PM 2Ring wrote:
> Tor Olav Kristensen <tor### [at] TOBEREMOVEDgmail com> wrote:
>> PM 2Ring wrote:
>>> That sounds great, Warp. But after over an hour of searching for Marching
>>> Triangles code, I haven't located anything yet, not even pseudocode. :( Do you
>>> have any suggestions for where I should look?
>> You can find some code in this thread:
> Thanks, Tor Olav. I'll have a look at it when I wake up. :)
I see from your answer to Fredrik that it is not Marching Tetrahedrons you're after,
so what I linked to is probably not relevant for you.
Tor Olav
http://subcube.com
> Tor Olav
> http://subcube.com
That's OK. Once I had a look at the code, I realized it wasn't Marching
Triangles, but decided to try it out anyway. The meshes it produces do look
better than Marching Cubes, but of course it is very slow on large data sets,
being in POV SDL rather than C. Especially with recursion depth of 3 or more.
FWIW, in one of my tests I got an error message from POV saying that a normal
vector can't be <0,0,0>.
Here's my latest Mandelbulb, rendered using the isosurface / df3 method.
Resolution = 800³. It uses pseudo-HDRI, with a light dome of 159 light sources,
but no radiosity: it was just too slow. This render took over 7 days on my
480MHz machine. I was hoping for a more impressive looking result, after all
that render time. Oh well.
Download 'mandelbulbja0s90.jpg' (124 KB)
Preview of image 'mandelbulbja0s90.jpg'
"PM 2Ring" <nomail@nomail> schreef in bericht
news:web.4b247f29ce81d185f4c648ed0@news.povray.org...
> sources,
> all
I do find it pretty impressive. Reminds me of some kind of delicate
porcelaine vase. The absence of shadows increases that feeling. I am
impressed by your patience too ;)
Thanks, Thomas. I think my next Mandelbulb renders will be close-ups rather than
trying to do the whole thing. And I might compromise & use a mesh instead of the
isosurface. These complex objects take up so much memory, I couldn't really do
much else while rendering, or the machine would start using virtual memory. That
would've taken months!
Nice.
Here's a 800^3 isosurface/df3, with radiosity and real HDRI, but I can't
figure out what's wrong with my code, since the shape isn't right. It
was supposed to be the n=8 shape from <-1.2,-1.2,-1.2> to <1.2,1.2,1.2>.
Time: 26 minutes with max_gradient 200 on a 2.6 GHz quad-core (AMD
Phenom 9950) for the render, and somewhere around there for the
generation on an older dual-core linux box.
Here's my c++ code for the iterations if anyone can figure out what is
wrong, I've gone through it many times and can't figure out what's not
right...
Chris
/* Iterates the formula at a given x,y,z and returns the smoothed number
of iterations used */
float IteratePoint(double cx, double cy, double cz, double n, double
bailout, int maxiter){
double x=0.0,y=0.0,z=0.0;
double r=0.0,rn=0.0,phin,thetan,sinthetan;
for(int i=0;i<maxiter;i++){
r=sqrt(pow(x,2)+pow(y,2)+pow(z,2));
if(r>bailout){
rn=pow(r,n);
thetan=atan2(sqrt(pow(x,2)+pow(y,2)),z)*n;
phin=atan2(y,z)*n;
x=rn*sin(thetan)*cos(phin)+cx;
y=rn*sin(thetan)*sin(phin)+cy;
z=rn*cos(thetan)+cz;
return (float)i + 1 - (log(log(r)/log(bailout)))/log(n);
rn=pow(r,n);
phin=atan2(y,z)*n;
return (float)maxiter;
and the loop part : (xs/xe are x-start, x-end values, same for y and z)
for (i=0;i<nx;i++){
for (j=0;j<ny;j++){
#pragma omp parallel
shared(df3,nx,ny,nz,xs,xe,ys,ye,zs,ze,bailout,maxiter,n,i,j,chunk)
private(k,cx,cy,cz)
#pragma omp for schedule(dynamic,chunk) nowait
for (k=0;k<nz;k++){
cx = (((double)i+0.5)/(double)nx)*(xe-xs)+xs;
cy = (((double)j+0.5)/(double)ny)*(ye-ys)+ys;
cz = (((double)k+0.5)/(double)nz)*(ze-zs)+zs;
df3[i][j][k]=IteratePoint(cx,cy,cz,n,bailout,maxiter);
if(j%2==0)
ShowStatus(i*nx+j,nx*ny,"Iterating Fractal: ");
Download 'mandel_df3.jpg' (69 KB)
Preview of image 'mandel_df3.jpg'
You're return value may be a bit off. The function log(r)/log(bailout) is the
base bailout logarithm of r,* which may not be what you intended. The usual
formulation of this part is the (base n log of the natural log of the bailout)
minus (the base n log of natural log of the radius), where n is the power of the
mandelbulb. This can then be simplified a little.
return (float)i + 1 - ( log(log(bailout))-log(log(r)) )/log(n)
//then
return (float)i + 1 - log(log(bailout)/log(r)) / log(n)
(Somebody check my math, please. This might be simplified a bit more using the
root/log relationships...)
I don't know if this is the root of your current problem; the formulation you're
using may be just fine. I would like to test it, since I've been monkeying with
continuous return values for the last couple of weeks, but won't be able to do
much more on this until after finals.
* http://en.wikipedia.org/wiki/Logarithms#Change_of_base
> //then
I spent a bit of time on that problem too, and ended up with my equation
based on the Escape Time Algorithm as presented at:
http://en.wikipedia.org/wiki/Mandelbrot_set#Continuous_.28smooth.29_coloring
Unless I'm reading it wrong, that formula is effectively ( i - log[base
N](log[base bailout](r))), which is what I'm using. I assumed that in
the formula on wiki that the inner log (hardcoded as base 2) is actually
base 'bailout', where most formulations of the mandelbrot equation use 2
as the bailout value. The Zn value is stated as the value after n
iterations, which in this case is r. Either I interpreted that equation
wrong, or I'm erroneous in applying the '2d' equation in '3d'.
