.povray.org...
>> P.S. The upper-right image shows some strange behavior at the height
>> field's edges. POV-Ray is handling image maps incorrectly, I think.
> Well, that is easy for us to cut off in a difference or intersection.... :-)
Yeah, but it's an annoying way to go about it. You can always use the
boxed pigment to cut off the edges while building you HF.
> This is really incredible. I need to experiment with this now!
> You rule, Sam! You rule!
After reading Yadgar's reply, I started to worry that everybody thinks
this file can produce erosion... it cannot... It only does what I said
it does, plus some near-useless red/green functions that I'm not
particularly proud of :/
Date: 15 Dec 2009 13:57:51
Message: <4b27dc2f$1@news.povray.org>
Rick Gutleber wrote:
> Two words:  A Mazing!  ;-)
Thanks... Hmm, your comment is making me think about height field mazes.
It might just be possible with arrays and a variation of Tek's Cells
pattern...
Date: 15 Dec 2009 14:00:39
Message: <4b27dcd7$1@news.povray.org>
nemesis wrote:
> Holy grab!
Clear the streets, the Caped Crusader is passing through ;)
Date: 15 Dec 2009 14:03:25
Message: <4b27dd7d$1@news.povray.org>
> WOW!
I hope so :)
Date: 15 Dec 2009 16:51:51
Message: <4b2804f7$1@news.povray.org>
> Hello,
> Here are some example shots from hf_tools.inc, which I just dropped at
> p.b.scene-files.
> does get better than that :) The upper-right image is using a
> pre-rendered edge map at full quality. The edge radius is adjustable.
> The bottom left image shows the superellisoidal pigment encasing a
> height field. It lets you make smooth transitions from height field to
> plane, while keeping more detail at the corners (as opposed to using,
> say a spherical pigment).
> The bottom right image shows how an angle map can be used to transform
> textures according to the different angles of a height field.
> Sam
It looks like it can be prety usefull. I'll play with that one.
Date: 15 Dec 2009 19:22:19
Message: <4b28283b@news.povray.org>
Did you use the "once" keyword? Otherwise the image_map will repeat and
the value at 1.0 will be identical to the value at 0.0 by definition.
Date: 15 Dec 2009 20:56:41
Message: <4b283e59@news.povray.org>
Yes, I tried that. I also tried using repeat warps with the flip
command, in the hope that mirrored edges would eliminate the problem. In
theory, it should work, but it doesn't.
I really need to make a small functioning example to provide along with
a bug report.