However, I don't think that's the problem in my equations, since I still
get the same basic shape if I return 'i' instead of the 'smooth'
coloring. Also, I wouldn't expect it to completely remove some of the
features if I got this part of it wrong.
Chris
(I'm also between class and finals, this is how I'm procrastinating
instead of studying and grading a pile of lab reports... )
I'm an idiot, please note that I mean 'Normalized Iteration Count
Algorithm' instead of Escape Time in that sentence.
CShake wrote:
> phin=atan2(y,z)*n;
> phin=atan2(y,z)*n;
Hmm. Perhaps these have a small error? I think maybe they should be like this.
phin=atan2(y,x)*n;
http://www.skytopia.com/project/fractal/2mandelbulb.html#formula
Also, I used the same starting point, then grabbed one of the wikipedia
references and read some more. (I also think I found a small improvement and
plan to write it up over the break.)
I like your color scheme, and also find the surface can have a nice, porcelain
look with the right finish.
Did you leave Jitter on? Jitter on is the default, but I've found using -J
helps reduce "smearing" and "fuzzing" in the final image.
waggy wrote:
> CShake wrote:
>> phin=atan2(y,z)*n;
>> phin=atan2(y,z)*n;
> phin=atan2(y,x)*n;
Right you are, once again one character causes all the problem... Thanks!
That fixed code takes a bit longer to run, but all told this image took
less than an hour, 800^3, n=8.0, radiosity, and the media halo uses the
same df3 (you can see how the smooth scaling works). This isosurface was
created by using function{0.06 - df3_func(x,y,z)}, the 0.06 part can
then be tuned to make the surface 'grow'.
Now I wonder if it's worth doubling the integer size in the df3 to
remove some of the grain.
Download 'mandelbulb_df3.jpg' (79 KB)
Preview of image 'mandelbulb_df3.jpg'
I haven't used any raytracing software for years, but am wondering how
much do the modern machines change the rendering times with something
like this? for instance, i am currently using a quad-core 2.00 ghz
machine with lots of ram. obviously, the quad-core would be faster, but
by how much?
zutroi
zutroi wrote:
>> on my
>> after all
> by how much?
> zutroi
Not only are current CPUs running faster clock speeds than old ones, but
they tend to do more per clock cycle too.
My quad-core Q6600 (overclocked from 2.4GHz to 3.2GHz) really shovels
through renders. It is easily four times as fast as my old dual core
D820. I thought that was fast when I got it!
What CPU do you have? Look it up on Tom's Hardware for an idea how fast
it is compared with others
(http://www.tomshardware.co.uk/charts/processors,6.html)
Remember that POVRay 3.6 only uses a single core.. to use multi-core
CPUs you need to move up to the 3.7 beta.
Rarius
I find it somehow impressive.
Paolo
Le 2009-12-14 06:04, zutroi a écrit :
>> on my
>> after all
> by how much?
> zutroi
Taking the overhead needed when multithreading, 4 cores and 4.166 times
the CPU speed, around 14 to 16 times faster would seems like a realist
estimate. Can even be a LOT faster if the slower machine had to use the
swap and you don't need to on the new one.
"PM 2Ring" <nomail@nomail> wrote:
> Simple "Mandelbulb" C source code.
> Compile with
> gcc -o Mandelbulb Mandelbulb.c -lm -O3
Greetings all,
Here's my humble contribution. The attached archive contains a C++ program that
computes the density file for the Mandelbulb, but using the GPU through an
OpenGL shader. The OpenGL context is provided by SDL 1.3 (currently still in
beta, but already working well).
Compile with:
g++ -Wall -O3 -msse2 -o mandelbulb_gpu -lGL $($SDL13_DIR/bin/sdl-config --cflags
--libs) mandelbulb_gpu.cpp
....where $SDL13_DIR is where you installed SDL 1.3.
On my system (AMD Athlon 64 X2, nVidia 8500 GT), it computes a density file of
1000x1000x1000 in about 12 seconds (using non-trigonometric expansion provided
elsewhere).
Hope this helps.
Best regards,
Download 'mandelbulb.tar.gz' (3 KB)
>> Compile with
> Greetings all,
> Compile with:
> elsewhere).
> Hope this helps.
> Best regards,
Nice. I wanted to play with GPGPU code, but just now finished final
exams for the semester and didn't find the time.
Without looking at the code, I have to ask a few questions:
Can you specify where to zoom in?
Is there any noticeable difference due to using single precision, or are
you using the double registers on the GPU directly (and using 1/10th the
power of the card)?
While I spent a bunch of time on my mbulb df3 generator, I'm probably
going to move on to the native function patch for the ability to
arbitrarily transform the surface (and not need to 'render' twice for
each image)
No, values (boundaries, max_iters, etc.) are hard-coded in a bunch of constants
at the beginning of the source file. But feel free to change them, or I can
modify the code so that they're given as command-line parameters.
> power of the card)?
I can't use double with OpenCL nor GLSL, as the driver and chipset I have don't
provide that extension. From what I read here and there, using double would
reduce performances by a factor of 5 to 10. That said, most of the time is
acutally spend into writing the file: see the attached code, it displays the
mandelbulb in less than a second (not generating the .df3 file, just displaying
using the shader).
> each image)
On 12/13/2009 9:40 PM, CShake wrote:
Interesting image... the grayish protrusions remind me a bit of
ferrofluid under the influence of a strong magnet. Cool!
~Mike
